Elektroda.pl
Elektroda.pl
Wyszukiwarki naszych partnerów
Wyszukaj w ofercie 200 tys. produktów TME
Kategoria: Kamery IP / Alarmy / Automatyka Bram
Montersi
Proszę, dodaj wyjątek elektroda.pl do Adblock.
Dzięki temu, że oglądasz reklamy, wspierasz portal i użytkowników.
Podajnik ADF RICOH Aficio MP161 MP171 MP201 ADFMP16185k
Nazwa elementu Podajnik ADF RICOH Aficio MP161 MP171 MP201 ADFMP16185k
Cena za szt. 280.00 do 280.00 PLN
Ilość ofert 1
114564 Podajnik ADF RICOH Aficio MP161 MP171 MP201 ADFMP16185k
1 280,00 PLN Podajnik ADF RICOH Aficio MP161 MP171 MP201 Zawiera wszystkie części: B8726011 Decal:Misfeed Removal 1 B8724711 Cover:Open And Close 1 AF022144 Pressure Roller 1 B8724721 Shaft:Pressure:Dia4 1 B8726031 Decal:Size:Original 1 B8724722 Spring Plate:R0 2 B8724624 Spring Plate 2 B8724616 Roller:Reverse:Pressure 1 B8724615 Cover:Original Table 1 B8726021 Decal:Side Fence 1 B8724613 Guide:Original Table:Rear 1 B8724612 Guide:Original Table:Front 1 BB013003 Gear - 14Z 1 B8724731 Cover:Rear 1 B87244621 Original Table:Auxiliary 1 AA143788 Pin:Guide Plate:Paper Feed 2 52152621 Snap Ring - M6 1 B872741 Cover:Front 1 B8726071 Decal:Scale:Left:EU 1 B8727014 Cap:Registration Sensor:Scale 1 B8727010 Scale:Left:Adhesion 1 AC013005 Df Exposure Glass 1 B0444929 Sheet - Exposure Glass 2 AA143866 Screw:Dia3.4:M3 1 B8724726 Case:Magnetic 2 G8271023 Magnetic:Hale:Dia10x7 2 B8592352 Pressure Plate Pad 1 B8726081 Decal: Caution Chart 1 B8722312 Guide Plate:Paper Feed:Upper 1 H5211350 Pad - Pick-up 1 B8722311 Guide Plate:Paper Feed:Upper 1 B8722510 Feeder Unit 1 B8722412 Bracket:Magnetic Clutch 1 B8722420 Magnetic Clatch:Ass'y 1 B8725240 Harness:Main 1 B8725210 Harness:Interface 1 B8725100 PCB:Main Control 1 B8722524 Spacer:Dia9 1 B8722523 Spring Clutch:Feed:Dia6 1 B8722521 Shaft:Feed:C 1 B8722513 Feeler:Original Sensor 1 B8722514 Shaft:Pickup 1 B8722512 Gear:Z18 1 B8722526 Spring:Roller Clutch 1 B8722522 Spacer:Pickup 1 AF031062 Feed Roller 1 B8722527 Roller Clutch:Bracket:Feed 1 B8722515 Cushion:Bracket:Feed 1 B8722511 Gear:Idler:Z16 1 B0444961 Oneway Clutch 1 54472681 Snap Ring 1 B8722528 Gear:Z18 1 B8722529 Collar:Pickup 1 AF030363 Pickup Roller 1 B8722222 Holder:Reverse Roller 1 AF032030 Reverse Roller 1 B8722614 Bushing:R1 2 54472681 Snap Ring 1 B8722221 Shaft:Reverse Roller 1 B8722223 Gear:Z17 1 B87222116 Compression Spring:Reverse:Driven 2 B8722113 Shaft:Reverse:Roller:Driven 1 B8722112 Roller:Driven:Dia14 1 AA080034 Bushing - 4x5x7 2 AW020141 Photointerruptor 2 B872110 Guide Plate:Paper Feed:Lower 1 B8722211 Bracket:Reverse 1 B8722212 Spring Plate:Reverse:Pressure 1 B0444962 Cushion 1 AW020155 Photointerruptor:Paper Size Sensor 1 B8724116 Gear:Z44/T14 1 B8724113 Gear:Z44/T16 1 AA043603 Timing Belt:B40S2M128 1 B8722613 Gear:Z22 1 B8724111 Bracket:Motor:Paper Feed:Ass'y 1 B8725810 Stepper Motor Dc24v 3.53w 1 B8721121 Stopper:Original Table 1 B8721122 Compression Spring:Stopper 1 B8723232 Torque Limiter:T24:S2m 1 B8722614 Bushing:R1 2 B8723231 Roller:Reverse:Drive 1 B8722611 Roller:R0 1 B8722118 Guide:Reverse 1 B8722217 Gear:Z28 1 AB017591 Gear - 18/30Z 1 B8722612 Gear:Z19 1 B8723121 Guide Plate:Scanning:Upper 1 B8723211 Roller:Scanning:Front:Drive 1 B8723221 Roller:Exit:Drive 1 B8723111 Guide Plate:Scanning:Lower 1 AW010109 Photo Refiection Sensor:Ps117ed1 2 B8723114 Discharge Brush:Lower 1 B8721515 Spring Plate:Guide:Exposure Glass 2 B8721522 Guide:Exposure Glass 1 AA143544 Screw - M3 2 B8723311 Exchange Powl:Reverse 1 B8723113 Spring Plate:Earth:Exit 1 B8723241 Knob:Pick-up Paper Jam 1 AA043605 Timing Belt:B40S3M114 1 G4173669 Timing Belt:B40S2M190 1 B8723223 Timing Pulley:T32 1 B872212 Pulley:T25 1 AA043604 Timing Belt:B40S2M110 1 AA043603 Timing Belt:B40S2M128 1 B8724214 Pulley:T16/T44 1 B8724216 Tension Spring:Motor:Transport 1 B8725820 Stepper Motor:Dc24v 3.35w 1 B8724210 Bracket:Motor:Transport 1 B8723222 Timing Pulley:T32 1 B8723313 Tension Spring:Exchange Powl 1 B8723312 Lever:Exchange Powl 1 B8724310 DC Solenoid:Exchange Powl 1 B8725250 Harness:Dc Solenoid 1 A8594141 Pulley Idler 1 B8724131 Inner Cover:Left Rear 1 B8721923 Torsion Spring:Pressure:Front 1 B8721921 Lever:Driven:Pressure 1 B8721924 Torsion Spring:Pressure:Rear 1 B8721922 Roller:Driven:Scanning:Front 1 B8721934 Bushing:Exit 2 B8721931 Exit Roller:Driven 1 B8721933 Compression Spring:Exit:Driven 2 B8721912 Cap:Paper Feed Sensor:Base 1 B8721114 Bracket:Side Plate:Rear Right 1 B8721414 Hinge:Left 1 B8721421 Hinge:Right 1 B8726041 Decal:Lever:Knob 1 B3514322 Tape:Pressuer Plate 2 B8724510 Pressure Plate 1 B8724513 Tape:Pressure Plate:Left 2 Przebieg maszyny 85.000 kopii podajnik oczywiście mniej
    05 Lut 2017 18:35
Ilość: 1 280,00 PLN Podajnik ADF RICOH Aficio MP161 MP171 MP201 Zawiera wszystkie części: B8726011 Decal:Misfeed Removal 1 B8724711 Cover:Open And Close 1 AF022144 Pressure Roller 1 B8724721 Shaft:Pressure:Dia4 1 B8726031 Decal:Size:Original 1 B8724722 Spring Plate:R0 2 B8724624 Spring Plate 2 B8724616 Roller:Reverse:Pressure 1 B8724615 Cover:Original Table 1 B8726021 Decal:Side Fence 1 B8724613 Guide:Original Table:Rear 1 B8724612 Guide:Original Table:Front 1 BB013003 Gear - 14Z 1 B8724731 Cover:Rear 1 B87244621 Original Table:Auxiliary 1 AA143788 Pin:Guide Plate:Paper Feed 2 52152621 Snap Ring - M6 1 B872741 Cover:Front 1 B8726071 Decal:Scale:Left:EU 1 B8727014 Cap:Registration Sensor:Scale 1 B8727010 Scale:Left:Adhesion 1 AC013005 Df Exposure Glass 1 B0444929 Sheet - Exposure Glass 2 AA143866 Screw:Dia3.4:M3 1 B8724726 Case:Magnetic 2 G8271023 Magnetic:Hale:Dia10x7 2 B8592352 Pressure Plate Pad 1 B8726081 Decal: Caution Chart 1 B8722312 Guide Plate:Paper Feed:Upper 1 H5211350 Pad - Pick-up 1 B8722311 Guide Plate:Paper Feed:Upper 1 B8722510 Feeder Unit 1 B8722412 Bracket:Magnetic Clutch 1 B8722420 Magnetic Clatch:Ass'y 1 B8725240 Harness:Main 1 B8725210 Harness:Interface 1 B8725100 PCB:Main Control 1 B8722524 Spacer:Dia9 1 B8722523 Spring Clutch:Feed:Dia6 1 B8722521 Shaft:Feed:C 1 B8722513 Feeler:Original Sensor 1 B8722514 Shaft:Pickup 1 B8722512 Gear:Z18 1 B8722526 Spring:Roller Clutch 1 B8722522 Spacer:Pickup 1 AF031062 Feed Roller 1 B8722527 Roller Clutch:Bracket:Feed 1 B8722515 Cushion:Bracket:Feed 1 B8722511 Gear:Idler:Z16 1 B0444961 Oneway Clutch 1 54472681 Snap Ring 1 B8722528 Gear:Z18 1 B8722529 Collar:Pickup 1 AF030363 Pickup Roller 1 B8722222 Holder:Reverse Roller 1 AF032030 Reverse Roller 1 B8722614 Bushing:R1 2 54472681 Snap Ring 1 B8722221 Shaft:Reverse Roller 1 B8722223 Gear:Z17 1 B87222116 Compression Spring:Reverse:Driven 2 B8722113 Shaft:Reverse:Roller:Driven 1 B8722112 Roller:Driven:Dia14 1 AA080034 Bushing - 4x5x7 2 AW020141 Photointerruptor 2 B872110 Guide Plate:Paper Feed:Lower 1 B8722211 Bracket:Reverse 1 B8722212 Spring Plate:Reverse:Pressure 1 B0444962 Cushion 1 AW020155 Photointerruptor:Paper Size Sensor 1 B8724116 Gear:Z44/T14 1 B8724113 Gear:Z44/T16 1 AA043603 Timing Belt:B40S2M128 1 B8722613 Gear:Z22 1 B8724111 Bracket:Motor:Paper Feed:Ass'y 1 B8725810 Stepper Motor Dc24v 3.53w 1 B8721121 Stopper:Original Table 1 B8721122 Compression Spring:Stopper 1 B8723232 Torque Limiter:T24:S2m 1 B8722614 Bushing:R1 2 B8723231 Roller:Reverse:Drive 1 B8722611 Roller:R0 1 B8722118 Guide:Reverse 1 B8722217 Gear:Z28 1 AB017591 Gear - 18/30Z 1 B8722612 Gear:Z19 1 B8723121 Guide Plate:Scanning:Upper 1 B8723211 Roller:Scanning:Front:Drive 1 B8723221 Roller:Exit:Drive 1 B8723111 Guide Plate:Scanning:Lower 1 AW010109 Photo Refiection Sensor:Ps117ed1 2 B8723114 Discharge Brush:Lower 1 B8721515 Spring Plate:Guide:Exposure Glass 2 B8721522 Guide:Exposure Glass 1 AA143544 Screw - M3 2 B8723311 Exchange Powl:Reverse 1 B8723113 Spring Plate:Earth:Exit 1 B8723241 Knob:Pick-up Paper Jam 1 AA043605 Timing Belt:B40S3M114 1 G4173669 Timing Belt:B40S2M190 1 B8723223 Timing Pulley:T32 1 B872212 Pulley:T25 1 AA043604 Timing Belt:B40S2M110 1 AA043603 Timing Belt:B40S2M128 1 B8724214 Pulley:T16/T44 1 B8724216 Tension Spring:Motor:Transport 1 B8725820 Stepper Motor:Dc24v 3.35w 1 B8724210 Bracket:Motor:Transport 1 B8723222 Timing Pulley:T32 1 B8723313 Tension Spring:Exchange Powl 1 B8723312 Lever:Exchange Powl 1 B8724310 DC Solenoid:Exchange Powl 1 B8725250 Harness:Dc Solenoid 1 A8594141 Pulley Idler 1 B8724131 Inner Cover:Left Rear 1 B8721923 Torsion Spring:Pressure:Front 1 B8721921 Lever:Driven:Pressure 1 B8721924 Torsion Spring:Pressure:Rear 1 B8721922 Roller:Driven:Scanning:Front 1 B8721934 Bushing:Exit 2 B8721931 Exit Roller:Driven 1 B8721933 Compression Spring:Exit:Driven 2 B8721912 Cap:Paper Feed Sensor:Base 1 B8721114 Bracket:Side Plate:Rear Right 1 B8721414 Hinge:Left 1 B8721421 Hinge:Right 1 B8726041 Decal:Lever:Knob 1 B3514322 Tape:Pressuer Plate 2 B8724510 Pressure Plate 1 B8724513 Tape:Pressure Plate:Left 2 Przebieg maszyny 85.000 kopii podajnik oczywiście mniej
COPY-EXPERT     05 Lut 2017 18:35
Podajnik ADF RICOH Aficio MP161 MP171 MP201 ADFMP16185k 114564
280,00 PLN   /   Ilość: 1
 Szukaj w ofercie
Zamknij
