NOKIA 6230i bład przy fleshowaniu
Post new topic  Reply to topic      Main Page -> Forum Index -> GSM -> GSM Service -> NOKIA 6230i bład przy fleshowaniu
Author
Message
kurczak_00
Post#1 Post from the author of the topic 23 Apr 2008 16:13
witam jak próbuje wgrac flasha do 6230i to MMC idzie bezproblemowo ale za to PPM przy kasowniu na 25% wywala bład
1st Boot Ok, TIKU, UPP: 1052
Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA
Fl1: 0x02000000-0x02FFFFFF,FFFDFFFD,
Algorithm: te_amd_b.fia, Ver: 4.57.0
Algorithm Ok, MSID: 8413844A4CEE17F60AAE516EAE
Decoded MSID: 80B0BAE9-009775BF-A8000000
Encoded FAID: 46CDCA79-3F2CB8C2-985902CB
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x009FFFFF Erased, Time: 01:37
Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:11
Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:40
MCU Flashing Completed, Time: 01:06
FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND]
Algorithm: te_essr.fia, Ver: 4.57.0
Alg Boot Error: 2
Error Data1:
00000000: 9F 01 04 00 EC 00 F8 22 00 00 11 00 10 00 02 FD ......."........
00000010: FF FD FF 00 00 00 00 00 00 04 00 00 01 00 00 00 ................
00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................
00000030: 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 29 ...............)
Error Data2:
00000000: F3 72 00 F8 22 00 00 11 00 10 00 02 FD FF FD FF .r.."...........
00000010: 00 00 00 00 00 00 04 00 00 01 00 00 00 00 00 00 ................
00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
00000030: 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 29 D3 72 00 ............).r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
co robic czekam na odp
Back to top
dickheadGSM
Post#2 23 Apr 2008 16:20
Re: NOKIA 6230i bład przy fleshowaniu
Zaistaluj paczke 3.88. Masz do wyboru 2 rodzaje flasha. MCU jest to samo ale PMM i CNT w 2 wersjach M i E. Proboj ktoras musi pojsc. Masz w logu algorytm ale nie pamietam do ktorej wersji on jest (czyli masz wrzucic ta druga).
Tu masz dokladnie
http://www.elektroda.pl/rtvforum/viewtopic.php?p=4927411#4927411
Back to top
kurczak_00
Post#3 Post from the author of the topic 23 Apr 2008 16:48
dalej blad
Algorithm Ok, MSID: 84503DC8EF03F26AF6EE0B70BC
Decoded MSID: 91DFBAE9-009775BF-A8000000
Encoded FAID: 9589F89F-7253A134-9EE430D5
Area2: 0x00010000-0x009FFFFF Erased, Time: 01:42
Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:12
Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:45
FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND]
Algorithm: te_oncsm.fia, Ver: 4.57.0
Erasing Mass Memory
Erasing Error: MM_2B_2, Time: 00:20
Co robic??
Back to top
Google
Google Adsense
Post# Post from the author of the topic 23 Apr 2008 16:48
Back to top
diablokomis
Post#4 23 Apr 2008 16:57
Czy telefon , sie włącza ?. Czy nie był zalany lub po upadku ? Jak masz możliwość to sprawdź kabel na innym fonie , lub sprawdź czy są przejścia do każdego pinu.
Back to top
Rhingsm
Post#5 23 Apr 2008 16:59
Powinienes wgrywać wersje M do telefonu.
Quote:
Fl1: 0x02000000-0x02FFFFFF,FFFDFFFD,(tu powinna być nazwa kości)
Przyłóż kabel bezpośrednio do płyty a jeżeli daje tam bedzie puste miejsce to kość flasha do przekulkowania.
Back to top
dickheadGSM
Post#6 23 Apr 2008 17:00
Zaktualizuj sobie FIA i lecisz full (mcu, pmmM,cntM)
Powinien wstac. Jak nie uszkodzenie HW.
Back to top
Google
Google Adsense
Post# 23 Apr 2008 17:00
Back to top
kurczak_00
Post#7 Post from the author of the topic 23 Apr 2008 19:52
jak mam to zaktualizowac??
Back to top
Google
Google Adsense
Post# Post from the author of the topic 23 Apr 2008 19:52
Back to top
Guest
Post#8 23 Apr 2008 20:00
Poprostu podmienić pliki. Poszukaj na elce pewnie ktoś wrzucał najnowsze fia.
Pozdr
Back to top
dickheadGSM
Post#9 23 Apr 2008 20:02
Zainstaluj najnowszego jafa i z katalogu ProgramFiles/ODEON/JAF/Flash skopiuj wszystkie pliki FIA (*.fia) do katalogu ProgramFiles/Nokia/Phoenix/Flash zastepujac istniejace.
That's all ;)
Jafika masz tu:
http://support.phone-tools.cn/files/JAF_Main_Software/
Back to top
kurczak_00
Post#10 Post from the author of the topic 24 Apr 2008 18:58
nie widzi tej drugiej kości która to jest na płycie ?? przekulkowac ja czy co dać nowa??
Back to top
Rhingsm
Post#11 24 Apr 2008 19:00
a czy po zaktualizowaniu fia i przyłożeniu kabla do płyty dalej ci jej nie widzi??
Back to top
kurczak_00
Post#12 Post from the author of the topic 24 Apr 2008 19:25
dalej nie widzi
Back to top
dickheadGSM
Post#13 24 Apr 2008 20:44
W tym wypadku przekulkowac, ale niekoniecznie kosc, rowniez uem i tiku.
Back to top
apap
Post#14 24 Apr 2008 22:10
To stary telefon i fia z całą pewnością nie trzeba aktualizować. Usterka jest ewidentnie hardwarowa - słyszał ktoś o flaszu, którego alias jest od FFFDFFFD? Podnieś go i zobacz, czy masz wszystkie pady, możliwe jest również uszkodzenie ścieżek na drodze do procka lub pady pod prockiem, choć to mało prawdopodobne, bo drugi flash czytany jest wzorcowo.
Back to top
amoralez
Post#15 25 Apr 2008 01:15
Jesli to log z tornado lub twistera ... a na to mi wyglada .. to masz uwalone biblioteki :) odinstaluj ufs suite ... i zainstaluj 3.03 od nowa ... przejdzie napewno :)
Pisze tak bo mialem ten sam problem i uwalilem pod rzad 2x 3650. W koncu sie okazało ze stykł reinstal aplikacji. Ale skoro koledzy wyzej piszą ze to HW ... to sie sprzeczac nie bede bo moge byc w błedzie.
Back to top
kurczak_00
Post#16 Post from the author of the topic 25 Apr 2008 16:13
moze ktos pokazac na zjd ktora to kosc??
Back to top
Google
Google Adsense
Post# Post from the author of the topic 25 Apr 2008 16:13
Back to top
dickheadGSM
Post#17 25 Apr 2008 16:35
Ta w szkle.
Back to top
Page 1 of 1
Similar topics
Nokia 6230i problem przy flashowaniu (8)
Bład przy wgrywaniu softu-Nokia N73 (23)
Nokia e52 bład przy próbie flashowania (10)
Nokia 1110-błąd przy fleshowaniu-nie kasuje0x012C000 (15)
Nokia e51 błąd przy fleshowaniu (39)
NOKIA 6630 padła przy fleshowaniu ! (3)
nokia 6310i - błąd przy fleshowaniu (7)
Nokia 6310i przy fleshowaniu komunikat (2)
Bład przy próbie flashowania 6230i (4)
Nokia 2700c bład przy próbie wgrywania Softa (5)
Page generation time: 0.506 seconds
elektroda.pl topic RSS feed
