Kto moze to przetłumaczyc na jezyk polski :)
Chester452 20 Lis 2005 17:23 1011 3
  • #1 20 Lis 2005 17:23
    Chester452
    siemka jak by ktos mogl to bym prosil o przetlumaczenie to na jezyk polski :) i tak zeby tez dzialalo z gory dziex
    #include <stdio.h>
    #include <ctype.h>
    #define String_Length 80
    #define Squares 9
    typedef char Square_Type;
    typedef Square_Type Board_Type[Squares];
    const Square_Type Empty = ' ';
    const int Infinity = 10; /* Higher value than any score */
    const int Maximum_Moves = Squares; /* Maximum moves in a game */
    int Total_Nodes; /* Nodes searched with minimax */
    /* Array describing the eight combinations of three squares in a row */
    #define Possible_Wins 8
    const int Three_in_a_Row[Possible_Wins][3] = {
    { 0, 1, 2 },
    { 3, 4, 5 },
    { 6, 7, 8 },
    { 0, 3, 6 },
    { 1, 4, 7 },
    { 2, 5, 8 },
    { 0, 4, 8 },
    { 2, 4, 6 }
    /* Array used in heuristic formula for each move. */
    const int Heuristic_Array[4][4] = {
    { 0, -10, -100, -1000 },
    { 10, 0, 0, 0 },
    { 100, 0, 0, 0 },
    { 1000, 0, 0, 0 }
    /* Structure to hold a move and its heuristic */
    typedef struct {
    int Square;
    int Heuristic;
    } Move_Heuristic_Type;
    /* Clear the board */
    void Initialize(Board_Type Board) {
    int I;
    for (I = 0; I < Squares; I++)
    Board[I] = Empty;
    /* If a player has won, return the winner. If the game is a tie,
    return 'C' (for cat). If the game is not over, return Empty. */
    Square_Type Winner(Board_Type Board) {
    int I;
    for (I = 0; I < Possible_Wins; I++) {
    Square_Type Possible_Winner = Board[Three_in_a_Row[I][0]];
    if (Possible_Winner != Empty &&
    Possible_Winner == Board[Three_in_a_Row[I][1]] &&
    Possible_Winner == Board[Three_in_a_Row[I][2]])
    return Possible_Winner;
    if (Board[I] == Empty)
    return Empty;
    return 'C';
    /* Return the other player */
    Square_Type Other(Square_Type Player) {
    return Player == 'X' ? 'O' : 'X';
    /* Make a move on the board */
    void Play(Board_Type Board, int Square, Square_Type Player) {
    Board[Square] = Player;
    /* Print the board */
    void Print(Board_Type Board) {
    int I;
    for (I = 0; I < Squares; I += 3) {
    if (I > 0)
    printf("---+---+---\n");
    printf(" %c | %c | %c \n", Board[I], Board[I + 1], Board[I + 2]);
    printf("\n");
    /* Return a heuristic used to determine the order in which the
    children of a node are searched */
    int Evaluate(Board_Type Board, Square_Type Player) {
    int I;
    int Heuristic = 0;
    int J;
    int Players = 0, Others = 0;
    for (J = 0; J < 3; J++) {
    Square_Type Piece = Board[Three_in_a_Row[I][J]];
    if (Piece == Player)
    Players++;
    else if (Piece == Other(Player))
    Others++;
    Heuristic += Heuristic_Array[Players][Others];
    return Heuristic;
    /* Return the score of the best move found for a board
    The square to move to is returned in *Square */
    int Best_Move(Board_Type Board, Square_Type Player, int *Square, int Move_Nbr,
    int Alpha, int Beta) {
    int Best_Square = -1;
    int Moves = 0;
    int I;
    Move_Heuristic_Type Move_Heuristic[Squares];
    Total_Nodes++;
    /* Find the heuristic for each move and sort moves in descending order */
    for (I = 0; I < Squares; I++) {
    if (Board[I] == Empty) {
    int Heuristic;
    int J;
    Play(Board, I, Player);
    Heuristic = Evaluate(Board, Player);
    Play(Board, I, Empty);
    for (J = Moves-1; J >= 0 &&
    Move_Heuristic[J].Heuristic < Heuristic; J--) {
    Move_Heuristic[J + 1].Heuristic = Move_Heuristic[J].Heuristic;
    Move_Heuristic[J + 1].Square = Move_Heuristic[J].Square;
    Move_Heuristic[J + 1].Heuristic = Heuristic;
    Move_Heuristic[J + 1].Square = I;
    Moves++;
    for (I = 0; I < Moves; I++) {
    int Score;
    int Sq = Move_Heuristic[I].Square;
    Square_Type W;
    /* Make a move and get its score */
    Play(Board, Sq, Player);
    W = Winner(Board);
    if (W == 'X')
    Score = (Maximum_Moves + 1) - Move_Nbr;
    else if (W == 'O')
    Score = Move_Nbr - (Maximum_Moves + 1);
    else if (W == 'C')
    Score = 0;
    else
    Score = Best_Move(Board, Other(Player), Square, Move_Nbr + 1,
    Alpha, Beta);
    Play(Board, Sq, Empty);
    /* Perform alpha-beta pruning */
    if (Player == 'X') {
    if (Score >= Beta) {
    *Square = Sq;
    return Score;
    } else if (Score > Alpha) {
    Alpha = Score;
    Best_Square = Sq;
    } else {
    if (Score <= Alpha) {
    *Square = Sq;
    return Score;
    } else if (Score < Beta) {
    Beta = Score;
    Best_Square = Sq;
    *Square = Best_Square;
    if (Player == 'X')
    return Alpha;
    else
    return Beta;
    /* Provide an English description of the score returned by Best_Move */
    void Describe(int Score) {
    if (Score < 0)
    printf("You have a guaranteed win.\n");
    else if (Score == 0)
    printf("I can guarantee a tie.\n");
    else
    printf("I have a guaranteed win by move %d.\n",
    Maximum_Moves - Score + 1);
    /* Have the human or the computer move */
    void Move(Board_Type Board, Square_Type Player, int Move_Nbr) {
    int Square;
    Total_Nodes = 0;
    Describe(Best_Move(Board, 'X', &Square, Move_Nbr, -Infinity, Infinity));
    printf("%d nodes examined.\n", Total_Nodes);
    Play(Board, Square, 'X');
    printf("Move #%d - X moves to %d\n", Move_Nbr, Square + 1);
    } else {
    do {
    printf("Move #%d - What is O's move? ", Move_Nbr);
    scanf("%d", &Square);
    Square--;
    } while (Board[Square] != ' ');
    Play(Board, Square, 'O');
    /* Play a game of tic-tac-toe */
    void Game() {
    Square_Type Player;
    char Answer[String_Length];
    Board_Type Board;
    int Move_Nbr = 1;
    Initialize(Board);
    printf("\nDo you want to move first? ");
    scanf("%s", Answer);
    if (toupper(Answer[0]) == 'Y')
    Player = 'O';
    else
    Player = 'X';
    while(Winner(Board) == ' ') {
    Print(Board);
    Move(Board, Player, Move_Nbr);
    Player = Other(Player);
    Move_Nbr++;
    Print(Board);
    if (Winner(Board) != 'C')
    printf("%c wins!\n", Winner(Board));
    else
    printf("It's a tie.\n");
    int main() {
    printf("Welcome to Tic-Tac-Toe!\n\n");
    printf("Here is the board numbering:\n");
    printf(" 1 | 2 | 3\n");
    printf(" 4 | 5 | 6\n");
    printf(" 7 | 8 | 9\n");
    printf("\n");
    printf("Computer plays X, you play O.\n");
    do {
    Game();
    printf("\nDo you want to play again? ");
    } while (toupper(Answer[0]) == 'Y');
  • #2 21 Lis 2005 15:38
    Misholotti
    jest to po prostu gra w kółko i krzyżyk :D A dokładniej algorytm :)
  • #3 23 Lis 2005 12:49
    Chester452
    wlasnie wiem ze to jest kolko i krzyzyk tylko ze potrzebuje taka gre na lab z infy i ale raczej musi byc po polsku :) a nie po angielsku tak wiec byl bym bardzo wdzieczny za przerobienie tego bna polski :) dziex
  • #4 23 Lis 2005 13:01
    Loker
    Poziom 37  
    A co tu do przerabiania? Przetlumaczyc komunikaty i ewentualnie komentarze...
 Szukaj w ofercie
