Nokia e52 - Nie uruchamia się, tylko wibracja, dead phone flash nie działa
stachu_22 18 Mar 2014 20:50
  • #1 18 Mar 2014 20:50
    stachu_22
    Witam, mam nokię e52 która tylko wibruje przy próbie włączenia. Ponoć wcześniej zapalał się na biało wyświetlacz, teraz już tego nie ma. Phoenix pokazuje coś takiego przy dwóch różnych softach:
    hing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15168 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000030000022600010007600C192102011104
    EM Asic ID is: 00001040
    EM Asic ID is: 00001030
    Public ID is: 21300203CC6C034449CB4F73EA7B0DE34E4FCA85
    Asic Mode ID: 00
    Hash: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Manufacturer code: 0020
    Device ID: 0040
    Revision ID: 0031
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Device ID: 0040
    Revision ID: 0031
    Loading update server code: 868592 bytes
    Update server loaded
    Asic CMT: Start programming 173188 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recovering phone
    Initializing
    --Tutaj pojawia się komunikat z prośbą o wypięcie i wpięcie kala usb i kliknięcie ok--
    Disconnect and connect
    Unable to set the phone to flash mode. Unable to flash.
    All operations completed
    Product flashing aborted
    i błąd:
    Flashing finalization failed. Do you like to retry the finalizing?
    HRESULT 0x8421001c (-2078212068)
    Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
    Próbowałem wgrać dwa różne softy, bateria w pełni naładowana.
  • #2 18 Mar 2014 22:05
    czarny244
    Skoro phoenix w trybie martwym nie skutkuje to stawiam na uwalony procek typowa usterka fabryczna.No chyba że zrobiłeś downgrade z niewiedzy i poszedł imei jednak telefon powinien wstać.
  • #3 19 Mar 2014 16:36
    stachu_22
    Dzięki za podpowiedź. Ja żadnego downgrade nie robiłem, pobrałem tylko soft, wybrałem produkt, flashing ---> wybór softu ---> dead phone USB flashing i refubrish. Może ktoś wcześniej coś przekombinował? Jak to sprawdzić?
    Co do procka to czytałem gdzieś, że można go sprawdzić poprzez mocne schłodzenie. Telefon wylądował w zamrażalce i sprawdzę czy będzie jakiś efekt. To jest uszkodzenie procka samego w sobie czy może zimne luty i wygrzanie pomoże? Ma ktoś jeszcze jakieś pomysły? Ten najgorszy scenariusz mnie trochę zasmuca..
  • #4 19 Mar 2014 16:37
    grubas
    Poziom 40  
    Niestety. Wada fabryczna.
    Jeśli fon tylko wibruje to uszkodzony może być jeszcze D3300, N3301, GAZOO lub proc ( najbardziej prawdopodobne - telefon na złom ).
  • #5 19 Mar 2014 17:00
    stachu_22
    No wcześniej podobno telefon jeszcze zapalał na chwilę wyświetlacz po czym gasł. A możesz kolego zarzucić jakimś schematem albo powiedzieć mniej więcej które to układy? Znalazłem taki http://obrazki.elektroda.pl/3172250000_1319650863.jpg ale nie widze tych układów o których mówiłeś.
    Jest mały postęp:
    Po błędzie:
    Odpiąłem kabel z telefonu, wyjąłem baterię, podpiąłem kabel i trzymałem wciśnięty włącznik wsadzając baterię. Nacisnąłem retry i jest:
    log:
    Recovering phone
    Initializing
    Phone recovery completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Failed to verfy communication to product
    Communication verified
    i błąd:
    HRESULT 0x8421001f (-2078212065)
    Firmware: Failed to switch phone to correct mode for factory settings using USB.
  • #7 19 Mar 2014 22:47
    prezes94
    Na pewno zamrażarka pomoze;D jak zmarłemu kadzidło...Płyta do wywalania,przerabiałem to w E52 kilkanascie razy.
  • #8 22 Maj 2014 17:36
    stachu_22
    Niestety ani zmrożenie ani wygrzanie płyty nie pomogło. Płyta została wymieniona.
  Szukaj w 4mln produktów
Przeglądaj produkty
