Wyszukiwarka V9 - nie można usunąć
Sta666 08 Wrz 2012 19:02
  • #4 08 Wrz 2012 20:33
    Acorus 20
    Spec od komputerów
    Odinstaluj Burn4Free Toolbar.Uruchom OTL i w okno (Własne opcje skanowania/Script)wklej:
    :OTL
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.v9.com/?utm_source=b&utm_medium=vl...AJB-00J3A0_WD-WCAV2J23085430854&ts=1346960901
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.v9.com/?utm_source=b&utm_medium=vl...AJB-00J3A0_WD-WCAV2J23085430854&ts=1346960901
    IE - HKU\S-1-5-21-640722949-800503081-1022036229-1001\..\SearchScopes\{0388404D-6072-4CEB-B521-8F090FEAEE57}: "URL" = http://klit.startnow.com/s/?q={searchTerms}&src=defsearch&provider=&provider_name=yahoo&provider_code=&partner_id=693&product_id=741&affiliate_id=&channel=&toolbar_id=200&toolbar_version=2.3.0&install_country=PL&install_date=20111001&user_guid=A73A7611670B4385B1ABC5B83ADEA6DB&machine_id=95bf044b3ce7ca00e5672cf470fd4ce8&browser=IE&os=win&os_version=6.1-x64-SP1&iesrc={referrer:source}
    FF - prefs.js..browser.search.defaultenginename: "v9"
    FF - prefs.js..browser.search.order.1: "v9"
    [2012-09-06 21:48:22 | 000,000,402 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\v9.xml
    O3 - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
    O4 - HKU\S-1-5-21-640722949-800503081-1022036229-1001..\Run: [] File not found
    O4 - HKU\S-1-5-19..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe File not found
    O4 - HKU\S-1-5-20..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe File not found
    [2012-08-23 23:04:35 | 000,000,000 | ---D | M] -- C:\Users\Monisia\AppData\Roaming\EurekaLog
    :Commands
    [emptytemp]
    Kliknij Wykonaj skrypt.W OTL użyj opcji Sprzątanie.
  • #6 08 Wrz 2012 22:22
    env002
    Uruchom OTL. W okno Własne opcje skanowana / skrypt wklej:
    :OTL
    FF - prefs.js..browser.search.defaultenginename: "\"v9\""
    FF - prefs.js..browser.search.order.1: "\"v9\""
    :Commands
    [emptytemp]
    Kliknij Wykonaj skrypt. Zgódź się na ponowne uruchomienie (restart).
    Użyj AdwCleaner (opcja Delete).
    1. Uruchom OTL i kliknij Sprzątanie, aby usunąć OTL wraz z jego kwarantanną.
    2. Uruchom AdwCleaner i kliknij Uninstall, aby usunąć AdwCleaner.
    3. Czyszczenie folderów przywracania systemu
    Daj znać czy problem dalej występuje.
  • #9 09 Wrz 2012 08:59
    Sta666
    A więc tak: Nie znalazłem wpisu V9 w about:config, ale za to znalazłem w:
    Nazwa: extensions.502e9f4143136.scode
    Wartość:
    Code:
    (function(){try{if('aol.com,mystart.incredibar.com,premiumreports.info,search.babylon.com,search.funmoods.com,search.gboxapp.com,search.sweetim.com'. indexOf(window.self.location.hostname)>-1) return;}catch(e)...
    Zresetowałem wartość, wyłączyłem FF, usunąłem plik prefs, no i V9 się nie pojawia.
    Natomiast jak wlazłem znowu w about:config, to wpis który zresetowałem do domyślnego jest wciąż ten sam.
    Za tamto wielkie dzięki a czy mógłby ktoś jeszcze z tym pomóc ??
    EDIT:
    Użyłem AdwCleanera i napisał, że usunął ten wpis, po resecie i włączeniu FF ten wpis w auto:config wciąż jest.
  • #11 06 Sty 2013 12:37
    resty
    Sprawdźcie czy nie macie w swoich programach takiego który nazywa się " New Tabs" .
    Usuwając ten program pozbyłem sie natręta V9 ze wszystkich przeglądarek.
    Ten program zainstalował mi się gdy instalowałem przeglądarkę PDFu
  Szukaj w 4mln produktów
Przeglądaj produkty
