konica 7920 - błąd C3310- jak naprawić?
Post new topic  Reply to topic      Main Page -> Forum Index -> Printer, photocopier service -> Printers, Photocopier Professional -> konica 7920 - błąd C3310- jak naprawić?
Author
Message
buli -konrad
Post#1 Post from the author of the topic 09 Apr 2009 12:09
konica 7920 błąd C3310
witam mam taką maszynkę klient przywiózł to ze szwecji czy cos hmm podobno chodziła podczas transportu dostała w bok kilka elementów połamanych i wyświetla właśnie ten błąd co to znaczy i jak to ewentualnie naprawić nie ukrywam ze nie miałem wcześniej doczynienia z czymś takim no i może ktoś ma jakiś parts do tego.
Popraw pisownię. Wielkie litery, kropki, ogonki.
marek216
Back to top
Google
Google Adsense
Post# Post from the author of the topic 09 Apr 2009 12:09
Back to top
copyman
Post#2 09 Apr 2009 16:05
Re: konica 7920 błąd C3310
C3310: CCD clamp/gain adjustment failure
Clamp/Gain Adjustment Values
✽ Clamp: Allowable up to ±100 of the above values.
✽ Gain: Allowable up to ±90 of the above values for R and B; allowable up to ±50 of the
above values for G.
✽ Exposure Lamp adjustment value: Allowable in the range between 64 and 192. A difference
of up to 30 is allowed between RO and RE, between GO and GE, and between BO
and BE.
C3310
Relevant Electrical Parts
Exposure Lamp (LA1)
Flat Cable (PWB-Z)
CCD Sensor Board (PWB-A)
Image Processing Board (PWB-C)
RO RE GO GE BO BE
Clamp 130 130 130 130 130 130
RO RE GO GE BO BE
Gain 160 160 170 170 160 160
Lamp Adjustment
Value
135
Step Check Item Result Action
1 Check that each of the values displayed on the screen falls within the above range.
2 There is a wide difference between the
clamp and gain adjustment values, the
value being close to “0” or “255.”
YES Make positive connection of
the harness connectors
between CCD Sensor Board
and Image Processing Board.
3 Clamp adjustment value exceeds the allowable
range.
YES Reinstall covers, as extraneous
light is the cause of the
problem.
4 The lamp adjustment value or gain value
exceeds the upper limit of the allowable
range, being abnormally great.
YES Clean lens, mirrors, CCD surface,
shading sheet, and
related parts.
5 The lamp adjustment value or gain value
falls short of the lower limit of the allowable
range, being abnormally small.
problem.
Change Scanner, as the
reflectors are deformed.
Tyle serwisówka... Jest to to samo co MINOLTA CF-2001. Partsa chyba też mam.
C.
Back to top
Page 1 of 1
Similar topics
Błąd aplikacji. Jak naprawić ten błąd? (4)
KONICA CF 900 - C3310 kolorowa - zalany panel (21)
KONICA 4345- błąd F34-02. Jak można skasować ten błąd? (2)
Konica 7015 wymien IU. Jak to naprawić? (3)
konica 7920 - polski dokumentacje itd (3)
Konica 7015 - Błąd C60 - co oznacza? jak naprawić? (3)
KONICA 1216 błąd J16 - jak naprawić? (2)
Konica 3331 - Błąd 36-01. Jak skasować błąd? (7)
Błąd 404 - jak naprawić ? (7)
Jeden błąd w validatorze. Jak go naprawić? (3)
Page generation time: 0.07 seconds
elektroda.pl topic RSS feed
