Jesst to model na chassis Q528.1E LA)
*mówi o tym pkt.8.2-8.5
*ostat.aktualizacja .20 jest mówiąć z lekka " danger" dla tego modelu powoduje co powoduje...ponadto producent zaleca uzywać Przy Upgrade flash > (usb flash) wielkosci 128-256Mb
*jest to chyba zaznaczone na stronie producenta Ph. tam gdzie jest mowa o firmware i upgrade
http://www.support.philips.com/support/html/index_global.html
Software history
Main modifications
Each release contains:
-- All solutions identified in earlier versions
-- Improved connectivity to improve compatibility with other external devices
-- As Philips pursuits to continuesly improve their products,it is possible
that the channels/preset list is affected after upgrading to a newer
software version. Therefore we recommend to re-install the
channels/presets after completing the software upgrade procedure.
Q581E_0.64.14.18
-- Swiss Teleraetia nagravision CAM recognized.
-- teletext reception on ORF1 and ORF2.
-- change VHF-III installation scan for France.
Q581E_0.64.14.17
-- Improved HDMI behaviour.
-- solution for brightness variations on 32PFL7862D
-- improved reception for Germany
Q581E_0.59.31.0
-- start-up behaviour improved
Q581E_0.59.28.0
-- picture improvements for 42PFL9900D and 52PFL9632D
Q581E-0.59.23.0
-- solved: M6 broadcaster(Luxembourg) could not be captured
Q581E-0.59.21.0
-- improved USB performance
-- improved channel installation
Q581E-0.59.19.0
-- solved: MUX reception Gilford (United Kingdom) not recognized
-- solved: teletext occasionally blocked
-- stability improvements for MHEG in in United Kingdom
-- color correction when switching from DVI to HDMI
-- picture improvement when PC is connected to TV with static content.
(Associate or link your external as 'PC' via the menu settings)
p.s
spróbuj "załadować " stare firmware > patrz str. producenta
*nie 20 a jakie z niższym nr.
Jak nie pójdzie trzeba udać się do serwisu PH. . onie przeszyją flash
Philips za pomocą ComPair
