palio weekend 1.6 16v alarm...
gawor06 11 Lip 2008 23:11 2424 6
  • #1 5334655
    gawor06
    witam ma ktoś jakąś instrukcje jak podłączyć alarm w tym aucie???
  • #2 5335789
    sadek1979
    Spec od samochodów
    sprubuj tak
    SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
    www.cobra.it
    Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
    as per the instructions given on the product installation manual.
    fipal98gbb.doc
    MAKE FIAT MOD. PALIO YEAR 98 ® PETROL
    DIESEL
    ALARM/SIREN
    POSITION
    Position the compact alarms and the sirens in the engine compartment, on the
    column of the shock absorber, passengers side.To pass the cables open the
    plastic bulkhead under the windshield wiper and use the original rubber provided
    of two holes whom one is free. You will find it near the fuse box.
    POWER SUPPLY + 30: connect to the 3 mm2 RED wire located in the 1 way black connector, in the
    upper right part of the fuse box.
    - 31: connect to the 2 mm2 BROWN wire located in the ground point behind the
    left lateral bulkhead, drivers side.
    IGNITION WIRE + 15/54: connect to the 3 mm2 ORANGE wire located in the wiring harness and
    coming out of the 4 way white connector of the ignition key.
    DIRECTION INDICATORS Connect to the 1,5 mm2 BLUE and BLUE/BLACK wires located in the wiring
    harness and coming out of the multiway white connector in the fuse box, the first
    in the upper front part of the fuse box.
    ELECTRIC WINDOWS Positive control signal
    Front window, driver’s side:
    cut the 2 mm2 WHITE/RED wire.
    Front window, passenger’s side:
    cut the 2 mm2 RED/GREEN wire.
    Connections are made directly in the wiring harness coming out of the original
    switches.
    CENTRAL DOORS LOCKING Negative control signal
    Connect to the 1,5 mm2 BLUE wire (lock) and WHITE wire (unlock) located in the
    wiring harness coming out of the rubber grommet of the front door, drivers side.
    IMMOBILISATION POINT 1 Fuel pump
    Cut the 1,5 mm2 BROWN/WHITE wire located in the multiway white connector,
    the first on the left of the fuse box.
    IMMOBILISATION POINT 2 +15 general
    cut the 3 mm2 ORANGE wire located in the wiring harness and coming out of the
    3 way white connector of the ignition key.
    BONNET SWITCH Install an additional switch on the front headlamp support plate, near the original
    bonnet stop rubber.
    DOORS SWITCH Connect to the 1 mm2 WHITE/BLUE wire located in the wiring harness of the 3
    way grey connector and coming out of the courtesy lamp.
    BOOT SWITCH Connect to the 1 mm2 WHITE/RED wire located in the wiring harness of the 2 way
    grey connector that comes out of the boots interior lamp.
  • #3 5335926
    gawor06
    a ma ktos moze jakiegos manuala po polsu bo z angielskim to krucho u mnie a jak przetłumacze translatorem z neta to wychodzi tak niezrozumiale że nie można się połapać...
  • #4 5355820
    gawor06
    jutro chce się wziąć za instalacje alarmu w moim palio i mam pyt... gdzie jest jakaś dziura do przedziału silnika bo chce podłączyć zasilanie z centralki alarmu do aku i nie wiem gdzie taka dziura jest...;/ i pod jaki kolor kabelków w aucie podpiąć kabelki od kierunków wychodzące z centralki???
  • #5 5355935
  • #6 5356096
    gawor06
    ok dzieki a teraz jeszcze jedno pyt. alarm ma wyjscie na sterowanie centralnym zamkiem, pod jakie kable w aucie (jakie kolory) i gdzie są podłączyć kabelki z centrali alarmu(otwieranie i zamykanie)???
  • #7 5356141
