| Author |
Message
Radek2 Poziom 13
#1
30 Nov 2005 11:30 SHARP AL-840 i błąd E07 - 05 |
Dostałem do konserwacji urządzenie jak w temacie. Po wyczyszczeniu optyki i lasera pojawił się błąd E07 - 05. Nie bardzo wiem co to za błąd, może ktoś wie i mógłby pomóc. Z góry wielkie dzięki.
| Back to top |
Google
30 Nov 2005 11:30 |
| Back to top |
janowak Poziom 8
#2
30 Nov 2005 13:22 Re: SHARP AL-840 i błąd E07 - 05 |
chetnie bym zamieścił manuala ale "waży" 17mb
jesli pomoże to ten błąd E07 - 05 znaczy:
Shading correction (dark component) trouble
DETAIL 1) Dark component level output is abnormal during shading correction.
2) Dark component level output is not recognized normally during shading correction.
a możliwe uszkodzenia:
TROUBLE POSITION
CAUSE
Scanner (reading) optical system does not transmit images (light) normally.
1) Scanner (reading) optical parts installing position shift
REMEDY (Check)
(CCD unit, lens, mirror, copy lamp, copy lamp light quantity sensor, shading correction sheet)
(Remedy)
1) Scanner (reading) optical parts installing position adjustment
(After work)
1) Copy density adjustment
albo:
TROUBLE POSITION
CAUSE
Dark component output level recognition error during shading correction
1) CCD unit trouble
2) MCU PWB image signal (CCD) input circuit trouble
REMEDY (Check)
1) CCD unit output
(Remedy)
1) CCD unit replacement
2) MCU PWB replacement
(After work)
1) When the MCU PWB is replaced, perform simulations to input various set values and
adjustment values.
2) When the CCD unit is replaced, adjust.
lub:
TROUBLE POSITION
CAUSE
Copy lamp light quantity abnormality
1) Copy lamp trouble
2) Copy lamp control PWB rouble
3) Copy lamp light quantity adjustment trouble
REMEDY (Check)
1) Copy lamp
3) Copy lamp light quantity level
(Remedy)
1) Copy lamp replacement
2) Copy lamp control PWB replacement
3) Copy lamp light quantity level adjustment
(After work)
| Back to top |
Radek2 Poziom 13
#3
30 Nov 2005 16:31 Re: SHARP AL-840 i błąd E07 - 05 |
Dzięki za informację, ale czy jest możliwe, żeby podczas czyszczenia wystąpiły takie błędy? Wygląda to na uszkodzenie optyki, ale wizualnie wszystko jest ok.. Przed rozkręceniem wszytsko było ok. prócz jakości wykonywanej kopii.
| Back to top |
Google
30 Nov 2005 16:31 |
| Back to top |
Radek2 Poziom 13
#4
03 Dec 2005 18:37 Re: SHARP AL-840 i błąd E07 - 05 |
Po dokładnym oglądnięciu wszystkich czujników zauważyłem, że czujnik początku plamki lasera ma zimny lut, po przelutwaniu błąd E07 - 05 przestał się pojawiać. Trochę mnie to dziwi, ponieważ błąd według serwisówki oznacza uszkodzenie optyki- więc czemu przlutowanie czujnika plamki usunęło problem?
Błąd E07 - 05 przestał się pojawiać, ale zaczął się pojawiać błąd E07 - 04, czyszczenie listwy poziomu bieli nie daje żadnego rezultatu, może ktoś z forumowiczów wie jaka może być przyczyna?
| Back to top |
Goshky Poziom 18
#5
03 Dec 2005 22:50 Re: SHARP AL-840 i błąd E07 - 05 |
A nie ruszyłeś czasem za dużo przy czyszczeniu?
Jeśli ruszyłeś kamerę CCD to będzie duży problem z ustawieniem.
| Back to top |
Google
03 Dec 2005 22:50 |
| Back to top |
tito Poziom 17
#6
26 Mar 2007 21:54 Re: SHARP AL-840 i błąd E07 - 05 |
Podłączę się do tematu, bo podobnie jak u kolegi po wyczyszczeniu lasera (lusterek + lustro wirujące) i szyby skanerau rządzenie wyrzuca kod E - 7 - 05. Pytanie moje to czy ten kod jest związany wyłącznie ze skaneremczy też z zespołem lasera, bo nie wiem gdzie szukać przyczyny, bo urządzenie przed rozkręceniem działało ( kopia nienajlepsza, ale działało ) , a teraz lipa. Czy jest jakiś kod od kalibracji?
| Back to top |
horse667 Poziom 20
Joined: 18 Jun 2005 Posts: 1079 Location: Wrocław nocą/Zumaraga
#7
27 Mar 2007 21:07 Re: SHARP AL-840 i błąd E07 - 05 |
Witam, wtące swoje 3 grosze. Zacznę od tego, że to wyjątkowo nieudany model, (nawet jak na shrpa :). Ale wracając do kodu błędu, walczyłem z podobnymi objawami niejednokrotnie. I mam takie spostrzeżenia:
W/w błedy, są w tej maszynie często nie logiczne, właśnie tak jak mówi serwisówka, że to optyka, a po rozebraniu lasera zaczyna chodzić itp.
Zaleciłbym następujące działania:
Czyszczenie optyki, wraz z z białym paskiem pod szybą, czyszczenie lasera, sprawdzenie taśmy zasilającej lampę skanera (lampa ma się cały czas świecić), ewentualnie podmianę całego skanera.
Kiedyś walczyłem z tą maszyną chyba z tydzień, żąglowałem modułami i w końcu z trzech zrobiłem jedną sprawną.
Pozdrwiam horse
| Back to top |
tito Poziom 17
#8
01 Apr 2007 18:21 Re: SHARP AL-840 i błąd E07 - 05 |
Swój problem zamykam, u mnie prawdopodobnie błąd tkwił w skręceniu zespołu lasera, a mianowicie tego półokrągłego lusterka nad silnikiem lasera, które niby wchodzi na takie małe wypustki, ale jest tam minimalna regulacja. Dzięki i pozdrawiam.
| Back to top |
