Serwer VPN (pptp)nie działa jak nalezy
kamilalek1 23 Lut 2013 20:47
  • #1 23 Lut 2013 20:47
    kamilalek1
    Zainstalowałem serwer VPN według tej instrukcji
    http://rembiejewski.pl/blog/raspberry-pi-vpn-pptp-pptpd/
    Telefon z androidem potrafi się połączyć z serwerem VPN zarówno w sieci lokalnej jak i sieci komórkowej wtedy wpisuje publiczne IP mojej sieci.
    IP routera 192.168.100.1
    IP Raspberry Pi 192.168.100.105
    IP DHCP jakie przydziela router 192.168.100.100-199
    Plik pptpd.conf
    Code:
    # $Id$
    # Sample Poptop configuration file /etc/pptpd.conf
    # Changes are effective when pptpd is restarted.
    # TAG: ppp
    #   Path to the pppd program, default '/usr/sbin/pppd' on Linux
    #ppp /usr/sbin/pppd
    # TAG: option
    #   Specifies the location of the PPP options file.
    #   By default PPP looks in '/etc/ppp/options'
    option /etc/ppp/pptpd-options
    # TAG: debug
    #   Turns on (more) debugging to syslog
    #debug
    # TAG: stimeout
    #   Specifies timeout (in seconds) on starting ctrl connection
    # stimeout 10
    # TAG: noipparam
    #       Suppress the passing of the client's IP address to PPP, which is
    #       done by default otherwise.
    #noipparam
    # TAG: logwtmp
    #   Use wtmp(5) to record client connections and disconnections.
    logwtmp
    # TAG: bcrelay <if>
    #   Turns on broadcast relay to clients from interface <if>
    #bcrelay eth1
    # TAG: localip
    # TAG: remoteip
    #   Specifies the local and remote IP address ranges.
    #       Any addresses work as long as the local machine takes care of the
    #       routing.  But if you want to use MS-Windows networking, you should
    #       use IP addresses out of the LAN address space and use the proxyarp
    #       option in the pppd options file, or run bcrelay.
    #   You can specify single IP addresses seperated by commas or you can
    #   specify ranges, or both. For example:
    #      192.168.0.234,192.168.0.245-249,192.168.0.254
    #   IMPORTANT RESTRICTIONS:
    #   1. No spaces are permitted between commas or within addresses.
    #   2. If you give more IP addresses than MAX_CONNECTIONS, it will
    #      start at the beginning of the list and go until it gets
    #      MAX_CONNECTIONS IPs. Others will be ignored.
    #   3. No shortcuts in ranges! ie. 234-8 does not mean 234 to 238,
    #      you must type 234-238 if you mean this.
    #   4. If you give a single localIP, that's ok - all local IPs will
    #      be set to the given one. You MUST still give at least one remote
    #      IP for each simultaneous client.
    # (Recommended)
    localip 192.168.100.105
    #remoteip 192.168.100.150-160
    # or
    #localip 192.168.0.234-238,192.168.0.245
    #remoteip 192.168.1.234-238,192.168.1.245
    pptpd-option
    Code:
    # $Id$
    # Sample Poptop PPP options file /etc/ppp/pptpd-options
    # Options used by PPP when a connection arrives from a client.
    # This file is pointed to by /etc/pptpd.conf option keyword.
    # Changes are effective on the next connection.  See "man pppd".
    # You are expected to change this file to suit your system.  As
    # packaged, it requires PPP 2.4.2 and the kernel MPPE module.
    # Authentication
    # Name of the local system for authentication purposes
    # (must match the second field in /etc/ppp/chap-secrets entries)
    name pptpd
    # Optional: domain name to use for authentication
    # domain mydomain.net
    # Strip the domain prefix from the username before authentication.
    # (applies if you use pppd with chapms-strip-domain patch)
    #chapms-strip-domain
    # Encryption
    # Debian: on systems with a kernel built with the package
    # kernel-patch-mppe >= 2.4.2 and using ppp >= 2.4.2, ...
    refuse-pap
    refuse-chap
    refuse-mschap
    # Require the peer to authenticate itself using MS-CHAPv2 [Microsoft
    # Challenge Handshake Authentication Protocol, Version 2] authentication.
    require-mschap-v2
    # Require MPPE 128-bit encryption
    # (note that MPPE requires the use of MSCHAP-V2 during authentication)
    require-mppe-128
    # Network and Routing
    # If pppd is acting as a server for Microsoft Windows clients, this
    # option allows pppd to supply one or two DNS (Domain Name Server)
    # addresses to the clients.  The first instance of this option
    # specifies the primary DNS address; the second instance (if given)
    # specifies the secondary DNS address.
    # Attention! This information may not be taken into account by a Windows
    # client. See KB311218 in Microsoft's knowledge base for more information.
    #ms-dns 10.0.0.1
    #ms-dns 10.0.0.2
    # If pppd is acting as a server for Microsoft Windows or "Samba"
    # clients, this option allows pppd to supply one or two WINS (Windows
    # Internet Name Services) server addresses to the clients.  The first
    # instance of this option specifies the primary WINS address; the
    # second instance (if given) specifies the secondary WINS address.
    #ms-wins 10.0.0.3
    #ms-wins 10.0.0.4
    # Add an entry to this system's ARP [Address Resolution Protocol]
    # table with the IP address of the peer and the Ethernet address of this
    # system.  This will have the effect of making the peer appear to other
    # systems to be on the local ethernet.
    # (you do not need this if your PPTP server is responsible for routing
    # packets to the clients -- James Cameron)
    proxyarp
    # Debian: do not replace the default route
    nodefaultroute
    # Logging
    # Enable connection debugging facilities.
    # (see your syslog configuration for where pppd sends to)
    #debug
    # Print out all the option values which have been set.
    # (often requested by mailing list to verify options)
    #dump
    # Miscellaneous
    # Create a UUCP-style lock file for the pseudo-tty to ensure exclusive
    # access.
    lock
    # Disable BSD-Compress compression
    ms-dns 192.168.100.1
    nobsdcomp
    noipx
    mtu 1490
    mru 1490
    Po wpisaniu
    Code:
    pi@raspberrypi ~ $ sudo iptables -t nat -L -n
    Wyskakuje mi coś takiego
    Code:
    Chain PREROUTING (policy ACCEPT)
    target     prot opt source               destination
    Chain INPUT (policy ACCEPT)
    Chain OUTPUT (policy ACCEPT)
    Chain POSTROUTING (policy ACCEPT)
    a po wpisaniu
    Code:
    pi@raspberrypi ~ $ cat /proc/sys/net/ipv4/ip_forward
    wyskukuje
    Code:
    1
  • #2 24 Lut 2013 11:03
    salmon
    Moderator - Sieci, Internet
    No dobra, a zasadnicze pytanie - w końcu co nie działa jak należy ?
  • #3 24 Lut 2013 14:27
    kamilalek1
    Telefon lub komputer z WIN 7 da rade się połączyć z serwerem VPN,
    ale nie wczytuje się żadna strona www np wp.pl, google.pl czy tez ip routera 192.168.100.1
  • #4 24 Lut 2013 14:35
    salmon
    po pierwsze uruchom NAT, po drugie - co masz w tablicy filter ?
    czy na malince działa jakiś serwer http ?
  • #5 24 Lut 2013 15:40
    kamilalek1
    NAT w routerze jest włączony porty również są przekierowane.
    Na maline nie działa żaden serwer http
    nie wiem gdzie są tablice filter
  • #6 24 Lut 2013 15:59
    salmon
    Kod:
    Po tym wnioskuję, że NAT jednak nie jest uruchomiony - brak wpisu świadczącego o tym "fakcie".
    tablica filter to tablica domyślna, ta która wyświetli się bez podawania parametru -t w iptables lub zdleklarowaniu jej w tym parametrze (czyli zawartość tablicy pokaże "iptables -L" lub "iptables -t filter -L")
    jeśli na malinie nie ma serwera http, to się nie dziw, że nic Ci się nie wyświetla żadna strona, jak w przeglądarce wpisujesz adres maliny...
  • #7 24 Lut 2013 16:07
    kamilalek1
    Widziałeś co pisałem wczesniej ip maliny to 192.168.100.105 a 192.168.100.1 to jest ip routera a na nim jest serwer http
    Jak w takim razie uruchomić serwer NAT, wydaje mi sie ze jest on niepotrzebny bo przecież mogę połączyć się z serwerem VPN tylko ze nic nie działa
  • #8 24 Lut 2013 16:13
    salmon
    Heh, racja, my fault, niedzielne rozkojarzenie :)
    Czy po połączeniu z vpn przechodzi ping do adresu 100.105 i 100.1 ?
  • #10 24 Lut 2013 16:33
    salmon
    pokaż tablicę filter (iptables -L)
  • #11 24 Lut 2013 16:34
    kamilalek1
    Code:
    pi@raspberrypi ~ $ sudo iptables -L
    Chain FORWARD (policy ACCEPT)
    Ale porty na raspberry pi są odblokowane bo gdyby był zablokowane to by nie połączyło z serwerem
  • #12 24 Lut 2013 16:35
    salmon
    ojej, myślałem, że się reszty domyślisz: sudo iptables -L
    Owszem, są (nawet wszystkie), ale wolałem sprawdzić to zanim zaczniemy szukać w innym miejscu.
    Będziemy próbować:
    w pptpd.conf: odblokuj remoteip z kilkoma adresami, na które nie będzie zachodzić zakres serwera dhcp z routera
    w pptpd-option: zmniejsz mtu i mru do 1450, dodaj opcje novj i novjccomp
    Na początek musi przechodzić ping do serwera vpn.
  • #13 24 Lut 2013 17:25
    kamilalek1
    Rozwiązanie problemu było znacznie prostsze
    przez pomyłkę nie odznaczyłem # przy remoteip
    Code:
