Jak wejść do biosu laptopa IBM thinkpad?
Emylus 21 Gru 2003 21:20 36108 9
  • #1 21 Gru 2003 21:20
    Emylus
    Wiem, że głupie ale próbuje i nie udaje mi się.
  • #2 21 Gru 2003 21:47
    andrew33
    Podaj jeszcze jaki model TP bo nie do każdego jednakowo się wchodzi.
  • #3 21 Gru 2003 21:54
    Pfikusny
    Na przykład w moim F1 przy starcie...
  • #4 21 Gru 2003 22:16
    Robert B
    Prościej wejść po prostu na stronę IBM i sprawdzić :)
    Cytuję za którymś z kolegów:
    Some bios key sequences:
    Del key with AMI or Award BIOS.
    Esc (some Toshiba systems)
    F1 (some Toshiba systems and some using Phoenix BIOS)
    F2 (some NEC systems)
    F10 (some Compaq systems)
    Ins (some IBM PS/2 models)
    On some Dell systems, you can press the Reset button twice.
    Ctrl-Alt-Enter works on some Dell systems
    Ctrl-Alt-? works on some IBM PS/2s
    Ctrl-Alt-Esc for some Award BIOS systems
    Ctrl-Alt-S for some Phoenix BIOS systems
    Ctrl-Alt-Ins for some other Phoenix BIOS systems
  • #5 21 Gru 2003 22:24
    andrew33
    W takim razie ja zacytuję IBM :D :
    G40, R40, R40e, R50, R50p, T40, T40p, T41, T41p, X40- Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the Access IBM Predesktop Area, and then select Start setup utility to open the IBM BIOS Setup Utility.
    240 series
    390 series
    570 series
    i Series 1200
    i Series 1300
    i Series 1400
    i Series 1500
    i Series 172x
    A20, A21, A22, A30, A31
    R30, R31, R32,
    S30, S31
    T20, T21, T22, T23, T30
    X20, X21, X22, X23, X24, X30, X31
    TransNote - Pressing F1 during startup when the ThinkPad logo is displayed.
    310, 315
    310E/ED
    315ED - BIOS Utility is entered by holding F2 while the ThinkPad logo is displayed after power on.
    365C/CS
    365CD/CSD
    365E/ED - Enter setup by pressing CTRL+Alt+F11 from a DOS prompt (you must be in DOS mode, not a DOS session under Windows).
    365X/XD - With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears
    360, 355 series
    380, 385 series
    560 series
    600 series
    701C/CS
    75x series
    76x series
    770 series - With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears.
    NOTE: On the TP 701, you can also access the Configuration area on BIOS by pressing the Fn+F1 keys.
    500, 510 Enter setup by pressing CTRL+Alt+F3 from a DOS prompt (you must be in DOS mode, not a DOS session under Windows).
    700/C
    720/C - Pressing CTRL+ALT+INS when the cursor moves over to the upper right hand side of the screen right after the memory count.
    710T
    730T - Hold the suspend/resume switch while powering on the computer.
  • #6 22 Gru 2003 20:02
    Emylus
    Dzięki F1 działa tylko że po wyłączeniu a nie restarcie jak ja robiłem. Model to 600X.
  • #7 10 Lut 2005 09:09
    D.M
    Model T41 2373 - do biosu wchodzi się poprzez F12 - sprawdzone
  • #8 12 Lis 2007 13:20
    Kamil1987
    IBM 600E F1 nie działa :| Różne kombinacje próbowałem i nic, helpnijcie.
  • #9 19 Gru 2007 16:09
    DanieLLo1991
    f1
    alt+f2
    albo mozesz sie pobawic naciskajac f12 i tam właczyc biosa
  • #10 19 Gru 2007 16:10
    Kamil1987
    Temat już odszedł w zapomnienie na 20 laptopów w pełni działają 3 - 4 ...
