mackos Poziom 9
#2
30 Oct 2004 23:33 Re: Philips 6010 |
Kody błędów tunera 6010
001-050 Watchdog errors
001 memory error e.g memory initialisation error, insufficient memory,...
002 Stack overflow error software processing becomes corrupted
003 Stall watchdog error software hang-up
004 Slave stall error indicates that the communication with the front panel is no longer possible
051-100 ISR errors
051 Non tranceable ISR error Currently not generated by the M5 STB
052 Bus error an illegal addressing has occurred
053 illegal instruction Currently not generated by the M5 STB
054 Pbus error an error on the Peripheral bus of the CPU
055 LSI Demux stall eror Demux hang-up
056 Not handled exception error an unhandled exception was generated
101-150 Hardware errors
101 Device instalation error a device could not be initialised
102 I1C error an I2C communication error
103 Unhandled edge interrupt error an edge triggered interrupt is not handled within a time limit
104 Unhandled edge interrupt error an edge triggered interrupt is not handled within a time limit
105 Serial receive error a serial reception error
106 Flash write error error writing to flash
107 Flash write error error erasing the flash memory
108 Slave comunication error an error occured while attempting to comunicate with the fron panel
109 Customisation error requested customer settings not found in EEPROM
401-450 Watchdog errors
401 memory error
402 Stack overflow error
403 stall watchdog error
404 slave stall error
451-500 ISR errors
451 Non traceable ISR error
452 Bus error
453 Illegal instruction
454 Pbus error
455 LSI Demux stall error
456 Not handled exception error
501-550 Hardware errors
501 Device initialisation error
502 I2C error => switch the power off for at least one minute
503 Unhandled edge interrupt error
504 Unhandled level interrupt error
505 Serial receive error
506 Flash write error
507 Flash read error
508 Slave communication error
509 Customization error
Not fatal error codes
551 Manager, initialisation error Theoretical error; box must be reset
552 not defined
553 not defined
554 not defined
555 not defined
556 Serial, initialisation error Initialisation problem with the port; box must be reset
557 not defined
558 not defined
559 not defined
560 not defined
561 not defined
562 not defined
563 not defined
564 not defined
565 not defined
566 Network, unknown error Theoretical error; box must be reset
567 Network, new image too large image doesn't fit into Video RAM;probably a provider problem
568 Network, CRC or digital signature false probably a provider problem
569 Network, scan for service failed check the satellite connection
570 Network, no component entry found in PMT probably a provider problem
571 Network, no service entry found in SDT probably a provider problem
572 Network, bad NIT, no reference to SDT probably a provider problem
573 Network, bad PAT, no reference to PMT probably a provider problem
574 Network, SDT time out probably a provider problem
575 Network, NIT time out probably a provider problem
576 Network, PAT time out probably a provider problem
577 Network, PMT time out probably a provider problem
578 Network, no download data no entitlements or no smartcard insered or bad sat connection
579 Network, bad DSI no M5 profile ID probably a provider problem
580 not defined
581 Network, bad DIRes probably a provider problem
582 Network, DIRes time out probably a provider problem
583 Network, scenario time out check the satellite connection
584 Network, bad smart card check smardcard
585 Network, store in RAM failed box problem
586 Network, no resource H2 box problem
587 Network, no resource H3 box problem
588 Network, no resource H4 box problem
589 not defined
590 not defined
591 Current initialisation error box problem
592 Current copy error box problem
593 not defined
594 not defined
595 not defined
596 New, initialisation error box problem
597 New, copy error
