ASMAX BR-604G jak zmienić/naprawic firmware??
J_Bravo 19 Gru 2008 16:03
  • #1 19 Gru 2008 16:03
    J_Bravo
    Kilka dni temu padł mi ruter BR-604G. Non stop sie restartuje.
    Podpiąłem sie przez kabel RS do terminala i wyskakuje w kółko ten oto log:
    Code:
    UART1 output test ok
    Uart init
    mfid=000000c2 devid=00002249
    Found 1 x 2M flash memory
    ---RealTek(RTL8186)at 2006.03.28-04:42+0800 version 1.4a [32bit](180MHz)
    no sys signature at 00010000!
    no sys signature at 00020000!
    Jump to image start=0x80800000...
    decompressing kernel:
    Uncompressing Linux... done, booting the kernel.
    done decompressing kernel.
    early printk enabled
    Determined physical RAM map:
     memory: 01000000 @ 00000000 (usable)
    Initial ramdisk at: 0x801d6000 (5529600 bytes)
    On node 0 totalpages: 4096
    zone(0): 4096 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: root=/dev/ram console=0 ramdisk_start=0 single
    Calibrating delay loop... 178.99 BogoMIPS
    Memory: 8660k/16384k available (1658k kernel code, 7724k reserved, 5552k data, 52k init, 0k highmem)
    Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
    check_wait... unavailable.
    POSIX conformance testing by UNIFIX
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    Serial driver version 6.02 (2003-03-12) with no serial options enabled
    ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
    state->flags=00000000
    Realtek GPIO Driver for Flash Reload Default
    block: 64 slots per queue, batch=16
    RAMDISK driver initialized: 16 RAM disks of 7000K size 1024 blocksize
    PPP generic driver version 2.4.1
    PPP MPPE Compression module registered
    RealTek E-Flash System Driver. (C) 2002 RealTek Corp.
    Found 1 x 2M Byte MXIC MX29LV160AB at 0xbe000000
    RTL8185 driver version 1.11 (2006-06-19)
    8186NIC Ethernet driver v0.0.5 (Mar 3, 2006)
    eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
    eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
    fast_nat v1.3b
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 1024 bind 2048)
    rtl8186_crypto_init()...
    rtl8186_crypto: IPSec status(RTL8186_IPSCFR) = B
    rtl8186_crypto: IPSec status(RTL8186_IPSCTR) = 2027202
    ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0
    ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0
    ipsec_md5_init(alg_type=14 alg_id=2 name=md5): ret=0
    ipsec_null_init(alg_type=15 alg_id=11 name=null): ret=0
    ipsec_sha1_init(alg_type=14 alg_id=3 name=sha1): ret=0
    ip_conntrack version 2.1 (128 buckets, 1024 max) - 312 bytes per conntrack
    PPTP netfilter connection tracking: registered
    PPTP netfilter NAT helper: registered
    ip_tables: (C) 2000-2002 Netfilter core team
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    NET4: Ethernet Bridge 008 for NET4.0
    RAMDISK: ext2 filesystem found at block 0
    RAMDISK: Loading 5400 blocks [1 disk] into ram disk... done.
    Freeing initrd memory: 5400k freed
    VFS: Mounted root (ext2 filesystem).
    Freeing unused kernel memory: 52k freed
    mount /proc file system ok!
    serial console detected.  Disabling virtual terminals.
    init started:  BusyBox v1.00-pre8 (2005.09.16-02:21+0000) multi-call binary
    BusyBox v1.00-pre8 (2005.09.16-02:21+0000) Built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    killall: pptp.sh: no process killed
    killall: pppoe.sh: no process killed
    Initialize wlan0 interface
    Setup BRIDGE interface
    killall: syslogd: no process killed
    killall: klogd: no process killed
    SIOCGIFFLAGS: No such device
    bridge br0 doesn't exist; can't delete it
    Setup bridge...
    device eth0 entered promiscuous mode
    eth0:phy is 8305
    SIOCDELRT: No such process
    device wlan0 entered promiscuous mode
    br0: port 2(wlan0) entering listening state
    br0: port 1(eth0) entering listening state
    br0: port 2(wlan0) entering learning state
    br0: port 2(wlan0) entering forwarding state
    br0: topology change detected, propagating
    br0: port 1(eth0) entering learning state
    br0: port 1(eth0) entering forwarding state
    Setup WAN interface
    eth1:phy is 8305
    start DNS Relay Daemon
    Setup Firewall
    IEEE 802auth uses obsolete (PF_INET,SOCK_PACKET)
    .1x (WPA) daemon, version 1.7
    I w tym momencie następuje restart i zaczyna sie wszystko od nowa.
    Gdy podczas włączania routera wcisne klawisz RESET wyskakuje:
    Code:
    Uart init
    ---Escape booting by user
    ----------------- COMMAND MODE HELP ------------------
    HELP (?)                : Print this help message
    D <Address> <Len>
    EW <Address> <Value1> <Value2>...
    EH <Address> <Value1> <Value2>...
    EB <Address> <Value1> <Value2>...
    EC <Address> <Value1> <Length>...
    CMP: CMP <dst><src><length>
    IPCONFIG:<TargetAddress>
    J: Jump to <TargetAddress>
    FLW: FLW <dst><src><length>
    FLR: FLR <dst><src><length>
    LOADADDR: <Load Address>
    AUTOBURN: 0/1
    Czy ktoś wie jak można wgrać nowy firmware??
    Ruter nie opdowiada na ping 192.168.2.1 przez 10s co minute .... tak jakby sie ciagle restartowal ...
    strona 192.168.2.1 nie działa ....
  • #2 21 Gru 2008 03:51
    soltys_w
    Mając kabel szregowy dziwi mnie, że jeszcze tego nie zrobiłeś - bylo wielokrotnie opisywane na forum,także przeze mnie... Ale do rzeczy.
    Zainstaluj PumpKin'a. Po przerwaniu boot'owania routera ustaw mu adres IP poleceniem IPCONFIG [adres ip. dowolny], zmień IP karty sieciowej, tak aby była w jednej podsieci z routerem. Z PumpKin'a wyślij firmware na IP AP. Po przuceniu softu do pamięci routera wyświetli Ci się komunikat pod jakim adresem znajduje się początek oraz jaka jest długość pliku. Wydaj polecenie FLW 30000 [adres początkowy] [długość pliku]. Po poprawnym flashowaniu odłącz zasilanie, odczekaj chwilę, podłącz ponownie i sprawdź jak będzie zachowywał się router. Jeśli ponownie nie wystartuje, to zakładjąc, że wrzuciłeś poprawny firmware, pewnie będzie uszkodzona pamięć RAM / flash / procesor
  • #3 22 Gru 2008 18:27
    J_Bravo
    Tak wiem ... wgrywałem nowy firmware i ciągle to samo .... restart za restartem ...
    Ruszyło na innym firmware od innego producenta ....ciekawa sprawa ;)
  Szukaj w 4mln produktów
Przeglądaj produkty
