k800i mryga na czerwono dioda
Mnemic 15 Maj 2008 09:55 3736 20
  • #1 15 Maj 2008 09:55
    Mnemic
    v0.914028/UNI
    CARD SERIAL: 000
    Loaded 51 flash descriptors
    SIGNED MODE (USING SERVER).
    ALTERNATIVE SECURITY BYPASS ENABLED.
    ChipID:9900,EMP protocol:0301
    BOOTROM MODE DETECTED
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:3 CERT:N/A
    FLASH CID:52 COLOR:RED
    Can't read SCRC unit
    Elapsed: 11 secs.
    BOOTROM MODE DETECTED.
    Speed:921600
    OTP LOCKED:1 CID:49 PAF:1 IMEI:xx342 CERT:N/A
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:2019
    Flash props sent ok
    writing D:\soft !!!!\Sony Ericsson\k800i\R8BF003_1250210_GENERIC_WI.ssw
    CURRENT FLASH FILE CID:52
    SSW uses complete hash, hash len is:9200
    Will flash 460 blocks...
    SSW loading returns:0
    writing D:\soft !!!!\Sony Ericsson\k800i\R8BF003_FS_CENT_EUROPE_WI_RED_CID52.ssw
    SSW uses complete hash, hash len is:4580
    Will flash 229 blocks...
    LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed: 399 secs.
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxx CERT:N/A
    Elapsed: 12 secs.
    telefon się nie uruchamia, mryga tylko czerwona dioda 6 razy, telefon działał, została w nim wyciągnięta zbyt szybko bateria ( zanim się wyłączył) upgrade erom zrobion przez kulankendi. Bootuje się tylko przez 2+5, jak widać soft się wgrywa ale tele nie odpala?
  • #2 15 Maj 2008 10:28
    dziuba
    Rozkręć telefon i zewrzyj bateryjkę na płycie, w moim przypadku z k800 pomogło.
  • #3 15 Maj 2008 10:30
    Mnemic
    ale po co skoro telefon się bootuje ?
    która bateryjkę i jak to zrobić bo nie próbowalem nigdy :)
  • #4 15 Maj 2008 10:40
    dziuba
    Po co to niewiem, mi pomoglo z jednym topornym K800
    Mala bateryjka przylutowana na plycie, pod plytka klawiatury. Zrob zwarcie srubokretem
  • #5 15 Maj 2008 10:41
    dziekanone
    Poziom 29  
    Zwarcie na bateryjce robi się jak nie ma komunikacji.
  • #6 15 Maj 2008 10:46
    dziuba
    tez mi sie wydawalo ze tylko przy braku komunikacji.
    W tym jednym przypadku jak juz niemialem innych pomyslow na postawienie telefonu zrobilem jako ciekawostke i pomoglo.
  • #7 15 Maj 2008 11:04
    Dexter23pl
    Podłącz pod setool i zrób RECOWERY i po problemie.
  • #8 15 Maj 2008 11:24
    dziekanone
    Poziom 29  
    Recovery przy CID52?
  • #9 15 Maj 2008 11:46
    PITER.99
    czasami pomaga przegzanie ukladu N2000
  • #10 15 Maj 2008 14:23
    newchief
    Cruiser->Repair EROM i bedzie smigac
  • #11 15 Maj 2008 17:59
    Mnemic
    Recovery robiłem już wcześniej i oczywiście upgradowało się ok, ale to nie pomogło. Upgrade kulankendi do tego full flash setoolem i dopiero flash patch, telefonik chodzi bez problemów :)
    CID się nie zmienił i pozostał 52 :)
  • #12 31 Lip 2008 15:01
    zarek1988
    ja miałem podobny problem z moim se i wystarczyło mi zewrzeć bateryjkę i ruszyło:)pozdrawiam
  • #13 31 Lip 2008 16:27
    pit08
    Na takie rzeczy pomaga upgrade eromu przez kulankendi, to tak dla potomnych.
  • #14 04 Sie 2008 10:27
    Usunięty
  • #15 04 Sie 2008 11:09
    PITER.99
    Raczej darmówką Ci to nie pójdzie. Musisz iść do kogoś, kto ma box.Możesz spróbować jeszcze xs++.
  • #16 04 Sie 2008 14:05
    Usunięty
  • #17 19 Sie 2008 23:00
    Usunięty
  • #18 04 Wrz 2008 15:44
    Venom_84
    mam to samo zwarcie bateryjki nie pomaga. czy wie ktoś jak to zrobić Setoolem albo MT SE ????
    pozdrawiam.
  • #19 04 Wrz 2008 19:28
    mar1aczi
    Spróbuj podmienić baterię na inną.
    SeTool'em zrób fullflash'a. Ja tak miałem jak coś się spartoliło z GDFSem. Pełny reflash pomógł.
  • #21 07 Wrz 2008 09:54
    bestkom
    Na takie rzeczy to najbardziej pomaga naprawa po testpointach dreamboxem.
 Szukaj w ofercie
