mam podobny problem.mianowicie nokia 2630 po kablu easy usb działa wszystko tj zmieniłem menu na polskie,ściągnąłem simlocka,zczytuje bez problemowo dane z telefonu.Problem powstaje gdy do tego tela lub jakiego kolwiek innego podłączam kabel"kopytko"czyli bez baterii w fonie.wyskakuje wtedy Phone not resonding,power on phone czy coś podobnego.A oto jaki log mi wyskakuje:
Phone is in: Phone is not responding, power on phone!
Phone is in: Normal mode
Scanning files, please wait...
Done
Selected Highest installed version: 05.61
Model: RM-298 ( RM-298)
V 05.61/18-04-08/RM-298 (c) Nokia
Production serial number FD1667323
Product code 0555113
Module code 0203304
Basic production code 0544206
Flash code
Order number
Long production SN 0
MCU SW V 05.61/18-04-08/RM-298/(c) Nokia
HW 6000
PCI
UEM 1328
UPP 12642
RFIC 0500
DSP P06w45.v48
LCD SUEZ
PPM V 05.61/18-04-08/RM-298/(c) Nokia/EA
BT MCM 2222-v101
Content Pack Content: o2_pre_uk/V 05.61/18-04-08/RM-298/(c) Nokia//
IMEI: 352068027758284
WARNING: VPP pin is not connected, disabling VPP.
FAILED to find USB Device.
Attach phone to usb port!
Switched to USB BUS
============= Set Flash mode for info =============
VBat is 3.86V
Vpp pin has 0.10V, Not Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
Boot...
Using Tx2 Data line.
Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit
============= Set FBus mode for info =============
VBat is 3.88V
Pins:
Switched to USB BUS
VBat is 3.89V
Pins:
Boot...
VBat is 3.87V
Pins:
Mbus 1, Box Tx 0, Box Rx 0, Bsi 0
Switched to service cable FBUS
VBat is 3.90V
Pins:
Boot...
VBat is 3.87V
Pins:
Using Account: 123458
Connect...
Resp:
o/0110/hello there
Login...
OK, available count
95/Added Panasonic X700 and VS3 and Alcatel E-xxx
Download lates version from
www.griffinteam.net
NK FLASH IMEI 10
NK 7250 to 7250i 10
NK FLASH+UEM IMEI 10
NK 7250i+FLASH+UEM 10
Panasonic x70 1
Maxon 792x 1
Maxon 797x 1
NK ESN FLASH 10
LG-G7050 1
Panasonic GD55 1
Siemens ST 55 1
Panasonic G50 1
NK ESN FLASH+UEM 10
Panasonic x60 1
Siemens ST 60 1
Sharp GX30/TM100 1
LG C3100/C1200/C1100/7100/G7120 1
LG-81XX 1
K700_1 0
K700_2 5
SiemensC62_1 0
SiemensC62_2 5
SiemensC62_3 0
SiemensC62_4 5
SiemensC62_5 5
Panasonic_A100 1
NKF 10
NKUF 10
NK_DCT4_PLUS 5
NK_DCT4_ASIC11 5
DCT4PLUS_NEW 5
Panasonic X700 1
Panasonic VS3 1
Alcatel E-xxx 10
Alcatel C 10
Alcatel E801 10
NK_BB5_CERT_REST 40
NK_BB5_PM_AUTH 0
LG_KE_CODES 10
NK_DCT4+_IMCHG 5
SE_K200 5
VODAFONE_225 10
V225_RST 10
SAGEM_X150 10
SE_224 0
SE_225 0
SE_226 20
CREDIT COUNT: 95;
Switched to USB BUS
Co jest nie tak?
