| Author |
Message
adikos Poziom 5
#1
27 Jul 2006 14:09 Ciągłe restarty i zwisy |
Mam płyte główną Jetway p4xfcu mam z nią problem związany z ciągłymi resetami i zwisami moja konfiguracja to:
celeron 2.4 northwood
zasilacz Enlight 350W
karta graficzna radeon 9550 128/128
dysk twardy samsung spinpoint 80GB
2 kośći pamieci pierwasza blitz 256 /400mhz druga Twinmos 256/266mhz
w programie Microsoft Debugging Tools wygenerował taki błąd
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini072706-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
Debug session time: Thu Jul 27 12:37:58.951 2006 (GMT+2)
System Uptime: 0 days 2:46:55.522
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {548b0067, 2, 1, 806f26e0}
ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,214600,41108004
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** WARNING: Unable to verify timestamp for cmuda.sys
*** ERROR: Module load completed but symbols could not be loaded for cmuda.sys
Probably caused by : hardware ( cmuda+288c )
Followup: MachineOwner
kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 548b0067, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 806f26e0, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
548b0067
CURRENT_IRQL: 2
FAULTING_IP:
hal+66e0
806f26e0 2408 and al,8
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xA
MISALIGNED_IP:
hal+66e0
LAST_CONTROL_TRANSFER: from 00000000 to 806f26e0
SYMBOL_ON_RAW_STACK: 1
STACK_ADDR_RAW_STACK_SYMBOL: 17002000010004
STACK_COMMAND: dds 8221A6F4-0x20 ; kb
STACK_TEXT:
8221a6d4 822a2b28
8221a6d8 0000001e
8221a6dc 00000002
8221a6e0 806f26e0 hal+0x66e0
8221a6e4 00000008
8221a6e8 00010282
8221a6ec 00000000
8221a6f0 f7e0e88c cmuda+0x288c
8221a6f4 00000000
8221a6f8 0002000e
8221a6fc 6d665346
8221a700 81703e00
8221a704 816dd7c0
8221a708 0a060002
8221a70c 63504354
8221a710 98000197
8221a714 00000001
8221a718 82210000
8221a71c 00040001
8221a720 00000000
8221a724 8221a724
8221a728 8221a724
8221a72c 821f19d8
8221a730 00000000
8221a734 00000000
8221a738 0a140006
8221a73c c3646641
8221a740 0000afd8
8221a744 00000000
8221a748 00000000
8221a74c 822182a8
8221a750 821e6600
FOLLOWUP_IP:
cmuda+288c
f7e0e88c ?? ???
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: hardware
SYMBOL_NAME: cmuda+288c
MODULE_NAME: hardware
FAILURE_BUCKET_ID: IP_MISALIGNED
Prosił bym was o porady związane tym problemem
| Back to top |
Google
27 Jul 2006 14:09 |
| Back to top |
konmaj Poziom 23
#2
27 Jul 2006 16:30 Czy te restarty i zwisy |
były od początku używania tego komputera? Jeśli tak, to ja podejrzewam nieprawidłową współpracę kości pamięci - są różnych firm, do tego jedna taktowana 400, a druga 266MHz. Polecałbym wyjąć jedną kość, włączyć komputer i popracować na nim jakiś czas...
| Back to top |
Google
27 Jul 2006 16:30 |
| Back to top |
tronic1 Poziom 26
Joined: 06 Feb 2005 Posts: 20258 Location: Police, Alesund-Norwegia
#3
27 Jul 2006 16:34 Ciągłe restarty i zwisy |
Pamięć proszę przetestować Memtestem
www.memtest86.com
Proszę zmierzyć miernikiem napiecia z zasilacza.Temperatury są monitorowane ?
| Back to top |
Google
27 Jul 2006 16:34 |
| Back to top |
adikos Poziom 5
#4
27 Jul 2006 16:53 Re: Ciągłe restarty i zwisy |
Komputer mam stale monitorowany przez everesta i aide robią mi sie te restarty tylko na tej płyćie głównej bo miałem mobo MSI wcześniej i takie cyrki mi sie nierobiły tylko że poszła do serwisu z powodu USB i teraz sie męcze na tym Jetway podaje wartośći zasilacza
Wartości napięć
Napięcie rdzenia procesora 1.50 V
+3.3 V 3.31 V
+5 V 5.03 V
+12 V 11.92 V
-12 V -12.03 V
+5 V podczas wstrzymania pracy 4.78 V
VBAT baterii CMOS 3.28 V
| Back to top |
tronic1 Poziom 26
#5
27 Jul 2006 17:28 Ciągłe restarty i zwisy |
Kolego,napięcia należy mierzyć tylko i wyłącznie MIERNIKIEM.Zrób test pamięci.
| Back to top |
adikos Poziom 5
#6
27 Jul 2006 17:35 Re: Ciągłe restarty i zwisy |
wszystko wskazuje na pamiec bo w książce z tej płyty pisze ze obsługuje tylko pamieci 266 i 200 a ja mam 266 i 400 czy to coś może robić a miernik musze pożyczyć bo niemam
| Back to top |
Google
27 Jul 2006 17:35 |
| Back to top |
tronic1 Poziom 26
#7
27 Jul 2006 18:33 Ciągłe restarty i zwisy |
Trzeci raz namawiam cię abyś przetestował RAM Memtestem.Najpierw jedną kość a potem drugą,jak bedzie bez błędów to obie na raz.
| Back to top |
