Częste resetowanie się komputera - co zrobić ?
Pejsinho 25 Kwi 2010 20:04 1308 7
  • #1 25 Kwi 2010 20:04
    Pejsinho
    Poziom 7  
    Witam ponownie ;p
    Mam problem z komputerem stacjonarnym - sam się resetuje.
    Poczytałem troszke na google i odrazu wklejam:
    Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\WINDOWS\Minidump\Mini042510-01.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: *** Invalid ***
    * Symbol loading may be unreliable without a symbol search path. *
    * Use .symfix to have the debugger choose a symbol path. *
    * After setting your symbol path, use .reload to refresh symbol locations. *
    Executable search path is:
    * Symbols can not be loaded because symbol path is not initialized. *
    * The Symbol Path can be set by: *
    * using the _NT_SYMBOL_PATH environment variable. *
    * using the -y <symbol_path> argument when starting the debugger. *
    * using .sympath and .sympath+ *
    Unable to load image ntoskrnl.exe, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ntoskrnl.exe
    *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
    Windows XP Kernel Version 2600 (Service Pack 1) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Machine Name:
    Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054be30
    Debug session time: Sun Apr 25 19:24:55.875 2010 (GMT+2)
    System Uptime: 0 days 0:35:00.421
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    Use !analyze -v to get detailed debugging information.
    BugCheck 1000008E, {c0000005, 80568fb6, f5b258ac, 0}
    ***** Kernel symbols are WRONG. Please fix symbols to do analysis.
    *** Your debugger is not using the correct symbols ***
    *** In order for this command to work properly, your symbol path ***
    *** must point to .pdb files that have full type information. ***
    *** Certain .pdb files (such as the public OS symbols) do not ***
    *** contain the required information. Contact the group that ***
    *** provided you with these symbols if you need this command to ***
    *** work. ***
    *** Type referenced: nt!_KPRCB ***
    *** work. ***
    Probably caused by : ntoskrnl.exe ( nt+94fb6 )
    Followup: MachineOwner
    Co robić ? ;/
  • #2 25 Kwi 2010 20:23
    1337166
    Usunięty  
  • #3 25 Kwi 2010 20:27
    chris-s
    Zobacz stan kondensatorów na płycie głównej.
  • #4 25 Kwi 2010 22:28
    Pejsinho
    Poziom 7  
    A to nie problem z tym plikiem ?
    Stałybywalec102 napisał:
    Witam wydaje mi się że masz zwarcie na zasilaczu lub na płycie ( podobnie miałem ale gdy włączałem komputer to nie mogłem go dotknąć bo się resetował , wymieniłem zasilacz i jak ok). pożycz zasilacz od jakiegoś kolegi i zobacz .
    Jaki zasilacz wybrać zeby był dobry i tani ? To w ogóle pomoże w moim problemie ?
    Jak mam to zrobić ?
  • #5 25 Kwi 2010 22:54
    adorbelo
    Przedstaw nam konfiguracje komputera, zebysmy mogli cos doradzic. A co do kondensatorow, sprawdz czy nie sa wybrzuszone;)
  • #6 25 Kwi 2010 23:19
    kkf
    1. Najpierw należy sprawdzić, czy przyczyna tkwi w sprzęcie, czy w systemie.
    2. Wystartuj komputer z CD z testem HDD (np. seatools) Jeśli restarty też występują przy starcie z CD - to na 100% jest uszkodzony sprzęt - czyli sprawdzanie konensatorów, pamięci, dysku, grafiki, zasilacza.
    3. Jeśli test HDD nie wykaże błedów - to jest problem z systemem (na 80%) pozostaje 20% na wady sprzętu które ujawniają się w specyficznych warunkach
    można wtedy próbować kilku sposobów: przywracanie systemu, ostatnia znana dobra konfiguracja, tryb VGA, odwirusowanie i wiele innych ...
  • #7 25 Kwi 2010 23:52
    Rychwal
    Może kolega spróbowałby podmienić plik ntoskrnl.exe i skopiować z płyty instalacyjnej
    Co do zasilaczy to dobra i tania firma to jest Delta
    Poza tym proponuję się zapoznać z tematem
    Code:
    http://www.elektroda.pl/rtvforum/topic1199271.html
  • #8 27 Kwi 2010 22:35
    mati211p
    Jeżeli Windows uruchamia się a co jakiś czas wyskakuje BSOD lub resetuje się on może mieć związek z uszkodzeniem kondensatorów na płycie czy w zasilaczu(przydałyby się wartości napięć z miernika) czy przegrzewaniem procesora(podaj wartości temperatur).Jeżeli sam resetuje się po dotyku to może znaczyć że przycisk reset jest uszkodzony lub na płycie jest zwarcie.Mógłbyś jeszcze przeskanować pamięć programem MemTest.
 Szukaj w ofercie
Zamknij
