Resetowanie sie nowego komputera
TOMEEK88 16 Paź 2008 19:05 1536 16
  • #1 16 Paź 2008 19:05
    TOMEEK88
    Witam otóż mam pewien problem złożyłem sobie nowy komputer jednak po zainstalowaniu Windowsa pojawiają się resety podczas normalnej pracy komputera, sprawdzałem już pamięci, zasilacz i te części są dobre.
    Zrobiłem zrzut błedu z minidump proszę o pomoc.
    Microsoft (R) Windows Debugger Version 6.6.0003.5
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\WINDOWS\Minidump\Mini091708-02.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: *** Invalid ***
    * Symbol loading may be unreliable without a symbol search path. *
    * Use .symfix to have the debugger choose a symbol path. *
    * After setting your symbol path, use .reload to refresh symbol locations. *
    Executable search path is:
    * Symbols can not be loaded because symbol path is not initialized. *
    * The Symbol Path can be set by: *
    * using the _NT_SYMBOL_PATH environment variable. *
    * using the -y <symbol_path> argument when starting the debugger. *
    * using .sympath and .sympath+ *
    Unable to load image ntoskrnl.exe, Win32 error 2
    *** WARNING: Unable to verify timestamp for ntoskrnl.exe
    *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
    Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
    Debug session time: Wed Sep 17 19:35:41.093 2008 (GMT+2)
    System Uptime: 0 days 0:01:03.812
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    Unable to load image nv4_disp.dll, Win32 error 2
    *** WARNING: Unable to verify timestamp for nv4_disp.dll
    *** ERROR: Module load completed but symbols could not be loaded for nv4_disp.dll
    * Bugcheck Analysis *
    Use !analyze -v to get detailed debugging information.
    BugCheck 1000007E, {c000001d, bfbd804f, baec3b88, baec3884}
    ***** Kernel symbols are WRONG. Please fix symbols to do analysis.
    *** Your debugger is not using the correct symbols ***
    *** In order for this command to work properly, your symbol path ***
    *** must point to .pdb files that have full type information. ***
    *** Certain .pdb files (such as the public OS symbols) do not ***
    *** contain the required information. Contact the group that ***
    *** provided you with these symbols if you need this command to ***
    *** work. ***
    *** Type referenced: nt!_KPRCB ***
    Probably caused by : hardware ( nv4_disp+20504f )
    Followup: MachineOwner
  • #2 16 Paź 2008 20:09
    tronic1
    Spec od komputerów
    Podaj całą konfigurację z danymi zasilacza włącznie.
  • #3 16 Paź 2008 20:49
    TOMEEK88
    Core 2 Duo E6750 2,66GHz
    Płyta główna GIGABYTE GA-P35-DS3L S755
    Grafika GIGABYTE 9600GT SILENTPIPE
    Pentagram freezone karakorum HP-120
    Zasilacz 4MAX YESICO SILENTCOOL SC-560W
    Dysk 500GB Seagate
    Zasilacz to porządny sprzęt więc od niego nie powinno być problemów.
    Moderowany przez K!lleR:
    10.9 pisanie z użyciem slangu młodzieżowego (branżowego), notoryczne popełnianie błędów ortograficznych, pisanie z użyciem przycisku "Caps Lock"
  • #4 16 Paź 2008 21:18
    tronic1
    Spec od komputerów
    Masz zainstalowane najnowsze sterowniki do k.graficznej ? Sprawdzałeś temperaturę k.graficznej ? Dodatkowe zasilanie podpięte ? Na próbę zamocuj dodatkowy wentylator tak żeby dmuchał na grafikę.
  • #5 16 Paź 2008 21:24
    whats_upp
    Dodaj jeszcze symbole do Debugger-a i jeszcze raz analizę tego samego zrzutu, zobaczymy co dalej wyskoczy.
    Ale mi to wygląda na problem z grafiką.
  • #6 16 Paź 2008 21:59
    TOMEEK88
    Sterowniki ściągałem najnowsze temp. karty jest w normie nawet sprawdzałem ją u kolegi.
  • #7 18 Paź 2008 15:29
    TOMEEK88
    Na problem z Prockiem to mi nie wygląda testowałem go pod SUPER PI i jakos resetów nie było wiec co to może być płyta główna??
  • #9 02 Lis 2008 12:31
    TOMEEK88
    Wczoraj wyskoczył mi nowy bład "System NVIDIA System Sentinel zgłasza, że moc przekazywana do karty graficznej z układem NVIDIA nie jest wystarczająca. ...i już nie wiem czy to wina karty czy płyty co radzicie?
  • #10 02 Lis 2008 12:33
    jankolo
    Dwa tygodnie temu zadano koledze pytanie, na które nie uzyskaliśmy odpowiedzi:
  • #11 02 Lis 2008 12:40
    burgman_85
    A czy ta płyta ma zintegrowana kartę graficzna ??
  • #12 02 Lis 2008 13:50
    TOMEEK88
    Zasilanie podpięte a płyta nie ma zintegrowanej karty graficznej.
  • #13 05 Lis 2008 01:11
    michaellopl
    Pomimo tego iz zasilacz jest porzadny, proponuje sprawdzic na innym o duzej mocy.
  • #14 05 Lis 2008 10:29
    abic
    Witam wrzuć sobie płyte z knopixem lub inną wersją bootowalną i pobaw sie troszke i sprawdź czy pod linuxem też ci się resetuje jesli tak to wina windy odpada , później odłącz dysk i inne urządzenia peryferyjne i sprawdzaj może trafisz na coś co się gryzie :).
    PS.
    Moze to kości ram ja tak kiedyś miałem, ze zaraz po starcie komputer mi sie resetował jak dołożyłem sobie ramu.
  • #15 10 Lis 2008 12:33
    TOMEEK88
    Zauważyłem jeszcze coś gdy podłączyłem drugi dysk przy kopiowaniu danych występują częściej właśnie te resety.
    Karta graf. sprawna ,pamięci ram tez, procesor tez był testowany w super PI. Może to być dysk?
  • #16 11 Lis 2008 12:16
    TOMEEK88
    Jeżeli mowa o wtyczkach dodatkowe zasilanie mam podłączone do karty 6-pinowa wtyczka nie 4 poniewaz do zasilacza takiej nie dostałem ale to chyba nie powinno mieć wpływu?
  • #17 11 Lis 2008 12:31
    iron64
    Spec Overclocking
    Do karty graficznej podpiąłeś 4 pinową wtyczkę?
 Szukaj w ofercie
