| Author |
Message
Artech Poziom 24
#1
12 May 2008 14:04 Setool - unlock i flash Sony Ericsson, LG, Sharp |
W tym temacie piszemy tylko i wyłącznie na temat działania, problemów i solucji związanych z Setoolem.
Temat założyłem ponownie do czasu aż sie stary odnajdzie..:)@Artech
Kliknij -->>SERVER-STATUS
SE TOOL VIDEO TUTORIALS ,
pomocna stronka bardzo dużo video manuali
Kliknij -->>SETOOL VIDEO MANUAL
Unlock and repair imei w200i
| Description: |
 Download |
| Filename: |
Video Procedura naprawy Red Miga RESET Mode z SeTool korzystanie z karty kredytowej..rar |
| Contents: |
| Filesize: |
10.85 MB |
| Punkty: |
17 = 13 for transfer + 4 for the user (set manually) |
| Description: |
 Download |
| Filename: |
SETOOL_DB2020_CID53_UNLOCK.exe |
| Contents: |
| Filesize: |
9.87 MB |
| Punkty: |
15.85 = 11.85 for transfer + 4 for the user (set manually) |
| Description: |
 Download |
| Filename: |
Jak stworzyć samemu pliki rest-RESTORE FILE.exe |
| Contents: |
| Filesize: |
1.89 MB |
| Punkty: |
6.268 = 2.268 for transfer + 4 for the user (set manually) |
| Description: |
 Download |
| Filename: |
SEtool i fleshowanie db2020 za free ;).txt |
| Contents: |
| Filesize: |
447 Bytes |
| Punkty: |
4 = 0.00 for transfer + 4 for the user (set manually) |
| Description: |
 Download |
| Filename: |
SEtool i CID52,CID53 DB2020, DB2012 i PNX ( z310i ) full unlock.txt |
| Contents: |
| Filesize: |
3.75 KB |
| Punkty: |
| Description: |
 Download |
| Filename: |
PATCH Unlock DB2020 CID52 SEtoolem.txt |
| Contents: |
| Filesize: |
512 Bytes |
| Punkty: |
| Description: |
 Download |
| Filename: |
Nowe K310,K510,W810 z CID50- jak zdjąć loka setoolem.txt |
| Contents: |
| Filesize: |
3.22 KB |
| Punkty: |
| Description: |
 Download |
| Filename: |
Jak Postawić uwalone na 4 zamknięte loki K510,K310,W810 z CID50 ;-).txt |
| Contents: |
| Filesize: |
1.06 KB |
| Punkty: |
| Description: |
 Download |
| Filename: |
Jak odblokowacfleshowac nowe PDA Sonyericssona przez server setoola.txt |
| Contents: |
| Filesize: |
3.44 KB |
| Punkty: |
| Description: |
 Download |
| Filename: |
Jak odblokowac DB2020 metoda firmware patch przez server setoola.txt |
| Contents: |
| Filesize: |
1.66 KB |
| Punkty: |
| Back to top |
Artech Poziom 24
#2
14 May 2008 06:50 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Kolejne manuale :)
| Description: |
 Download |
| Filename: |
Jak naprawić problem oprogramowania,db200x,db201x,db2020,telefonu. -uszkodzony gdfs,erom itp.txt |
| Contents: |
| Filesize: |
3.73 KB |
| Punkty: |
| Description: |
 Download |
| Filename: |
Video procedury Uwolnienie SEMC ODMT303a z SE-Tool użyciu kredytowych.rar |
| Contents: |
| Filesize: |
8.56 MB |
| Punkty: |
14.278 = 10.278 for transfer + 4 for the user (set manually) |
| Back to top |
dickheadGSM Poziom 22
#3
14 May 2008 12:28 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Jak zwykle pojawiaja sie problemy z instalacja ;) wiec pelna wersja 31 tylko do rozpakowania.
Nalezy dograc resty lub zrobic samemu (zawiera aktualne patche).
http://rapidshare.com/files/114779812/v0.914031.zip
W zwiazku ze zmiana polityki Lasera dotyczacej rozbicia restow na supporcie na pojedyncze sztuki zamieszczam wlasna kolekcje restow (okolo 200 mb).
Kolekcja zawiera wiekszosc plikow rest do dostepnich telefonow oraz patche do odblokowanie SEMC OLD.
Kolekcja nie zawiera plikow patch do odblokowywanie telefonow CID52/53.
Archiwum 2 czesciowe, nalezy pobrac obydawa pliki.
| Code: |
http://rapidshare.com/files/114804632/rest.part1.rar
http://rapidshare.com/files/114813329/rest.part2.rar
Resta mozna zrobic samemu posiadajac oprogramowanie, ale mysle ze przydadza sie nowym uzytkownikom setoola np. do sciagniecia simlocka.
| Back to top |
rpk Poziom 20
#4
14 May 2008 12:39 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Pewnie dla większości banalne pytanie ale czy w710i cid52 mam robić tą nową metodą cz po staremu flash na patha? I nie śmiać się ze mnie :)
| Back to top |
#5
14 May 2008 12:53 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
| rpk wrote: |
| Pewnie dla większości banalne pytanie ale czy w710i cid52 mam robić tą nową metodą cz po staremu flash na patha? I nie śmiać się ze mnie :) |
Mozesz nowa mozesz stara (dwie rozne procedury).
Ja wczoraj k800 robilem stara bo nie bylo patcha w nowej pod ten soft co mial.
| Back to top |
rpk Poziom 20
#6
14 May 2008 14:03 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Nie wiem co jest niemoge zrobić tej słuchawki cały czas mam:
v0.914031/UNI
CARD SERIAL: 00041658
Loaded 51 flash descriptors
Open COM port OK
Can't load ID loader !
PROCEDURE WAS STOPPED BY USER
Elapsed: 7 secs.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35306xxxxxxx CERT:RED
FLASH CID:52 COLOR:RED
Model:W710i
Brand:Orange PL
MAPP CXC article: R1JC002 prgCXC1250433_ORANGE_CH
MAPP CXC version: R1JC002
Language Package:ORANGE_GEN
CDA article: CDA102566/7
CDA version: R6A
Default article: cxc1250441
Default version: R1JC002
PROVIDER: 260-03
Network LOCKED
RESTORATION FILE NOT PRESENT
"R1JC002_CXC1250433_ORANGE_CH"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
BYPASS PACKAGE NOT PRESENT
"R1JC002_CXC1250433_ORANGE_CH.zip"
YOU MUST FLASH SUPPORTED FIRMWARE
TO USE "ALTERNATIVE SECURITY BYPASS"
SECURITY UNITS BACKUP CREATED.
Elapsed: 6 secs.
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:353xxxxxxxxx CERT:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
BYPASS PACKAGE ABSENT FOR THAT FIRMWARE.
Elapsed: 8 secs.
do tej pory wszystko latało.
| Back to top |
Artech Poziom 24
#7
14 May 2008 14:06 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Witam a resty to gdzie są??
| Back to top |
#8
14 May 2008 14:07 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
| rpk wrote: |
do tej pory wszystko latało. |
No czytaj loga. Nie masz resta i "patcha".
Przeflashuj na wersje softu do ktorej masz i machnij albo zaistaluj setoola w wersji 28 i zrob po staremu.
| Back to top |
Google
14 May 2008 14:07 |
| Back to top |
discusall Poziom 18
#9
15 May 2008 12:35 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Witam mam najnowsza wersje setoola i nie moge nigdzie znalez rest do z310i jak by ktoś poratował był bym wdzięczny.
| Back to top |
dziekanone Poziom 21
#10
15 May 2008 12:50 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Pod jaki soft chcesz resta?;> Pozatym najnowsza instalka sama robi resty (automatycznie).
| Back to top |
discusall Poziom 18
#11
15 May 2008 13:09 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Obojentnie bo locka chce zrobic a u mnie nie robi automatycznie resta moze cos trzeba zaznaczyc?.
Model:Z310i
Brand:Generic
MAPP CXC article: R1KF001 prgCXC1250790_VODAFONE_AL
MAPP CXC version: R1KF001
Language Package:CENT_EUROPE
CDA article: CDA12345678/123
CDA version: R2A
Default article: cxc1250595
Default version: R1KF001
PROVIDER: 000-00
Network LOCKED
"R1KF001_CXC1250790_VODAFONE_AL"
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
| Back to top |
#12
15 May 2008 13:33 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Jak masz 031 to robisz bez resta sam w miedzy czasie zrobi go. ;)
| Back to top |
discusall Poziom 18
#13
15 May 2008 13:47 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
ok probuje.
Zrobiłem tak jak mówiłeś i telefon dead :(. Nadal potrzebuje resta.
A telefon robie jako z310i czy jako W200i bo też słyszałem ze tak mam robić.
| Back to top |
#14
15 May 2008 14:13 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Nie wiem jak to zrobiłeś no ale łap (30s. szukałem):
Jako Z310!!
| Description: |
 Download |
| Filename: |
r1kf001_cxc1250790_vodafone_al.rar |
| Contents: |
r1kf001_...fone_al
See all... |
| Filesize: |
362.69 KB |
| Punkty: |
0 |
| Back to top |
Google
15 May 2008 14:13 |
| Back to top |
wanek Poziom 17
#15
15 May 2008 14:27 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Witam mam pytanie zastało mi trochę logów na suporcie ale nie mogę znaleźć serwera pisze ze zamknięty a 2 są otwarte i uzywałem196 ale teraz go niema i daje ten pierwszy i nic co mam teraz zrobić.
jak by ktoś nie widział co i jak to tu jest opis wchodzisz w setool 2 ustaw kon i zmieniasz na takie ustawienia jak tu pierwsze dwie linijki w zależności jaki miałeś serwer
http://www.mobile-files.com/forum/showpost.php?p=376942&postcount=9
| Back to top |
Deny81 Poziom 19
#16
16 May 2008 10:14 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
panowie. prosił bym aby ktoś wrzucił zrzut ekranu z ustawień pliku "ini" gdzie były te zmiany dokonane ponieważ jakoś mi to nie idzie i zostałem bez dostępu do logów...
| Back to top |
wanek Poziom 17
#17
16 May 2008 10:23 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
kolego chyba prościej niż napisałem wyże sie nie da w setolu masz setool2 ustawienia konfiguracyjne i pierwsze dwie linijki zmieniasz na taki które podałem w linku w zależności jakiego serwera używasz.
| Back to top |
tooomek2 Poziom 15
#18
16 May 2008 17:52 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
panowie , jest to nowa metoda i może jeszcze być niedopracowana, plus w tym że softu się nie instaluje więc bez problemu póki co można używać dwóch wersji jeśli ktoś nie radzi sobie z najnowsza, ja za pierwszym razem też uwaliłem k550i i postawiłem ja starą wersja
| Back to top |
Rusłan Poziom 16
| Back to top |
| Back to top |
newchief Poziom 21
#21
17 May 2008 19:32 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Witam, do tej pory używałem Cruisera, setoola zakupiłem, te resty jak to mowicie mozna pobrac z supportu i sa niezbedne do zrobienia locków patchem dobrze kminie? A w380 pnx ten nowy tez da rade zrobic setoolem by patch ?
| Back to top |
Dexter23pl Poziom 21
#22
18 May 2008 09:18 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
A czy platformę PNX z serji np W910 z cid52 też da się zrobić po paczu za free? Bo juz się z tym pogubiłem...
| Back to top |
Artech Poziom 24
#23
18 May 2008 11:17 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
| Dexter23pl wrote: |
| A czy platformę PNX z serji np W910 z cid52 też da się zrobić po paczu za free? Bo juz się z tym pogubiłem... |
Wszystko oprócz A2.:)
| Back to top |
IMEX Poziom 17
#24
19 May 2008 10:02 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Pomocy - szukam opisu jak zrobić unlock i polak K850 Cid52
| Back to top |
onrad18 Poziom 19
#25
19 May 2008 10:19 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
polaka sie da ale unlock tylko po logach opis jak wgrac polaka znajdziesz na pewno na elektrodzie tylko troche poszukaj
| Back to top |
| Back to top |
#27
19 May 2008 11:33 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
jeszcze jedno pytanie co do nowego setool-a; czy wszystkie telefony w zakładce A2 jak np W910 to jedynie unlock po logach?
| Back to top |
Google
19 May 2008 11:33 |
| Back to top |
leon.euro Poziom 22
#28
19 May 2008 11:50 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
| Dexter23pl wrote: |
| jeszcze jedno pytanie co do nowego setool-a; czy wszystkie telefony w zakładce A2 jak np W910 to jedynie unlock po logach? |
wszystkie a2 po logach analogicznie wszystkie na liście w zakładce a2
| Back to top |
heniek3 Poziom 17
Joined: 08 May 2004 Posts: 382 Location: Cyców.lubelskie
#29
20 May 2008 06:34 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
v0.914033- added FREE STANDALONE new alternative bypass method
for db201x cid50/cid51, pnx5230 cid49/cid51, db2020 cid49/cid51.
you DO NOT NEED logs for them anymore.
PLEASE CHECK FAQ for important instructions.
- added all latest bypass packages
Rapidshare link
http://rapidshare.com/files/116186330/v0.914029_to_v0.914033.exe
| Back to top |
#30
20 May 2008 09:32 Re: Setool - unlock i flash Sony Ericsson, LG, Sharp |
Standardowo wrzucilem v0.914033 tylko do rozpakowania bez kompletu plikow rest
| Code: |
| http://rapidshare.com/files/116220188/v0.914033.zip |
| Back to top |
