| Author |
Message
i-punkt Poziom 20
#91
23 Apr 2010 11:11 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Nowa aktualizacja :)
Cyclone MAJOR Update - New FBUS Protocol (X3,X6) - DCT4RSA(1661,5030) - COM Emulator
Hello, New Cyclone Box Installer is READY.
What's new?
Installer v1.05
23.04.2010
- Added support for NEW Nokia BB5 FBUS CMT Loaders (flashing new phones E52 ST Chip, X3, X6, 5530, etc, etc), supported RAPU,RAPIDO,RAPv4 phones,etc. You can flash your phone using New Protocol, but also manage Reading/Writing Certificates,etc.
- Added support for BB5 FBUS New Protocol APE Loaders
- Added support for Unlock / Relock / Autolock DCT4 RSA Based phones (1661, 5030, 1202, and generally ALL ASIC 11 phones), without patch. Solution is standalone and to unlock one phone takes no longer than 2 seconds.
- Added CS Repair due to Bad Simlock in ASIC11 phones (no patch)
- Latest Nokia Loaders 2010 Introduced (including upgraded RAPv3 old prot algo 9.50)
- Added SD Repair, RPL Calc, etc for RAP3v2 phones (hash E9EFF4BFAA5393217CA6B17755FC3E14)
- Added SIMLOCK BACKUP for SL3 phones (can be restored even after fullerase)
- Added support for NCK Reading, SD Extracting, and more accurate Securtity Analysis for v30.xx phones (N96,5800,etc - so called by "mx" team "sl3" but in fact is simple sl2), previous versions gave msg about "Decryption fails"
- Added COM Emulator - now Cyclone Box can work as UNI BOX with UFS Pinout !
- Added one-click analyze / repair of Dynamic Camera Configuration (blank screen, "camera not ready",etc) based phones (DCT4plus, 5310, 7210, 5220, 6700, others) supported Camera Drivers:
GR0103D101260C206C02
GR0103D101260C213402
GR0103D10126095A1F05
GR0103D10126095A1F07
GR0103D10126095A1F87
GR0103D1012601022C00
GR0103D1012601022E05
GR09733814140C206C02
GR0973381414095A1F05
GR0973381414095A1F07
GR0973381414095A1F87
GR097338141401022C00
ISL2TI020000093E2F30
NI00IIIIRR030C20C607
NI00IIIIRR03095B1F00
NI00IIIIRR03095B1F01
NI00IIIIRR030102F200
NI00IIIIRR030102F201
NI00IIIIRR030102F202
NI00IIIIRR030102F203
NI00IIIIRR0301035420
NIMMIIIIRRFF0A021001
NIMMIIIIRRFF094B2F01
NIMMIIIIRRFF06150018
NIMMIIIIRRFF06150110
ST090404003C06150018
ST090404004C06150018
- Added TX2 warning when certificate is being not accepted (common problem while writing RPL)
- Updated Nokia USB Connectivity Drivers to 7.1.22.0
- Upon installation, StoredFiles permission is now set to full to avoid Permission problems (and software is still safe for trojans/etc)
- Folder "StoredFiles" is no longer marked to Delete upon Uninstallation to keep old backup files
- Rewritten BB5 RPL Backup routine, now Certificates are being backed-up first, so even if phone is DEAD, still certs will be backed-up
- Factory defaults after flash are now defaultly ticket (BB5,DCT4)
- Mode transition manager added in firmware v01.37
- Software accept Mode Transision to "Normal" when phone goes to "Power Off"
- Flash Variants are displayed now in descending order
- SL Array readen now upon RPL Backup is Keyb/FBUS Count masked
- Now, all 7 codes are being sent to phone (some phones don't accept +7 codes - tested on N71)
- Fixed NCK Calculation for some mobiles (Security Section Checksum Error)
- When software detects HWC/CCC/Variant certs mismatch, it tries to write local one from database
- Fixed smartcard not responding for reset in some configurations
- Fixed "Failed to Read SP Info" on older RAPv2 phones
- Path manager - bug "/" fixed
- Fixed problems with StoredFiles managing when software have no enough permissions (occurs on WinVista / Win7)
- SX4 Bypass is removed now (no need anymore)
- Improved sending CMT Secondary Loader
- Fixed TX2 test crash when phone is completly erased (TOC erased)
- Added automatic PM upload with field 1,309 after SX4 Authorization (one-click ST_SECURITY_FIX !), Supported 100+ BB5 phones in local database
- Improved Security Analysis, added HWC/CCC/Variant Certs Check
- Box Firmware : 01.0C, Access Violation Fixed
- Runtime Error when "Disable Skins" enabled fixed
- Taksbar problems fixed
- Fixed 1208 UEM Read/IMEI Rebuild
- N73 booting improved (when backing up crt, writing rpl incorrect loaders was assumed before)
- New Nokia Firmware introduced, improved stability a lot
- DCT4Plus relock fixed
- Mode transition improved
- BB5 USB Flashing fixed
- Factory Set problems fixed
- Fixed problems when dealing with RAP3v2 Phones
- Skin manager upgraded to v6.63
- HW Platform is now being readen upon Box Initialization
- Added support for CTF'2010 Platform
- Flashbus writing speed increased about 10%
- Flashbus FUR messages reading speed increased about 40%
- BB5 Booting procedure rewritten, now no problems in phones like 5800,N97,5200,etc..
- After flashing, added average writing speed display
- BootAgent removed, now Bootloader upgrade is managed by middle-loader
- Main Firmware rewritten from scratch, old bugs gone away.
- MPU Added
- Improved Oscillator startup time, box hangup fixed in some cases
- Realtime clock not used anymore, too much hardware problems when box not started
- Fixed booting dead BB5 mobiles
- If bb5 booting fails, SW displays possible reason reported by new firmware
- BB5 is being try to boot now without hardware VCC switch
- Added USB Dualport transactions (increases speed)
- Added old protocols support (tick "Use Old Protocols Loader")
- Upon finding CMT/APE loaders, it shows a find parameters (TX2 line, Requested Protocol Type, etc)
- BB5 flash_block_Data checksum fixed
- Additional flash chip information is now shown upon BB5 Alg Boot (VPP Info, Chip Size)
- Fixed boot when after activating DCT4 FTD phone comes to dead
- Fixed "Failed to decode MSID" when flashing some PPM DCT4 files
- UPP ID is now represented as hex upon Read Info
- Added detection whether Pri/Sec camera exists or is configurable
- Minor changes and bugfixes
- Black Skin introduced
- Fixed DCT4 Unlock not being executed after Flashing Procedure
- Versions snap
Installer v1.05
Main x86 Application v1.0.0.9392
x86 Memory Manager v4.92
Native USB Drivers v1.0.0.4
USB-COM Stack Drivers v1.0.0.0
Onboard Secure Bootloader v2.10
Onboard Main Nokia Application v01.37
Onboard COM Emulation Code v1.00
Onboard Security Card Revision v1.09
Nokia Connectivity Cable Drivers v7.1.22.0
BB5 USB/FPIF Single Line/FPIF DualLine v20100410
DCT4 FPIF Single Line/USB v20100410
DCT4 Unlock Patches DEPRECATED
Communication Stack SSLv3-keys-06092008
Skin Stack v6.63
Thanks to all contributors which supporting us! Thanks Moulnisky, ptt, Honey... Thanks arash & others...
Where to download?
DOWNLOAD LINK 1
DOWNLOAD LINK 2
!!CYCLONE - STOP ME IF YOU CAN!!
Best Regards,
Cyclone Team
| Back to top |
gruby89 Poziom 9
#92
05 May 2010 11:32 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Mam Cyclone Boxa.
Mam problem z połączeniem Noki n96, w której docelowo chce wgrać PL.
Gdy biore "Check Flashing BUS" mam taki odczyt:
Booting CMT...
APE_SYSTEM_ASIC_ID: 008815D3
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: B1D26EBD4D73CD5476313F02394CCBA8D10119DC
APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE_BOOT_ROM_CRC: 137A9A3B
APE_SECURE_ROM_CRC: 33259D2C
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0D50010717AE015838943EDFDDE15648F8600784
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.9.50.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
CBUS Request Error -> CBUS Response wrong header
Prepare phone failed with message -> Failed to get CMT Configuration
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Failed to disable VBAT -> CBUS reported an error
A gdy biore Read Phone Info to wiadomo:
Failed to read info -> Phone not detected
Może ktoś pomóc??
| Back to top |
arcik99 Poziom 17
#93
06 May 2010 07:33 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
probuj z adapterem, cyclon jest bardzo kaprysny. ja dokupilem specjalnie adapter pod ten box dedykowany i dopiero wtedy skonczyly sie problemy. do flesza proponuje UFS, sprawdzony i niezawodny sprzet ;)
| Back to top |
Google
06 May 2010 07:33 |
| Back to top |
kaisak Poziom 2
#94
06 May 2010 15:42 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| gruby89 wrote: |
Mam Cyclone Boxa.
Booting CMT...
CMT Ready!
Może ktoś pomóc?? |
W przypadku telefonow BB5 MUSISZ podpiac adapter (ten zolty-TX2), ten komunikat jest spowodowany wlasnie nie podlaczeniem adaptera.
W przypadku telefonow DCT4 podpinaj je BEZPOSREDNIO.
| Back to top |
gruby89 Poziom 9
#95
06 May 2010 17:40 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| arcik99 wrote: |
| probuj z adapterem, cyclon jest bardzo kaprysny. ja dokupilem specjalnie adapter pod ten box dedykowany i dopiero wtedy skonczyly sie problemy. do flesza proponuje UFS, sprawdzony i niezawodny sprzet ;) |
Mam adapter do Cyclona v 2.0 i nic nie daje.
| Quote: |
W przypadku telefonow DCT4 podpinaj je BEZPOSREDNIO. |
Tak wiem, podpinam i nic.
| Back to top |
rpk Poziom 21
#96
07 May 2010 11:13 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Cyclone jest bardzo kapryśny do zczytania telefonu podłączam bez adaptera do zgrania certyfikatów i flascha tylko z adapterem. Przy podpiętym adapterze jeszcze mi się nie udało zczytać info z żadnego aparatu. Nie ma znaczenia czy podpina się na kopytku czy na uniwersalnych kablach.
| Back to top |
rpk Poziom 21
| Back to top |
i-punkt Poziom 20
#98
11 May 2010 09:46 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Teraz niech doda jeszcze HTC , Huawei i Alcatela ;)
| Back to top |
Google
11 May 2010 09:46 |
| Back to top |
rpk Poziom 21
#99
11 Jun 2010 08:05 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Kolejna poprawka do Cyclone.
http://www.cyclonebox.com/news.php?id=46
v01.38 Nokia Firmware (2010-06-08)
v01.38 Nokia Firmware is uploaded to server. Changes: - Fixed problem when Nokia correct BB5 NCKs was calculated only for levels +1,+2,+3, codes +4,+5,+6,+7 was wrongly calculated due to memory leak of calculation routines. - Minor (or non enveloped yet ) changes and bugfixes This is server-side update only, don't ask for "exe" file because new "exe" is not released at moment, just use Maintenance Tool and upgrade your box. Every box have 3 tries of upgrading firmware, please be patient during upgrade process because it may take some time and if you will cancel it (When software will act as a "hangup") you will lose upgrade logs and will need ask us for adding another credits... Best Regards, Cyclone Team
Swoją drogą można by ten temat podpiąć na górze jak inne boxy w końcu sporo użytkowników już posiada ten sprzęcik.
| Back to top |
kawasz1982 Poziom 11
#100
22 Jun 2010 12:38 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Witam!
Podłączam kabel EF III do 2220S simlock poszedl od strzala a polaka za chiny nie mogę wrzucić;/ probowalem dwie wersje i ciagle nic.
Processing Flash Image Failed -> UPP Not Responding
Failed to Flash -> Problem with processing MCU Image file
| Back to top |
Google
22 Jun 2010 12:38 |
| Back to top |
arcik99 Poziom 17
#101
22 Jun 2010 21:17 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
cyclone do flesza jest slaby, sprobuj innym boxem, proponuje ufs lub jaf
| Back to top |
prilo Poziom 13
#102
22 Jun 2010 22:12 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Panowie a jak wygląda porównanie ATF do Cycka??Bo chce cos dokupic wlasnie do Nokii i zastanawiam sie nad Cyclonem lub ATF.
| Back to top |
fischer8 Poziom 24
Joined: 27 Mar 2003 Posts: 5753 Location: Oława--Grodków
#103
22 Jun 2010 22:16 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
ATF jest najlepszy w flashowaniu, cyclone nie mam także się nie wypowiem.
| Back to top |
rpk Poziom 21
#104
03 Aug 2010 12:11 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
To się Cyclone postarał SL3 już robi co prawda po logach ale zawsze kolejna opcja.
| Back to top |
jAZZ-MAN Poziom 4
#105
10 Nov 2010 11:22 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Witam...
Mam mały problem, instaluję soft do telefonów dct4, włączam oprogramowanie Cyclone, podłączam telefon, sczytuję z niego informacje, przechodzę do zakłądki flashowania,rozwijam zakładkę PRODUCT i
| Code: |
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 6 products, Filtering DCT4 Products - wait...
0 Products left after filtering. Ready. |
Flashe pobrałem z suportu Cyclone i instalowałem dla konkretnych RM'ów.
Proszę o pomoc
| Back to top |
#106
07 Dec 2010 20:53 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Cyclone Box Installer v1.10 FBUS2USB, TurboCache, Infineon XGold Imei, Loaders & more (2010-12-07)
CYCLONE TEAM
proudly presents
What's new?
- Infineon XGold IMEI Backup/Restore added (First in the world)
- New BB5 FBUS/USB Loaders v10.34.1 introduced
- BB5 USB Flashing module rewritten, supports new Flashing Type: FUR USB
- using FBUS loaders on USB. Is possible now to do also RPL write, Cert's read/write/erase, using just USB cable. Full FBUS protocol emulation over USB supported!
- FBUS2USB RAPU Support
- FBUS2USB RAP4 Support
- FBUS2USB Broadcomm Support
- Broadcomm platform flashing added (Nokia X2,....)
- 6700,E52 and other RAPunistore Booting fixed (Wrong First Char Received)
- SL3 Simlock RPL Write Introduced
- DCT4/BB5 Flash TurboCache added, increasing flashing speed a bit
- The Profile Bits is now analyzed before SL3 Unlock (it will not submit job if phone have blocked NCK unlocking
- i.e. Telcel Mexico units)
- New NCK unlocking method for SL2 phones introduced (with latest MCU SW versions)
- Added Autologging (operation logs are stored in StoredFiles)
- Added USB Full RPL Backup (NPC,CCC,HWC,Simlock,WMDRM,etc)
- Added StatusBar in Nokia Tool, displaying current Task/Mobile attached
- DCC Camera Repair added for module NI00BC0000030102F201
- DCC Camera Repair added for module ISL3TI0200000C000002
- DCC Camera Repair added for module IS00TI0200000C208A03
- DCC Camera Repair added for module IS00TI02000001022B04
- DCC Camera Repair added for module 86000300010401022B04
- DCC Camera Repair added for module 8600030001040C208A03
- DCC Camera Repair added for module 86L10300010406260004
- DCC Camera Repair added for module 86L10300010406260000
- DCC Camera Repair added for module 86L103000104094C1003
- Refactorized GUI thread problems
- Improved stability of Blackberry calculator
- Improved flashing speed with Skins Enabled
- Added detailed Action Statusbar
- Added CBUS StatusBar, indicates "---->" on USB Transmit, "<----" on USB Receive, Idle and Errors
- Support area is rebuilt
- file list parsing is optimized
- "Connection Closed Gracefully" in Support Area fixed
- Connection recovery in SupportArea added
- Fixed "Floating Point Divison by zero" in Support Area
- Entered NCK codes are now backed-up too upon Simlock Backup
- New progressbar introduced in Nokia Tool gui
- Improved USB SwitchToRaw
- Improved ADL Server Pooling
- Improved USB Phone Pooling
- USB BootRom detect routine rebuilt
- Fixed "Access Violation" while application exit
- Fixed Registration Tool bug when "Submit" button is not shown after Box Prepare
- Fixed bug when software after minimizing to tray don't appears at taskbar
- Added "KB Left", "Time Left", "Current Speed" real-time information while downloading files from support
- The Germany Server is now default Support Server
- Added support for Box HW Revisions B, thus is A11F, B110, B111 and B112, and other B11x
- Old "INI" File Parser Module added (for Old DCT4 phones)
- Old "INI" File parser Module added (for Old BB5 phones)
- Added support for 6630,6680,N70 ini parser (DPConverted v1-v2 VPL files)
- The product name is now resolved at Product List (i.e. RM-1 (6630))
- Auto-select flashfiles added (selects product and variants on Read Phone)
- The new method of BB5 NCK Calculation is now the default Unlock Method for BB5 mobiles. For SL3 use SL3 Online Code Calculation.
- "Abort" button added, this terminating all threads (during flash, erase, unlock, whatever)
- Skin Manager updated to v7.02, much stable and faster
- Fixed box hangup problem when PC goes to sleep mode
- During SL3 Check/Submit job, phone is readen first, then server transaction starts (to not overload server resources)
- Failed to Process Initial Challenge (2) during Bootloader Upgrade fixed
- During SL3 Submit Job software now try first to read PM 120 and detect if phone is SL3
- Small changes regarding SL3 Submit Job
- should work bit smoother right now with bad cables
- Updated message about SL3 Credit consumption
- Added bigger delay between entering NCK codes (bruteforce protection)
- Fixed "Canvas does not allow drawing" while SL3 Manual Mode
- Cyclone Secure Bootloader v2.13 Released
- Cyclone Main Firmware v01.49 Released
- Cyclone Calculator v1.00 added into installer
- Cyclone USB Drivers Updated to 1.0.0.5
- Connectivity Cable drivers updated to 7.1.34.0
| Back to top |
arcik99 Poziom 17
#107
26 Dec 2010 20:32 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
CycloneBox FREE and STANDALONE SL3 Unlock RELEASED!!! (2010-12-25)
Hi,
Small manual how-it-works:
1. Read SL3 Log file (BB5, Simlock Tabs, Group "Local SL3 Bruteforce", Button Read LOG File)
2. Save the readen Log File somewhere. It contains necessary informations needed to calculate code.
3. Use "log2cod Calculator" to calculate COD file. Processing speed depends on GPU installed at your PC. log2cod calculator supports calculation resume (on power-off fail, etc).
4. Once COD file is ready, use "Send COD File to Server" button to Submit Calculation Result to our server for further processing
5. You can unlock your phone now as it would be unlocked by our servers (Select SL3 Online RPL Calculation method, and press Direct Unlock), you may also use Manual Mode if phone is away.
Download Link: http://www.karwos.hk/CycloneSL3_Standalone.rar
Br
CycloneBox Team
moze w koncu ktos podczepi ten temat? zasluguje na to :)
| Back to top |
leofeo Poziom 14
#108
27 Dec 2010 01:13 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Raczej nie dokąd nie będzie jasne czy to działa czy nie.
Wpierw trzeba zakupić komputer za ok. 6000zł.
| Back to top |
mobista Poziom 22
Joined: 28 Oct 2008 Posts: 2210 Location: Bytom/Chorzów
#109
27 Dec 2010 12:34 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| arcik99 wrote: |
Hi,
Br
CycloneBox Team
moze w koncu ktos podczepi ten temat? zasluguje na to :) |
Jak wygląda opcja kalkulacji RPL na serwerze Cyclone?
| Back to top |
Stokłosy Poziom 23
Joined: 28 Mar 2006 Posts: 3777 Location: polska/europa
#110
27 Dec 2010 15:41 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Po przeliczeniu pliku COD, który ''przeliczył'' twoj komputer z najlepsza karta graficzna na rynku np. za 2000pln albo dwoma - 4000pln za same karty - uzywasz ''Send COD File to Server'' - aby tam zrobiono koncowe przeliczenie, potem odblokowujesz telefon poprzez ''SL3 Online RPL Calculation method'' lub po prostu ''Direct Unlock''.....
Jezeli chodzi Ci o te finalne przeliczenie przez serwer cyclone - to powinno byc szybko..... za to COD na twoim kompie moze potrwac....
| Back to top |
cykada Poziom 20
#111
27 Dec 2010 19:15 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
No nie wiem, czy temat na to zasługuje, Karwos bana dostał na 7 dni, za tę właśnie nieprawdziwą solucję ...
| Back to top |
Stokłosy Poziom 23
#112
27 Dec 2010 19:49 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Troche nieładnie ze strony producenta - dawac info ze dziala a tu zonk - tymbardziej ze bez drogiej jednostki komputera nie ma jak sprawdzic tej solucji, moze ja poprawia i na dniach bedzie wszystko ok....
| Back to top |
TxT Poziom 19
Joined: 05 Jan 2003 Posts: 750 Location: podkarpackie -krosno -jasło -rzeszów
#113
28 Dec 2010 00:54 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| cykada wrote: |
| No nie wiem, czy temat na to zasługuje, Karwos bana dostał na 7 dni, za tę właśnie nieprawdziwą solucję ... |
kolego nie za "nieprawdziwa solucje" tylko za spam w newsach
| Back to top |
zenekrtv Poziom 18
#114
28 Dec 2010 04:12 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Panowie jakie grabie grabią od siebie jest sprzedający i kupujący a co najważniejsze to że my to kupujemy i potem każdy ma żale
| Back to top |
cykada Poziom 20
#115
28 Dec 2010 10:01 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| TxT wrote: |
| cykada wrote: |
kolego nie za "nieprawdziwa solucje" tylko za spam w newsach |
karwos & XcachorroX ---> 7 days ... Fake Update in news section
as title say ...
Karwos & XcachorroX banned for 7 days..
http://forum.gsmhosting.com/vbb/f188/karwos-xcachorrox-7-days-fake-update-news-section-1171844/
ślepy jestem, czy co ?
| Back to top |
TxT Poziom 19
#116
28 Dec 2010 12:02 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
nazwalbym to inaczej, ale nie o to tu chodzi.
interpretacja nalezy do interpretujacego.
7 dni za spam w newsach, czyli chodzi o posty w newsach o update ktory dopiero bedzie tzw twoja "nieprawdziwa solucja" wg twojej interpretacji, w mojej fake update to nieprawdziwa aktualizacja. na chwile obecna i w chwili pisania przez Ciebie posta aktualizacja wydana przez Karwosa byla jak najbardziej Prawdziwa, a Ty dalej swoje ze nie dziala.
| Back to top |
mobista Poziom 22
#117
28 Dec 2010 12:22 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
Prawdziwa czy nie prawdziwa - co za różnica w sytuacji, gdzie ta solucja jest nieekonomiczna? Na tą chwilę nie zainwestuję w "pudło" 6 patyków (poza tym wartość części spadnie do ~4,5 w ciągu 6 miesięcy) i podniesienie rachunków za prąd czekając aż mi się zwróci sam sprzęt (liczmy ~100 telefonów). Dobrą ideą byłoby postawienie serwera SL3, ale z drugiej strony ile brać za unlock pojedynczej sztuki od osób kupujących konto np. na 10 telefonów? Skoro każdy będzie twierdził, że ma MX-Keya i przy radku 4650 będzie liczył sobie kod przez 2 miesiące :]?
| Back to top |
TxT Poziom 19
#118
28 Dec 2010 12:31 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| mobista wrote: |
| Prawdziwa czy nie prawdziwa - co za różnica w sytuacji, gdzie ta solucja jest nieekonomiczna? Na tą chwilę nie zainwestuję w "pudło" 6 patyków (poza tym wartość części spadnie do ~4,5 w ciągu 6 miesięcy) i podniesienie rachunków za prąd czekając aż mi się zwróci sam sprzęt (liczmy ~100 telefonów). Dobrą ideą byłoby postawienie serwera SL3, ale z drugiej strony ile brać za unlock pojedynczej sztuki od osób kupujących konto np. na 10 telefonów? Skoro każdy będzie twierdził, że ma MX-Keya i przy radku 4650 będzie liczył sobie kod przez 2 miesiące :]? |
wiec dlatego ceny nie spadna, wg moich wyliczen na moim radeonie 4670 to okolo 500 godzin by liczylo, czyli wg mnie 150 zl dla klienta koncowego, tyle ze ja jestem w komfortowej sytuacji ze mi wystarczy wymienic grafike za 2000zl i czas przerobu jednego telefonu spadnie do 50 godzin, a wiecej niz 2 na tydz sl3 to nie mam.
| Back to top |
cykada Poziom 20
#119
28 Dec 2010 12:40 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| TxT wrote: |
7 dni za spam w newsach, czyli chodzi o posty w newsach o update ktory dopiero bedzie tzw twoja "nieprawdziwa solucja" wg twojej interpretacji, w mojej fake update to nieprawdziwa aktualizacja. na chwile obecna i w chwili pisania przez Ciebie posta aktualizacja wydana przez Karwosa byla jak najbardziej Prawdziwa, a Ty dalej swoje ze nie dziala. |
K.. mać.
Podpisywałem umowę z Twoim prawnikiem, że mnie za słowa łapiesz ?
Gdzie napisałem, że nie działa? I gdzie się przy tym upieram ?
Wyluzuj kolego.
P.S. poza tym pewne osoby sprawdzały i kody były błędnie wyliczane.
| Back to top |
Google
28 Dec 2010 12:40 |
| Back to top |
TxT Poziom 19
#120
28 Dec 2010 12:52 Re: Cyclone Box - nokia BB5, DCT-L, DCT4, DCT4+. |
| cykada wrote: |
| TxT wrote: |
K.. mać.
Wyluzuj kolego.
P.S. poza tym pewne osoby sprawdzały i kody były błędnie wyliczane. |
mi pierwsza sztuka za jakies 60 godzin sie wyliczy u kolegi z mocnym sprzetem wiec potwierdze czy dziala czy nie dziala, nie sadze zeby algorytm byl zly jak Piotrek od kilku dobrych miesiecy liczy dobre kody, tylko trudno sie wbic na serwer bylo.
| Back to top |
