#1 5699821 04 Lis 2008 09:32 pyzamen pyzamen Poziom 11 #1 5699821 04 Lis 2008 09:32 Witam ,potrzebuje schemacik jak podłączyć sterowanie c. zamka w hummer H2 2005, zamek jest zamontowany fabrycznie
#2 5699840 04 Lis 2008 09:43 carrier carrier Specjalista - Alarmy Samochodowe Pomocny post? (+3) #2 5699840 04 Lis 2008 09:43 POWER LOCK LIGHT BLUE (Negative (-)) @ BCM, PURPLE Plug, Pin B3, See NOTE *1 POWER UNLOCK WHITE (Negative (-)) @ BCM, PURPLE Plug, Pin B2, See NOTE *1 NOTE *1 The BCM is located behind the HEADLIGHT Switch. The BCM has 6-Plugs, with the PURPLE Plug on the Back of the Module. GPS RFID E-CALL DALLAS SONDY (CYFROWE) CAN FMS D8 TMR LITRAŻOWANIE DOJAZD SENT-GEO TERMOMETRY E-TOLL CAN-IMMO - 603612134 https://www.youtube.com/c/ZabezpieczAutoPL/videos https://www.facebook.com/Carrier-199222403426194/
