Amro eid Poziom 14
Joined: 26 Jan 2005 Posts: 188 Location: alexandria egypt
#8
06 Apr 2009 20:50 Re: Poszukuję sterowników do skanera Artec E+48U |
hi Mery84
thanks alot for this program it is new for me i used it and get that
05d8 Ultima Electronics Corp.
4001 Artec Ultima 2000
4002 Artec Ultima 2000 (GT6801 based)/Lifetec LT9385 Scanner
4003 Artec E+ 48U
4004 Artec E+ Pro
my scanner Artec E+ 48U GT6816 chip
and here it the DeviceList i get it from this program
Device Information Listing for amro@DREAM-BFC1C57A1 - 4/6/2009 10:30:49 PM
VT8601 Apollo PLE133 CPU to PCI Bridge
Vendor: VIA Technologies Inc
PnpID: PCI\VEN_1106&DEV_0601&SUBSYS_00000000&REV_05
Details
Bus 0 (PCI), Device Number 0, Device Function 0
Vendor 1106h VIA Technologies Inc
Device 0601h VT8601 Apollo PLE133 CPU to PCI Bridge
Command 0006h (Memory Access, BusMaster)
Status A290h (Has Capabilities List, Supports Back-To-Back Trans., Received Master Abort, Detected Parity
Error, Medium Timing)
Revision 05h, Header Type 00h, Bus Latency Timer 08h
Self test 00h (Self test not supported)
PCI Class Bridge (PCI to HOST)
Address 0 is a Memory Address (anywhere in 0-4Gb, Prefetchable) : D0000000h
New Capabilities List Present:
AGP Capability, Version 2.0 (AGP 4x and below support)
AGP Mode Enabled : Yes
AGP Speed(s) Supported : 1x 2x 4x, Currently : 4x
FW Transfers Supported : No, Enabled : No
>4Gb Address Space Supported : No, Enabled : No
Sideband Addressing Supported : Yes, Enabled : Yes
Maximum Command Queue Length : 8 bytes, Current Queue Length : 1 byte
Class: Bridge (PCI to HOST)
VT82C601 Apollo PLE133 CPU to AGP Bridge
PnpID: PCI\VEN_1106&DEV_8601&SUBSYS_00000000&REV_00
Details
Bus 0 (PCI), Device Number 1, Device Function 0
Device 8601h VT82C601 Apollo PLE133 CPU to AGP Bridge
Command 0007h (I/O Access, Memory Access, BusMaster)
Status A230h (Has Capabilities List, Supports 66MHz, Received Master Abort, Detected Parity Error, Medium
Timing)
Revision 00h, Header Type 01h, Bus Latency Timer 00h
PCI Class Bridge (PCI to PCI)
PCI Bridge Information:
Primary Bus Number 0, Secondary Bus Number 1, Subordinate Bus Number 1
Secondary Bus Command 0004h (ISA mapping)
Secondary Bus Status 0000h
Secondary Bus Latency 00h
I/O Port Range Passed to Secondary Bus : None
Memory Range Passed to Secondary Bus : D4000000h to D6FFFFFFh
Prefetchable Memory Range Passed to Secondary Bus : None
Power Management Capability, Version 1.1
Supports low power State D1
Does not support PME# signalling
Current Power State : D0 (Device operational, no power saving)
Class: Bridge (PCI to PCI)
VT82C686B PCI to ISA Bridge
PnpID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_40
Details
Bus 0 (PCI), Device Number 7, Device Function 0
Device 0686h VT82C686B PCI to ISA Bridge
Command 0087h (I/O Access, Memory Access, BusMaster, Wait Cycles)
Status 0210h (Has Capabilities List, Medium Timing)
Revision 40h, Header Type 80h, Bus Latency Timer 00h
PCI Class Bridge (PCI to ISA)
Subsystem ID 00001106h VT82C686/A PCI to ISA Bridge
Subsystem Vendor 1106h VIA Technologies Inc
Does not support low power State D1 or D2
Class: Bridge (PCI to ISA)
OEM Device: VT82C686/A PCI to ISA Bridge
OEM Vendor: VIA Technologies Inc
VT82xxxx EIDE Controller (All VIA Chipsets)
PnpID: PCI\VEN_1106&DEV_0571&SUBSYS_00001106&REV_06
Details
Bus 0 (PCI), Device Number 7, Device Function 1
Device 0571h VT82xxxx EIDE Controller (All VIA Chipsets)
Status 0290h (Has Capabilities List, Supports Back-To-Back Trans., Medium Timing)
Revision 06h, Header Type 00h, Bus Latency Timer 20h
PCI Class Storage (IDE (ATA)
PCI EIDE Controller Features :
BusMaster EIDE is supported
Primary Channel is at I/O Port 01F0h and IRQ 14
Secondary Channel is at I/O Port 0170h and IRQ 15
Subsystem ID 05711106h VT82Cxxxx EIDE Controller (All VIA Chipsets) (Generic ID)
Address 4 is an I/O Port : 0000C000h
Class: Storage (IDE (ATA)
OEM Device: VT82Cxxxx EIDE Controller (All VIA Chipsets) (Generic ID)
VT82C686B USB Controller
PnpID: PCI\VEN_1106&DEV_3038&SUBSYS_05711106&REV_1A
Details
Bus 0 (PCI), Device Number 7, Device Function 2
Device 3038h VT82C686B USB Controller
Revision 1Ah, Header Type 00h, Bus Latency Timer 20h
Cache line size 32 Bytes (8 DWords)
PCI Class Serial (USB (UHCI))
Subsystem ID 12340925h VIA USB Controller
Subsystem Vendor 0925h Known Bad Subsystem ID - no Vendor ID Available
Address 4 is an I/O Port : 0000C400h
System IRQ 11, INT# D
Class: Serial (USB (UHCI))
OEM Device: VIA USB Controller
OEM Vendor: Known Bad Subsystem ID - no Vendor ID Available
OEM Device: Known Bad Subsystem ID - no Vendor ID Available
System IRQ: 11, INT# D
VT82C686B ACPI Power Management Controller
PnpID: PCI\VEN_1106&DEV_3057&SUBSYS_12340925&REV_40
Details
Bus 0 (PCI), Device Number 7, Device Function 4
Device 3057h VT82C686B ACPI Power Management Controller
Command 0000h (Bus Access Disabled!!)
Revision 40h, Header Type 00h, Bus Latency Timer 00h
PCI Class Bridge (PCI to Other)
Subsystem ID 30571106h VT82C686/A/B ACPI Power Management Controller (Generic ID)
Class: Bridge (PCI to Other)
OEM Device: VT82C686/A/B ACPI Power Management Controller (Generic ID)
VT82C686B AC'97 Audio Codec
PnpID: PCI\VEN_1106&DEV_3058&SUBSYS_30571106&REV_50
Details
Bus 0 (PCI), Device Number 7, Device Function 5
Device 3058h VT82C686B AC'97 Audio Codec
Command 0001h (I/O Access)
Revision 50h, Header Type 00h, Bus Latency Timer 00h
PCI Class Multimedia (Audio)
Subsystem ID 45111106h Onboard AC'97 Audio Codec
Address 0 is an I/O Port : 0000CC00h
Address 1 is an I/O Port : 0000D000h
Address 2 is an I/O Port : 0000D400h
System IRQ 11, INT# C
Class: Multimedia (Audio)
OEM Device: Onboard AC'97 Audio Codec
System IRQ: 11, INT# C
F65554 HiQV64 GUI Accelerator
Vendor: Chips And Technologies
PnpID: PCI\VEN_102C&DEV_00E4&SUBSYS_45111106&REV_C2
Details
Bus 0 (PCI), Device Number 8, Device Function 0
Vendor 102Ch Chips And Technologies
Device 00E4h F65554 HiQV64 GUI Accelerator
Command 0083h (I/O Access, Memory Access, Wait Cycles)
Status 0280h (Supports Back-To-Back Trans., Medium Timing)
Revision C2h, Header Type 00h, Bus Latency Timer 00h
PCI Class Display (VGA)
Address 0 is a Memory Address (anywhere in 0-4Gb) : D7000000h
Expansion ROM of 256Kb decoded by this card (Currently disabled)
Class: Display (VGA)
HCF 56k PCI Modem
Vendor: Rockwell Semiconductor Systems (Also Conexant)
PnpID: PCI\VEN_127A&DEV_1025&SUBSYS_00000000&REV_01
Details
Bus 0 (PCI), Device Number 9, Device Function 0
Vendor 127Ah Rockwell Semiconductor Systems (Also Conexant)
Device 1025h HCF 56k PCI Modem
Revision 01h, Header Type 00h, Bus Latency Timer 20h
PCI Class Simple Communication (Other)
Subsystem ID 1025127Ah HCF 56k PCI Modem (Generic ID)
Subsystem Vendor 127Ah Rockwell Semiconductor Systems (Also Conexant)
Address 0 is a Memory Address (anywhere in 0-4Gb) : D9000000h
Address 1 is an I/O Port : 0000DC00h
System IRQ 11, INT# A
Supports low power State D2
Supports PME# signalling from mode(s) D0, D1, D2, D3hot, D3cold
PME# signalling is currently disabled
3.3v AUX Current required : 0mA (Self powered)
Class: Simple Communication (Other)
OEM Device: HCF 56k PCI Modem (Generic ID)
OEM Vendor: Rockwell Semiconductor Systems (Also Conexant)
System IRQ: 11, INT# A
RT8139 (A/B/C/813x) Fast Ethernet Adapter
Vendor: Realtek Semiconductor
PnpID: PCI\VEN_10EC&DEV_8139&SUBSYS_1025127A&REV_10
Details
Bus 0 (PCI), Device Number 10, Device Function 0
Vendor 10ECh Realtek Semiconductor
Device 8139h RT8139 (A/B/C/813x) Fast Ethernet Adapter
Command 0005h (I/O Access, BusMaster)
Revision 10h, Header Type 00h, Bus Latency Timer 20h
Minimum Bus Grant 20h, Maximum Bus Latency 40h
PCI Class Network (Ethernet)
Subsystem ID 813910ECh RT8139 (A/B/C/810x) Fast Ethernet Adapter (Generic ID)
Subsystem Vendor 10ECh Realtek Semiconductor
Address 0 is an I/O Port : 0000E000h
Address 1 is a Memory Address (anywhere in 0-4Gb) : D9010000h
Expansion ROM of 64Kb decoded by this card (Currently disabled)
Supports PME# signalling from mode(s) D1, D2, D3hot
PME# signalling is currently enabled
Class: Network (Ethernet)
OEM Device: RT8139 (A/B/C/810x) Fast Ethernet Adapter (Generic ID)
OEM Vendor: Realtek Semiconductor
CyberBlade/i1
Vendor: Trident Microsystems
PnpID: PCI\VEN_1023&DEV_8500&SUBSYS_813910EC&REV_6A
Details
Bus 1 (PCI), Device Number 0, Device Function 0
Vendor 1023h Trident Microsystems
Device 8500h CyberBlade/i1
Command 0004h (Bus Access Disabled!!, BusMaster)
Status 02B0h (Has Capabilities List, Supports 66MHz, Supports Back-To-Back Trans., Medium Timing)
Revision 6Ah, Header Type 00h, Bus Latency Timer 20h
Subsystem ID 85001023h CyberBlade/i1 (Generic ID)
Subsystem Vendor 1023h Trident Microsystems
Address 0 is a Memory Address (anywhere in 0-4Gb) : D6800000h
Address 1 is a Memory Address (anywhere in 0-4Gb) : D5FE0000h
Address 2 is a Memory Address (anywhere in 0-4Gb) : D6000000h
Maximum Command Queue Length : 33 bytes, Current Queue Length : 8 bytes
Power Management Capability, Version 1.0
OEM Device: CyberBlade/i1 (Generic ID)
OEM Vendor: Trident Microsystems
Ultima Electronics Corp. Artec E+ 48U
Vender: Ultima Electronics Corp.
PnpID: VID_05D8&PID_4003
Device: Artec E+ 48U
Kingston Technology USB Device
Vender: Kingston Technology
PnpID: VID_0951&PID_1607
Device: USB Device
Kingston Technology Company Inc. USB Device
Vender: Kingston Technology Company Inc.
PnpID: VID_13FE&PID_1F00
Device: USB Device
USB Mass Storage Device
Vendor: Microsoft
PnpID: usb\class_08&subclass_06&prot_50
Unknown Device
Vendor: Microsoft
PnpID: usb\unknown
USB Composite Device
Vendor: Microsoft
PnpID: usb\composite
CD-ROM Drive
Vendor: Microsoft
PnpID: gencdrom
Advanced Configuration and Power Interface (ACPI) PC
Vendor: Microsoft
PnpID: acpipic_up
Disk drive
Vendor: Microsoft
PnpID: gendisk
Standard floppy disk controller
Vendor: Microsoft
PnpID: *pnp0700
Primary IDE Channel
Vendor: Microsoft
PnpID: primary_ide_channel
Secondary IDE Channel
Vendor: Microsoft
PnpID: secondary_ide_channel
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Vendor: Microsoft
PnpID: *pnp0303
VIA AC'97 Audio Controller (WDM)
Vendor: Microsoft
PnpID: pci\ven_1106&dev_3058&subsys_45111106
Standard Game Port
Vendor: Microsoft
PnpID: *pnpb02f
Media Control Devices
Vendor: Microsoft
PnpID: ms_mmmci
Video Codecs
Vendor: Microsoft
PnpID: ms_mmvid
Audio Codecs
Vendor: Microsoft
PnpID: ms_mmacm
Legacy Video Capture Devices
Vendor: Microsoft
PnpID: ms_mmvcd
Legacy Audio Drivers
Vendor: Microsoft
PnpID: ms_mmdrv
Microsoft Streaming Clock Proxy
Vendor: Microsoft
PnpID: sw\{97ebaacc-95bd-11d0-a3ea-00a0c9223196}
Microsoft Kernel System Audio Device
Vendor: Microsoft
PnpID: sw\{a7c7a5b0-5af3-11d1-9ced-00a024bf0407}
Microsoft Kernel Wave Audio Mixer
Vendor: Microsoft
PnpID: sw\{b7eafdc0-a680-11d0-96d8-00aa0051e51d}
Microsoft Kernel DLS Synthesizer
Vendor: Microsoft
PnpID: sw\{8c07dd50-7a8d-11d2-8f8c-00c04fbf8fef}
Microsoft Kernel GS Wavetable Synthesizer
Vendor: Microsoft
PnpID: sw\{6c1b9f60-c0a9-11d0-96d8-00aa0051e51d}
Microsoft WINMM WDM Audio Compatibility Driver
Vendor: Microsoft
PnpID: sw\{cd171de3-69e5-11d2-b56d-0000f8754380}
Microsoft Streaming Quality Manager Proxy
Vendor: Microsoft
PnpID: sw\{ddf4358e-bb2c-11d0-a42f-00a0c9223196}
Microsoft Kernel DRM Audio Descrambler
Vendor: Microsoft
PnpID: sw\{eec12db6-ad9c-4168-8658-b03daef417fe}
Microsoft Kernel Acoustic Echo Canceller
Vendor: Microsoft
PnpID: sw\{4245ff73-1db4-11d2-86e4-98ae20524153}
Microsoft Kernel Audio Splitter
Vendor: Microsoft
PnpID: sw\{2f412ab5-ed3a-4590-ab24-b0ce2aa77d3c}
Microsoft Streaming Service Proxy
Vendor: Microsoft
PnpID: sw\{96e080c7-143c-11d1-b40f-00a0c9223196}
Best Data Data Fax Modem
Vendor: Microsoft
PnpID: pci\ven_127a&dev_1025&subsys_1025127a
Plug and Play Monitor
Vendor: Microsoft
PnpID: *pnp09ff
PS/2 Compatible Mouse
Vendor: Microsoft
PnpID: *pnp0f13
Realtek RTL8139 Family PCI Fast Ethernet NIC
Vendor: Microsoft
PnpID: pci\ven_10ec&dev_8139&subsys_813910ec
RAS Async Adapter
Vendor: Microsoft
PnpID: sw\{eeab7790-c514-11d1-b42b-00805fc1270e}
Packet Scheduler Miniport
Vendor: Microsoft
PnpID: ms_pschedmp
WAN Miniport (L2TP)
Vendor: Microsoft
PnpID: ms_l2tpminiport
WAN Miniport (PPTP)
Vendor: Microsoft
PnpID: ms_pptpminiport
WAN Miniport (PPPOE)
Vendor: Microsoft
PnpID: ms_pppoeminiport
Direct Parallel
Vendor: Microsoft
PnpID: ms_ptiminiport
WAN Miniport (IP)
Vendor: Microsoft
PnpID: ms_ndiswanip
Eset Personal Firewall Miniport
Vendor: ESET
PnpID: eset_epfwndismp
Printer Port
Vendor: Microsoft
PnpID: *pnp0400
Communications Port
Vendor: Microsoft
PnpID: *pnp0501
Microsoft System Management BIOS Driver
Vendor: Microsoft
PnpID: root\mssmbios
Logical Disk Manager
Vendor: Microsoft
PnpID: root\dmio
Plug and Play Software Device Enumerator
Vendor: Microsoft
PnpID: root\swenum
Microcode Update Device
Vendor: Microsoft
PnpID: root\update
Volume Manager
Vendor: Microsoft
PnpID: root\ftdisk
Microsoft ACPI-Compliant System
Vendor: Microsoft
PnpID: *pnp0c08
ACPI Fixed Feature Button
Vendor: Microsoft
PnpID: acpi\fixedbutton
PCI bus
Vendor: Microsoft
PnpID: *pnp0a03
System board
Vendor: Microsoft
PnpID: *pnp0c01
ACPI Power Button
Vendor: Microsoft
PnpID: *pnp0c0c
Programmable interrupt controller
Vendor: Microsoft
PnpID: *pnp0000
System timer
Vendor: Microsoft
PnpID: *pnp0100
Direct memory access controller
Vendor: Microsoft
PnpID: *pnp0200
Numeric data processor
Vendor: Microsoft
PnpID: *pnp0c04
Motherboard resources
Vendor: Microsoft
PnpID: *pnp0c02
System CMOS/real time clock
Vendor: Microsoft
PnpID: *pnp0b00
System speaker
Vendor: Microsoft
PnpID: *pnp0800
ISAPNP Read Data Port
Vendor: Microsoft
PnpID: isapnp\readdataport
Printer Port Logical Interface
Vendor: Microsoft
PnpID: lptenum\microsoftrawport958a
Terminal Server Device Redirector
Vendor: Microsoft
PnpID: root\rdpdr
Terminal Server Mouse Driver
Vendor: Microsoft
PnpID: root\rdp_mou
Terminal Server Keyboard Driver
Vendor: Microsoft
PnpID: root\rdp_kbd
Intel PentiumIII Processor
Vendor: Microsoft
PnpID: acpi\genuineintel_-_x86_family_6_model_11
Generic volume
Vendor: Microsoft
PnpID: storage\volume
sorry this program new for me what i have to do after that
thank u very much
kind/regards
| Description: |
 Download |
| Filename: |
raport.txt |
| Contents: |
| Filesize: |
17.45 KB |
| Punkty: |
0 |
