| Author |
Message
shel82 Poziom 16
#1
15 Apr 2008 09:25 SE K750i - problem z wgraniem softu? |
Witam, jak w temacie - telefon nie żyje, zgłasza komunikacje, ale wyrzuca następujący błąd:
zrzut z LOGu:
09:20:47| XS++ v3.2 Dev1 (Crystal) Ready !
09:20:47| Executed on Microsoft Windows XP
09:20:57|
09:20:57| Attempting to open the interface...
09:20:57|
09:20:57| TURN OFF PHONE!
09:20:57| Hold 'C' button on phone and connect phone NOW.
09:20:57| You have 30 seconds...
09:20:57|
09:21:02| Baseband ID: 8040
09:21:02| Protocol Version: 3.1
09:21:02|
09:21:02| Sending db2010_cid00_prodid_p3l.bin...
09:21:03| Applet ID: 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L
09:21:03| This is a PRODUCTION_ID loader
09:21:03| Activating GDFS...
09:21:03| Phone name detected!
09:21:03|
09:21:03| Sending db2010_cid36red_flash_r2ab.bin...
09:21:04| Applet ID: 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB
09:21:04| This is a FLASH loader
09:21:04|
09:21:04| Profiling SEMC phone...
09:21:04| Platform: DB2010
09:21:04| OTP CID: 36
09:21:04| EROM CID: 36
09:21:04| EROM Color: Red
09:21:04| IMEI: 35655300xxxxxx
09:21:04| Phone ID: K750
09:21:04| Region: EMEA_1
09:21:04| CDA: CDA102337/12 R5A
09:21:04| Firmware Version: R1DB001
09:21:04| EROM: n/a
09:21:04| Ready for operation!
09:21:20| Running CID36 code...
09:21:27| ~~~~~~~~~~ Custpack information ~~~~~~~~~~
09:21:27| Custpack: EMEA_1 (CDA102338/36) (K750)
09:21:27| Generic(non-branded) custpack: No
09:21:27| Allowed languages: en, et, pl, lv, lt, ru, uk,
09:21:27| ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
09:21:31| Bypassing RSA...
09:21:31|
09:21:31| Sending db2010_cid00_prodid_r2f.bin...
09:21:32| Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F
09:21:32| This is a PRODUCTION_ID loader
09:21:32|
09:21:32| Sending db2010_cid00_cert_r2e.bin...
09:21:32| Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E
09:21:32| This is a CERTIFICATE loader
09:21:32| RSA security disabled!
09:21:32|
09:21:32| Sending db2010_cid36red_flash_r2ab.bin...
09:21:33| Applet ID: 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB
09:21:33| This is a FLASH loader
09:21:33| Now flashing firmware main...
09:21:33| Flashing c:\documents and settings\przemeksz\pulpit\nowy folder (2)\k750_r1ca021_main_red49.bin
09:21:33| Header type: BABE
09:21:33| 288 flashblocks
09:21:33| Binary acknowledge failed with: 15
09:21:33| Failed
z góry dzięki za podpowiedzi, dodam, że w setoolu też nie idzie :(
| Back to top |
Google
15 Apr 2008 09:25 |
| Back to top |
dickheadGSM Poziom 22
#2
15 Apr 2008 09:31 Re: SE K750i - problem z wgraniem softu? |
Jak wrzucasz na 36 49 to ja sie wcale nie dziwie. Zanies do sewisu bo niebawem bedzie drozej.
| Back to top |
Google
15 Apr 2008 09:31 |
| Back to top |
wanek Poziom 17
#3
15 Apr 2008 10:27 Re: SE K750i - problem z wgraniem softu? |
To są uroki jak ktoś nie poczyta a robi teraz leć do serwisu bo sam to tylko pogorszysz jak kolega napisał wyżej
| Back to top |
Google
15 Apr 2008 10:27 |
| Back to top |
pierooo Poziom 15
#4
15 Apr 2008 12:04 Re: SE K750i - problem z wgraniem softu? |
musisz miec naładowaną baterie do pełna,
poczytaj LINK
| Back to top |
shel82 Poziom 16
#5
16 Apr 2008 06:07 Re: SE K750i - problem z wgraniem softu? |
Fakt nie patrzyłem na nazwy plików, które po rozpakowaniu były inne niż w ściągniętym pliku :(
ok wgrałem FS, bo dało się wgrać, telefon ożył, ale w niewielkim stopniu, tzn. włącza się, ale brak podświetlania i karty sim dalej nie widzi (tu wina MAINa), ale i tak dalej nie mogę wgrać MAINa - wyskakuje ten sam błąd, dodam, że baterię naładowałem na max, nawet podmieniałem od innego, co jeszcze mogę domowymi sposobami zrobić?
| Back to top |
Google
16 Apr 2008 06:07 |
| Back to top |
shel82 Poziom 16
#6
17 Apr 2008 08:25 Re: SE K750i - problem z wgraniem softu? |
Ok telefon ożył, po raz kolejny miałem zły plik z softem, ściągałem z trzech różnych źróeł i wszystkie były złe, ale się udało...
| Back to top |
