Ukryte Strony w Pentagram Cerberus ADSL WIFI 802.11g Plus
medcom 29 Mar 2008 17:45
  • #1 29 Mar 2008 17:45
    medcom
    Ukryte Strony w Pentagram Cerberus ADSL WIFI 802.11g Plus nie które niedziałają z oprogramowaniem z pentagrama
    192.168.1.254/PortCtrl.asp = Ethernet Port Control (Speed and mode settings)
    192.168.1.254/StaticArp.asp = Static Arp Config
    192.168.1.254/StaticRoute.asp = Static Route Config
    192.168.1.254/adsl.asp = DSL Stats (SNR, Noise, Sync etc etc ...)
    192.168.1.254/adsl_diag.asp = ADSL Line Analyzation (Logs COMPLETE Instant ADSL Stats)
    192.168.1.254/arp.asp = ARP Table
    192.168.1.254/blkhack.asp = Intrusion Detection On/Off option page
    192.168.1.254/blkhackDisable.asp = Above Fowarded to this if Disabled
    192.168.1.254/blkhackEnable.asp = Above Fowarded to this is Enabled
    192.168.1.254/blockwan.asp = Block WAN Request On/Off option page
    192.168.1.254/config.asp = Backup/Restore Config page
    192.168.1.254/customer.asp = Lists some info such as firmware,WAN, also admin password in plain text
    192.168.1.254/ddns.asp = Dynamic DNS On/Off
    192.168.1.254/ddnsDisable.asp = Dynamic DNS Off
    192.168.1.254/ddnsEnable.asp = Dynamic DNS On
    192.168.1.254/dhcp.asp = DHCP Config
    192.168.1.254/dhcp_disable.asp = Diasble DHCP and Relay Agent
    192.168.1.254/dhcp_relay.asp = Relay Agent Config
    192.168.1.254/dhcp_server.asp = DHCP server Config
    192.168.1.254/dhcptable.asp = DHCP Table
    192.168.1.254/dns_conf.asp = DNS Config
    192.168.1.254/do_hostscript.asp = ???? Browser Timeout but lights flashed on modem
    192.168.1.254/do_upgrade_firmware.asp = ???? Timeout
    192.168.1.254/home.asp = As it says Home (Main Status Page)
    192.168.1.254/hostname.asp = Hostname for Router (defualt home.gateway)
    192.168.1.254/ic.asp = Parameters (max connections etc...)
    192.168.1.254/igmp.asp = IGMP parameters / config
    192.168.1.254/iptv.asp = Noise margin options, "test" & "others" seem to increase sync
    192.168.1.254/lan_conf.asp = LAN side of router config
    192.168.1.254/lan_conf_apply.asp = Apply Page for above (Froze Modem when loading strait to this)
    192.168.1.254/language.asp = Blank
    192.168.1.254/lconf.asp = Blank
    192.168.1.254/left.asp = Blank
    192.168.1.254/locale_en.asp = Returns Me to Status Page/ index.htm/ home.asp
    192.168.1.254/locale_other.asp = As Above " " " "
    192.168.1.254/lstat.asp = Blank
    192.168.1.254/mac.asp
    192.168.1.254/macf.asp
    192.168.1.254/macf1.asp
    192.168.1.254/maclist.asp
    192.168.1.254/misc.asp
    192.168.1.254/pf.asp
    192.168.1.254/pf1.asp
    192.168.1.254/pf1.asp~
    192.168.1.254/port_status.asp
    192.168.1.254/pppoa_edit.asp
    192.168.1.254/pppoe_edit.asp
    192.168.1.254/pwdadmin.asp
    192.168.1.254/pwdadmin_edit.asp anchor
    192.168.1.254/pwduser_create.asp
    192.168.1.254/pwduser_delete.asp
    192.168.1.254/pwduser_edit.asp
    192.168.1.254/qadv.asp
    192.168.1.254/qfw.asp
    192.168.1.254/qlan.asp
    192.168.1.254/qos.asp
    192.168.1.254/qos1.asp
    192.168.1.254/qsys.asp
    192.168.1.254/quick.asp
    192.168.1.254/qvpn.asp
    192.168.1.254/qwan.asp
    192.168.1.254/qwireless.asp
    192.168.1.254/rbnosv.asp
    192.168.1.254/rbnosv_apply.asp
    192.168.1.254/remote.asp
    192.168.1.254/restore_frame.asp
    192.168.1.254/restore_progress.asp
    192.168.1.254/rfc1483_bridge_edit.asp
    192.168.1.254/rfc1483_routed_edit.asp
    192.168.1.254/route_delete.asp
    192.168.1.254/route_delete1.asp
    192.168.1.254/route_edit.asp
    192.168.1.254/route_edit1.asp
    192.168.1.254/routingtable.asp
    192.168.1.254/save.asp
    192.168.1.254/scanpvc.asp
    192.168.1.254/scanpvc_delay.asp
    192.168.1.254/scanpvc_frame.asp
    192.168.1.254/scanpvc_progress.asp
    192.168.1.254/scanpvc_result.asp
    192.168.1.254/seclog.asp
    192.168.1.254/setvs.asp
    192.168.1.254/setvs.asp~
    192.168.1.254/setvs1.asp
    192.168.1.254/static_arp_create.asp
    192.168.1.254/static_arp_delete.asp
    192.168.1.254/static_arp_edit.asp
    192.168.1.254/staticroute_create.asp
    192.168.1.254/staticroute_create1.asp
    192.168.1.254/syslog.asp
    192.168.1.254/tcwd.asp
    192.168.1.254/timezone.asp
    192.168.1.254/top.asp
    192.168.1.254/update.asp
    192.168.1.254/update_delay.asp
    192.168.1.254/update_frame.asp
    192.168.1.254/update_progress.asp
    192.168.1.254/upnp.asp anchor
    192.168.1.254/urlf.asp
    192.168.1.254/urlf1.asp
    192.168.1.254/urlfde1.asp
    192.168.1.254/urlfde2.asp
    192.168.1.254/vlan_port.asp
    192.168.1.254/wan_adv.asp
    192.168.1.254/wan_br_create.asp
    192.168.1.254/wan_br_del.asp
    192.168.1.254/wan_br_edit.asp
    192.168.1.254/wan_create_service.asp
    192.168.1.254/wipca.asp
    192.168.1.254/wipcaDisable.asp
    192.168.1.254/wipcaEnable.asp
    192.168.1.254/wireless.asp
    192.168.1.254/wireless_macfilter.asp
    192.168.1.254/wireless_macfilter1.asp
    192.168.1.254/wireless_maclist.asp
    192.168.1.254/wireless_security.asp
    192.168.1.254/wireless_security1.asp
    192.168.1.254/wireless_security2.asp
    192.168.1.254/wireless_security3.asp
    192.168.1.254/wireless_security_disable.asp
    192.168.1.254/wireless_status.asp
    192.168.1.254/wireless_txpower.asp = Wireless Signal Strength
  • #2 31 Maj 2008 12:51
    Erni1
    dobre, ale uruchomiłem http://192.168.1.254/PortCtrl.asp i nic nie można zmienić.
    A tak na boku małe pytanko:
    Mam kolesia który raz się dokłada do netu a raz niechcący zapomnie (począczony przez WIFI)
    Czy jest jakać opcja w tym routerze aby ustawić kilka haseł lub coś podobnego, tak aby wszystkim innym nie trzeba było zmnieniać przez jednego "zapominalskiego"
