Fenix nowy box do Nokii i jego możliwości.
Post new topic  Reply to topic      Main Page -> Forum Index -> GSM -> GSM Service -> Fenix nowy box do Nokii i jego możliwości.
Author
Message
siudziu
Post#241 21 Jan 2012 20:48
Re: Fenix nowy box do Nokii i jego możliwości.
U mnie za którymś razem zapisuje czasem za 2 czasem za 3. Generalnie straj sie mieć jak najmnej odpalonych aplikacji. I nie zminieaj mu folderu zapisz tam gdzie otworzy sie okienko do zapisu.
Back to top
Google
Google Adsense
Post# 21 Jan 2012 20:48
Back to top
siudziu
Post#242 10 Feb 2012 10:18
Fenix Key v1.2.0 released:
1. Supporting Nokia Broadcomm Model:
- unlock (read SL3 Log) - added
- SX4 AUTHORIZATION - added
- SD Repair - added
- Security Analyze - added
- C3-00 (RM-614)
- X2-00 (RM-618)
- X2-01 (RM-709)
- X2-03 (RM-709)
- X2-01.1 (RM-717)
- 2710c (RM-586)
- 2710b-2 (RM-586)
- 7020 (RM-497)
2. Supporting Nokia RAPUYAMA v21 Model:
- SD Repair - added
Nokia Asha 201 (RM-799)
Nokia Asha 201 (RM-800)
Nokia Asha 300 (RM-781)
Nokia Asha 303 (RM-763)
Nokia 500 (RM-750)
Nokia 600 (RM-701)
Nokia 603 (RM-779)
Nokia 700 (RM-670)
Nokia 701 (RM-744)
3. Phone IDs are stored now locally this solve problem with booting phone at very opration.
4. Added latest .ini files.
5. Added latest drivers for Nokia phones v7.1.48.0
6. Improved USB unlock speed for SL1 and SL2 Nokia phones.
7. Reset off FBUS/Keypad counter code - added.
8. Fenix can now automatically detected phones which cannot be unlocked using FBUS/Keypad code (B Profile bit).
9. BF Unlock button is removed now from main software (you can start SLAP brutforce unlocker from Fenix Smart Start).
10. Signature check at read log process for SL3 phones can be skipped now.
11. Reading special PM fields from some models - fixed.
12. SELF TEST results are dispaled now in main log window.
13. More info is displayed now on unlocking Rap3gv3 via USB.
W końcu jakis update. Wreszcie dogonili reszte stawki :P
Back to top
entermen
Post#243 15 Feb 2012 16:45
Panowie mam problem ze zczytaniem loga z 6303ci rm-638 pod fenixem.
Wersja oprogramowania 10.80 (simlock z orange).
Po usb idzie ladnie zczytuje info, pod jafem także bezproblemowo.
Nistety loga po usb nie można zczytać sypie błędami.
Quote:
Job's finished successfully!
SL3 Unlocking started (via USB)
Reading phone data
Powering off the phone
PLEASE PRESS PHONE`S POWER BUTTON
CMT Hash : 7B045400E1752022F9EB80B0DEA9C65D
CMT Hw ID: 020C192102054100
CMT Boot ROM CRC: 67E82268
CMT Secure ROM CRC: F29CEA60
CMT Public Id: 09A00104F0820E49CF97B6F74240DF2868E59F8C
Preparing bootstrap to use USB BootMedia
Sending RAW 2ND
Initializing...
Initialization error
Job's finished with errors!
Po kablu fbus (rj-45) próbuje zczytać info po fenixem za pomocą jafa, ale ani razu nie poszło.
Wersja firmware jaf: 01.B4
Dostaje takie komunikaty:
Quote:
Cannot init MBUS mode in phone. Please check that you are using high quality cable.
Objaw jest taki, że telfo wchodzi w local model. Na wyświetlaczu pisze Local mode, a po kilkunastu sekundach występuje błąd.
Cała aplikacja fenixa zaktualizowana, łącznie z czytnikiem.
Sprawdziłem kabel ma 2 linie mbus połączone. Dodatkowo miedzy bsi a gnd są dwa rezystory: 7.5 kOhm oraz 6.8 kOhm odpowiednio połączone.
Back to top
gsmline
Post#244 15 Feb 2012 19:38
6303ci ma inny kabel niz 6303i !!! jakbys czasem nie wiedzial...
Back to top
entermen
Post#245 15 Feb 2012 21:04
Kabel jest kupiony do 6303ci RM-638. Ma 2 linie mbus połączone razem i dwa rezystory tak jak pisałem. Wiem, że kable są różne do tych modeli.
Back to top
rraaddoo
Post#246 21 Feb 2012 11:58
Mam problem przy update card nie kończy mi procedury , co zatym idzie nie działa mi klucz jak to rozwiązać?
Back to top
Bass Rockers
Poziom 7
Poziom 7
Post#247 21 Feb 2012 12:25
jak juz pisalem zrob update czytnika do wersji 2.0
Back to top
rraaddoo
Post#248 21 Feb 2012 15:35
Faktycznie pomogło , dzięki
Back to top
Fregh
Post#249 26 Feb 2012 15:29
Próbowałem zrobić update czytnika i mam wersję 0.0.2 wyżej nie da się zaprogramować.
wyskakuje komunikat:
Cannot update card
An error occurred while updating card.
Ensure that reader is connect and card is plugged in.
If error still occurs pleas contact support team.
Nie mogę przeprowadzić update card ;/
Back to top
siudziu
Post#250 26 Feb 2012 15:31
Robisz to zgodnie z instrukcja ? Wkładasz sam czytnik bez karty sim tak jak jest na obrazkach ?
Back to top
piratten
Post#251 27 Feb 2012 00:16
Wyłącz antywirusa i spróbuj raz jeszcze oczywiście wyciąg karte z czytnika ;)
Back to top
mefistofilos
Post#252 13 Mar 2012 16:21
Na liscie supportowanych modeli do odczytywania hashy - Nokia E6 widnieje jako nie testowana.
Tak wiec mnie dzisiaj trafila sie taka sztuka i pomyslnie Fenix odczytal hasha. Ponizej log :
Code:
Fenix Reader SW version: 0.0.2
Connection interface is set to USB now.
Checking connection...
Reading phone info
Product type: RM-609
MCU SW Version:
   V 92_11w15.5
   25-05-11
   RM-609
   (c) Nokia
Imei: 3548750xxxxxxxx
Product code: 059K470
Simlock status:
Profile bits: 8000000000000000
Config key: 2343300190233141
Fbus codes typed: 0/10
Key codes typed: 0/3
Block 1:
   Lock 1:  CLOSED(IMSI); TYPE: 5; DATA: 23 43 3F
Block 2:
   Lock 1:  CLOSED(IMSI); TYPE: 5; DATA: 23 48 6F
Block 3:
   Lock 1:  CLOSED(IMSI); TYPE: 5; DATA: 23 43 0F
Analyzing profile bits...
This phone can be unlocked via keyboard and fbus
Looking for flash files
No flash files found for selected product
Reading phone data
CMT Hash : 916F75217F32081248B15C38DFC8E81B
CMT Hw ID: 600C192102031104
CMT Boot ROM CRC: E693EF0D
CMT Secure ROM CRC: AC22615B
CMT Public Id: 13800017B5D80xxxxxxx
Sending RAW 2ND
Initializing...
Back to top
rpk
Post#253 08 Apr 2012 20:09
W Fenixie jest opcja slap aby liczyć BF na kilku kompach. Czy te kompy muszą być połączone w sieć? Czy mogą mieć połączenie internetowe? Jak to działa czy jest gdzieś jakiś opis tej usługi? Może ktoś tego używa jak to się sprawuje?
Back to top
goodmaster
Post#254 14 Apr 2012 14:17
Dlaczego log fenixa jest tak smiesznie stworzony ze zawiera imei i 8 razy hashcode?
Nie moglby zawierac imeia i hasha :) bo przeciez tylko to jest potrzebne... Prosze o info lawarov ;p
Back to top
Google
Google Adsense
Post# 14 Apr 2012 14:17
Back to top
siudziu
Post#255 14 Apr 2012 14:32
@lawarov ma wszystkich w głębokim poważaniu więc nie licz na reakcje :). A tak na poważnie to mogli by bugi poprawić i ciut więcej updatów.
Back to top
Google
Google Adsense
Post# 14 Apr 2012 14:32
Back to top
entermen
Post#256 14 Apr 2012 19:46
Mam pytanie:
Nokia 6303ci rm-638 pod fenixem nie daje rady zczytać loga po usb, a pod i7evolution po usb idzie bezproblemowo (za kredyty).
Czy nie można by podobnego rozwiązania zastosować w fenixie?
Back to top
elliott
Post#257 20 Apr 2012 14:58
Witam. Ostatnimi czasy zauważyłem że fenix sprawia mi trochę problemów, a mianowicie gdy flashuje jakiś telefon nie wszystkie funkcje w tel później działają, a to brakuje kalkulatora a to nie ma wyboru mp3 na alarm itp. Ponowny flash np phoenixem (ta sama wersja flasha itp) załatwia sprawę. Ma ktoś podobny problem??
Back to top
siudziu
Post#258 24 Apr 2012 10:59
Jeśli kalkulator nie działa ci w noki 6303 po flashu zrób reset factory fenixem lub z poziomu telefonu i kalkulator będzie działał.
Back to top
Page 9 of 9 Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Similar topics
nowy box na nowy komputer (7)
soft i jego instalacja w nokii 3120 (8)
możliwości symbiana 9,3 w nokii 6720 (7)
kabel do nokii 7650 i możliwości (3)
Multi-box lite - nowy box (20)
Nowy box do unlocku BB5 na rynku Nooox Box (41)
Jaki box do Noki SL3? Best tool, Fenix Key, AFT. (17)
Jaki box do serwisowania Nokii dla amatora? Jakie ma możliwości taki box? (6)
bark możliwości przeflesowania nokii bb5 (6280) przez hwk (6)
Page generation time: 0.298 seconds
elektroda.pl topic RSS feed
