serwer CCcam-klient Mg camd- nbox BSKA przerobiony E2
konwertor 12 Gru 2011 18:16 12772 3
  • #1 12 Gru 2011 18:16
    konwertor
    Poziom 7  
    Witam potrzebuję tak skonfigurować nbox-a żeby czytał kartę z czytnika (stara TNK) i był klientem CCcam-a VU duo na razie mam tak:
    Mg camd cfg;
    # EMM messages
    # 00 don't show any EMMs (default)
    # 01 show only valid EMMs
    # 02 show valid and bad EMMs with complete data display
    M: { 00 }
    # ECM messages
    # 00 don't show anything about ecm
    # 01 normal mode, show pids processed, decoded ecm and cw
    # 02 verbose mode, show valid and bad ECMs with data
    C: { 01 }
    # AU
    # 00 disable, no emm pids processed
    # 01 enable, emm pids always processed for soft-au and shared cards
    # 02 auto, emm started only if channel cant be decoded
    # 03 process emm pids for network cards update only
    A: { 02 }
    # key update (sum 01 or 02 with 04)
    # 01 update only new keys, default setting
    # 02 update all keys (used for valid PMK checking)
    # 04 enable TPS au
    # + tps SID, which pmt pid contains au pid
    U: { 01 } 0x12c0
    # config files folder (softcam, autoroll, ignore/priority)
    # 00 files in /var/keys
    # 01 files in /tmp
    T: { 00 }
    # network mode, use summ for several clients
    # 00 no network (default)
    # 01 newcamd netclient
    # 02 radegast netclient
    # 04 camd3 netclient
    # 08 gbox netclient
    # 32 cccamd netclient, card list saved as /tmp/cccamd.info
    # (ECM only, supported server version up to 2.1.1, later not work)
    G: { 32 }
    # network retry, use summ for several options
    # 00 disable
    # 01 retry every new ecm
    # 02 try to connect to offline shares every Q: seconds
    # 04 try to detect and fast reconnect to lost (and not used atm) server
    # + XX messages number and YY seconds to reconnect
    # mg will reconnect to server, if no answer to last XX ecm/keepalive or
    # if no answer for last ecm or keepalive sent for YY seconds
    # set to 0 to disable
    N: { 07 } 5 30
    # network ecm timeout in seconds
    K: { 05 }
    # newcamd dead routes connect retry, sec
    Q: { 600 }
    # network shares priority
    # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
    # 01 camd3, radegast, cccamd, gbox, newcamd
    # 02 cccamd, newcamd, camd3, gbox, radegast
    P: { 02 }
    # on screen display type
    # 00 No OSD (default)
    # 01 neutrino
    # 02 enigma
    # 03 relook
    # + user password for http auth
    O: { 00 } username password
    # on screen display Options, summ of:
    # 01 show emu ecm
    # 02 show network shares messages
    # 04 show decoding failed / fta
    # 08 show emm keys update
    # + web port to use for osd
    S: { 03 } 80
    # Log option, summ of:
    # 00 off
    # 01 network udp log
    # 02 log to console
    # 04 file, appended ! delete it by yourself, before it eat all your hdd
    # + IP udp-port log-file-name
    L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
    # keep ecm cache, seconds
    # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
    # for openbox/elanvision users with remote shares make sense to set it higher than default value,
    # to not hammer cards while timeshifting or playing crypted recordings.
    E: { 15 }
    # cache option, summ of:
    # 00 Off (default)
    # 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
    # 02 Ecm data cache, remember CW for (E:) time
    # 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
    H: { 07 }
    # reread files, summ of:
    # 00 No (default)
    # 01 reread config file on channel change (including priority and ignore, but not replace/cache)
    # 02 reread SoftCam.Key on channel change
    # 04 reread SoftCam.Key if file changed
    R: { 00 }
    # debug, summ of
    # 00 off (default)
    # 01 debug ecm
    # 02 debug emm
    # 04 debug network ecm
    # 08 debug network emm
    # 16 debug network login
    # 32 show mem/cpu stats every 1 min
    # 64 add timestamp to log messages
    D: { 00 }
    # box type
    # 00 autodetect, change only if you think wrong type detected.
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 06 dreambox/mips
    # 08 stapi/kathrein
    # 09 stapi/ipbox
    # 11 stapi/openbox
    # 12 fortrex (ipboxhd)
    B: { 11 }
    # map all 180x nagra caids to 1801
    # default is 01
    F: { 00 }
    Na tych wpisach mam czasem zacinki i nie chodzą i wszystkie HBO,nie chodzi także karta z czytnika,czytałem że do uruchomienia czytnika trzeba uruchomić Mg camd+newsc ale potrzebny jest wpis w pliku newcs xml.Może ktoś podpowie jaki wpis zrobić w tym pliku dla karty TNK i rzuci okiem na wpisy w cfg co by tam poprawić ?
  • #2 10 Sty 2012 11:25
    Antzuch
    Nie kombinuj z mgcamd, nie prościej oscam?
  • #3 03 Lut 2012 17:46
    CSA
    Pewnie już kolega rozwiązał problem bo rozwiązanie było w samym pliku:
    G: { 32 }
    Masz za wysoką wersję serwera CCCam na VU+ duo. Prawdopodobnie 2.2.x (aktualna jest 2.3.0) a mgcamd wymaga starszych wersji. Pomóc teoretycznie może wykasowanie w plik cccam.cfg wpisu
    Code:
    MINIMUM CLIENT VERSION : ....
    Ale najprawdopodobnie nic to nie zmieni.
  • #4 25 Mar 2012 21:40
    olonokia
    mg.cfg
    M: { 01 }
    C: { 01 }
    A: { 01 }
    U: { 01 } 0x12c0
    T: { 00 }
    G: { 01 }
    N: { 07 } 5 30
    K: { 05 }
    Q: { 600 }
    P: { 00 }
    O: { 00 }
    S: { 03 } 80
    E: { 15 }
    H: { 07 }
    R: { 00 }
    D: { 00 }
    B: { 00 }
    F: { 01 }
 Szukaj w ofercie
Zamknij
