MODEL YEAR(S)
CAMRY 1992 -1996
12 VOLT CONSTANT WHITE (+) and WHITE/RED (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GREEN (-) @ HEAD LIGHT SWITCH
PARKING LIGHTS ( + ) GREEN (+) @ BOTTOM OF FUSE BOX, See NOTE *1
POWER LOCK BLUE/WHITE (TYPE B) IN PASSENGER KICK PANEL, BLUE PLUG
POWER UNLOCK LIGHT GREEN/RED (TYPE B) IN PASSENGER KICK PANEL, BLUE PLUG
DOOR TRIGGER RED/WHITE (-) See NOTE *2
EXTRA INFORMATION
NOTE *1 the GREEN (+) PARKING LIGHT wire, is located in a WHITE plug, just below the fuses.
NOTE *2 to find this DOOR TRIGGER wire, remove the BLACK Plastic Air Duct covering the TOP RIGHT side of the FUSE BOX, this will let you access the 6-PIN Plug that contains this RED/WHITE(-) wire.
