W850i naprawa GDFS, błąd przy wgrywaniu 12/32 bloku.
Post new topic  Reply to topic      Main Page -> Forum Index -> GSM -> GSM Beginners -> W850i naprawa GDFS, błąd przy wgrywaniu 12/32 bloku.
Author
Message
gavron04
Post#1 Post from the author of the topic 14 Apr 2010 22:29
Witam, do zrobienia mam W850i z uszkodzonym GDFS. (Posiadam se tool 3 box, v1.01). Robię reset, przechodzę do zakładki Empty Fill & Repair dodaję gdfs w formacie .ssw, klikam FLASH. Dochodzi do 12 bloku i wyskakuje błąd.
Oto log:
Code:
2010-04-14 21:53:40 RUNNING v 1.01/UNI
2010-04-14 21:53:40 CARD SERIAL ----------
2010-04-14 21:53:40 USBFLASH DRIVER VERSION 02.02.00.05
2010-04-14 21:53:51 SIGNED MODE (USING SERVER)
2010-04-14 21:53:51 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
2010-04-14 21:53:51 CFG:100000000000
2010-04-14 21:53:51 RESET MODE STARTED
2010-04-14 21:54:27 ChipID:9900,EMP protocol:0301
2010-04-14 21:54:28 BOOTROM MODE DETECTED
2010-04-14 21:54:28 Speed:921600
2010-04-14 21:55:00 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
2010-04-14 21:55:02 FLASH ID: 2019
2010-04-14 21:55:15 GOT SEED:B48BBD3A2380236C1570C7A4
2010-04-14 21:55:18 P96 AUTH PASSED
2010-04-14 21:55:20 OTP: LOCKED:1 CID:51 PAF:1 IMEI:------- CERT:N/A
2010-04-14 21:55:22 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
2010-04-14 21:55:23 Elapsed: 92 secs.
2010-04-14 21:55:54 CFG:000000000000
2010-04-14 22:00:18 ChipID:9900,EMP protocol:0301
2010-04-14 22:00:19 BOOTROM MODE DETECTED
2010-04-14 22:00:19 Speed:921600
2010-04-14 22:00:49 OTP: LOCKED:1 CID:51 PAF:1 IMEI:---------- CERT:N/A
2010-04-14 22:00:50 FLASH CID:49 COLOR:BROWN
2010-04-14 22:02:24 LDR:060721 1021 DB2020_SERVICE_LOADER
2010-04-14 22:02:25 FLASH ID: 2019
2010-04-14 22:02:26 writing "-----------BOX v1.01\gdfs_in_ssw_format\db2020\w850_gdfs_ssw.ssw"
2010-04-14 22:02:28 CURRENT FLASH FILE CID:49
2010-04-14 22:02:28 SSW uses full hash, hash len is: 640
2010-04-14 22:02:30 Will flash 32 blocks...
2010-04-14 22:13:51 llbug: blk write fail. fatal
2010-04-14 22:14:21 packet not acknowledged (01)
2010-04-14 22:14:21 subblock 010 NAK, [47EB0000/00010000]
2010-04-14 22:14:21 Elapsed: 1107 secs.
EROM wgrywa się bez problemów.
Pozdrawiam,
gavron04
Back to top
Google
Google Adsense
Post# Post from the author of the topic 14 Apr 2010 22:29
Back to top
tomi_154
Post#2 15 Apr 2010 01:34
Re: W850i naprawa GDFS, błąd przy wgrywaniu 12/32 bloku.
Czy wybrałeś dobry model ? Jakie opcje zaznaczałeś przy tym gdfs ? Powinno być tylko signed mode i powinno pójść.
Jakby nie poszło to spróbuj po COM-ie to polecieć ...
Back to top
Google
Google Adsense
Post# 15 Apr 2010 01:34
Back to top
gavron04
Post#3 Post from the author of the topic 15 Apr 2010 11:29
Tak, zaznaczyłem dobry model. Zaznaczyłem tylko signed mode.
Back to top
Page 1 of 1
Similar topics
Nokia X3 Błąd przy wgrywaniu softa. (8)
Błąd przy wgrywaniu softu, k550i (2)
Soft Z520i błąd przy wgrywaniu (1)
6131 błąd przy wgrywaniu softu (27)
błąd przy wgrywaniu softa SE k550i (6)
Nokia 6610i - błąd przy wgrywaniu softu (5)
Tornado i 6310i: błąd przy wgrywaniu softu (9)
[V360] Błąd przy wgrywaniu backupu (2)
Jakiś błąd przy wgrywaniu (4)
Naprawa gdfs w W850i cruiserem (12)
Page generation time: 0.09 seconds
elektroda.pl topic RSS feed
