Logi do sprawdzenia 100% cpu SVCHOST.exe
Post new topic  This topic is locked      Main Page -> Forum Index -> Computer Service -> Anti-Virus Emergency -> Logi do sprawdzenia 100% cpu SVCHOST.exe
Author
Message
matess
Poziom 3
Poziom 3
Post#1 Post from the author of the topic 02 Mar 2010 14:09
Mam pro¶bę o sprawdzenie logów i pomoc:
OTL.txt: http://wklej.org/id/288926/
Extras.txt: http://wklej.org/id/288927/
Proszę o pomoc
Back to top
Google
Google Adsense
Post# Post from the author of the topic 02 Mar 2010 14:09
Back to top
Kolobos
Post#2 02 Mar 2010 14:50
Re: Logi do sprawdzenia 100% cpu SVCHOST.exe
Czy skan przy pomocy mbam oraz cureit cos wykazal?
Uzyj Flash Disinfector oraz zainstaluj KB971029 ze strony MS. Pamietaj tez zeby usunac infekcje z G:, S:, F:.
Wklej to do OTL i nacisnij Run Fix:
:OTL
SRV - File not found [On_Demand | Stopped] -- -- (avast! Web Scanner)
SRV - File not found [On_Demand | Stopped] -- -- (avast! Mail Scanner)
SRV - File not found [Auto | Stopped] -- -- (avast! Antivirus)
FF - prefs.js..browser.search.defaultenginename: "Winamp Search"
FF - prefs.js..browser.search.defaulturl: "http://slirsredirect.search.aol.com/slirs_http/sredir?sredir=2685&invocationType=tb50ffwinampie7&query="
FF - prefs.js..keyword.URL: "http://slirsredirect.search.aol.com/slirs_http/sredir?sredir=2685&invocationType=tb50ffwinampab&query="
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [avast5] C:\PROGRA~1\ALWILS~1\Avast5\avastUI.exe File not found
O20 - HKLM Winlogon: TaskMan - (C:\RECYCLER\S-1-5-21-2614021535-4667476129-520795991-7620\nissan.exe) - C:\RECYCLER\S-1-5-21-2614021535-4667476129-520795991-7620\nissan.exe File not found
O33 - MountPoints2\{106cf84e-3879-11de-9213-001a920a363d}\Shell\AutoRun\command - "" = G:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{106cf84e-3879-11de-9213-001a920a363d}\Shell\open\command - "" = G:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{1ee4a528-889a-11dd-85d0-0018f3d62d56}\Shell\AutoRun\command - "" = S:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{1ee4a528-889a-11dd-85d0-0018f3d62d56}\Shell\open\command - "" = S:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{3ce580bf-a284-11de-9390-0018f3d62d56}\Shell\AutoRun\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{3ce580bf-a284-11de-9390-0018f3d62d56}\Shell\open\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{a3e08a7b-a004-11dd-85fd-001a920a363d}\Shell\AutoRun\command - "" = K:\InstallTomTomHOME.exe -- File not found
O33 - MountPoints2\{b3648c77-d859-11de-9458-0018f3d62d56}\Shell - "" = AutoRun
O33 - MountPoints2\{b3648c77-d859-11de-9458-0018f3d62d56}\Shell\AutoRun\command - "" = F:\NokiaPCIA_Autorun.exe -- File not found
O33 - MountPoints2\{ce4bda77-a1c1-11de-938e-0018f3d62d56}\Shell\AutoRun\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{ce4bda77-a1c1-11de-938e-0018f3d62d56}\Shell\open\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{ce4bda79-a1c1-11de-938e-0018f3d62d56}\Shell\AutoRun\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
O33 - MountPoints2\{ce4bda79-a1c1-11de-938e-0018f3d62d56}\Shell\open\command - "" = F:\MUSHKARCI\\nesme.exe -- File not found
:Files
C:\Documents and Settings\All Users\Dane aplikacji\ypkpiykb.yyr
Daj moze log z combofix, tylko wylacz przed uzyciem firewall oraz antywirus.
Back to top
matess
Poziom 3
Poziom 3
Post#3 Post from the author of the topic 02 Mar 2010 20:23
otl: http://wklej.org/id/289169/
gmer: http://wklej.org/id/289171/
combofix: http://wklej.org/id/289173/
Dzięki za poprzednie rady. Zainstalowałem KB971029 jest lepiej.
Jakiego polecasz antywira i firewalla?
Back to top
Google
Google Adsense
Post# Post from the author of the topic 02 Mar 2010 20:23
Back to top
Kolobos
Post#4 03 Mar 2010 13:49
Zgraj c:\windows\system32\dllcache\beep.sys do c:\windows\System32\drivers\beep.sys
Wpisz w uruchom:
sc delete soqwx32
Back to top
matess
Poziom 3
Poziom 3
Post#5 Post from the author of the topic 03 Mar 2010 23:31
Ok zrobiłem tak,
Czy to już wszystko?
Back to top
Google
Google Adsense
Post# Post from the author of the topic 03 Mar 2010 23:31
Back to top
Kolobos
Post#6 03 Mar 2010 23:43
Tak.
Back to top
matess
Poziom 3
Poziom 3
Post#7 Post from the author of the topic 04 Mar 2010 00:12
Dzięki wielkie :)
Back to top
Page 1 of 1
Similar topics
100% użycie CPU przez proces svchost.exe (10)
Windows XP- svchost.exe zjada 100% CPU (7)
svchost.exe usługa sieciowa używa 100% procesora -LOGI (3)
Svchost.exe 100% użycie CPU (21)
Svchost.exe 100% CPU (2)
svchost.exe 100% procesora - log z OTL do sprawdzenia (11)
Logi do sprawdzenia 100% cpu SVCHOST.exe (1)
laptop Acer- proces svchost.exe zużywa 100% CPU (12)
SVChost - 100% CPU pomocy (4)
Notebook svchost.exe 100% wi-fi (2)
Page generation time: 0.099 seconds
elektroda.pl topic RSS feed
