Elektroda.pl
Elektroda.pl
Proszę, dodaj wyjątek elektroda.pl do Adblock.
Dzięki temu, że oglądasz reklamy, wspierasz portal i użytkowników.
Short wave halogen lamp with ceramic reflector
Nazwa elementu Short wave halogen lamp with ceramic reflector
Cena za szt. 20.00 do 20.00 PLN
Ilość ofert 1
109287
200 20,00 PLN Short wave infrared emitters Twin tube emitters, tube format 23x11mm Filament temperature 1800-2400 0C Peak wavelength 1.2-1.4um Mean power density 70W/cm Maximum surface power approx. 200kw/m2 Standard emitters are designed for horizontal operation. The emitters can be modified for vertical operation. Emitters are available in different designs and can be one-side or two-side connected. A gold coating of the emitter ensures that the effective radiation is virtually doubled.
    10 Wrz 2013 09:52
109287
Ilość: 200 20,00 PLN Short wave infrared emitters Twin tube emitters, tube format 23x11mm Filament temperature 1800-2400 0C Peak wavelength 1.2-1.4um Mean power density 70W/cm Maximum surface power approx. 200kw/m2 Standard emitters are designed for horizontal operation. The emitters can be modified for vertical operation. Emitters are available in different designs and can be one-side or two-side connected. A gold coating of the emitter ensures that the effective radiation is virtually doubled.
irsenttech     10 Wrz 2013 09:52
109287
20,00 PLN   /   Ilość: 200
