HP 6122 sterowniki pod vistę - szukam.
jarbzyk 19 Sty 2009 15:13 2693 0
  • #1 6022247
    jarbzyk
    Witam,szukam sterowników do HP 6122 pod viste.Będę wdzięczny za link.Pozdrawiam i dzięki za pomoc.
    Już sobie poradziłem,poniżej sposób instalacji:
    HP is not providing a Windows Vista driver for the HP Deskjet 6122 printer. But there is an alternative way to get the printer working on Windows Vista. Just follow these steps:
    1. If your printer is connected to your computer, disconnect it.
    2. Click on the Start menu.
    3. Click on Control Panel
    4. Click on the Hardware & Sounds control panel.
    5. Click Printers.
    6. Click "Add a Printer"
    7. Click "Add a Local Printer"
    8. Check off the "Use an existing port" check box.
    9. In the list entitled "Use an existing port" choose "LPT1: (Printer Port)
    10. Click on the "Next" button
    11. Choose "HP" as the manufacturer from the list of manufacturers
    12. In the printers list that shows up, choose "Deskjet 990c"
    13. Click on the "Next" button
    14. In the text box called "Printer name" type "Deskjet 6122"
    15. Wait for the computer to say that the printer has been successfully added.
    16. Connect your printer to your computer (i.e. connect the cable to the USB port at the back of your computer.
    17. A "Found New Hardware" screen should show up. Click Cancel on this window. (if it keeps showing up, just keep on clicking cancel until no more windows pop up)
    18. Go back to the printer folder (i.e. the one where you clicked "Add a Printer"
    19. Right Click on "Deskjet 6122"
    20. Click on "Properties" in the menu that popped up.
    21. Select the "Ports" tab.
    22. Change the port from "LPT1" to "USB"
    23. Click on the "Apply" button.
    Pozdrawiam serdecznie.
