  • #1 6204583
    jony
    Specjalista elektronik
    Czy może ktoś skompilować ten kod mieszanka asemblera z C i umieścić tu wsad (HEX)
    ; Program		: t13pwm.asm
    ; Description		: Tiny13 Fast PWM and ADC Fan Controller
    ; Last Updated	        : 15 December 2008
    ; Author		: RWB
    ; IDE/Compiler  	: Atmel AVR Studio 4.14
    ; Programmer    	: AvrOspII v5.47 from Mike Henning
    ;               	: AVRJazz Tiny2313 Board
    .include "tn13def.inc"
    ; The Tiny13 Default Frequency Clock
    .equ F_CPU = 9600000
    .cseg
    ; Start on the flash ram's address 0
    .org 0
    main:   ldi R24,RAMEND         ; Initial Stack Pointer
    	out SPL,R24            ; SP = RAMEND
    ; Initial I/O
            ldi   R16,0b00000011   ; Set PB0=Output, PB1=Output, PB2=Input, PB3=Input, PB4=Output
            out   DDRB,R16         ; DDRB=0x03
    ; Initial ADC
            ldi   R16,0b10000110
    	out   ADCSRA,R16       ; Turn On the ADC, with prescaler 64
    	ldi   R16,0b00000000
    	out   ADCSRB,R16       ; Free running mode
    	ldi   R16,0b01100001
    	out   ADMUX,R16        ; Internal Reference 1.1 Volt,Left Adjust, Channel: PB2 (ADC1)
    	ldi   R16,0b00000100   ; Disable Digital Input on PB2
    	out   DIDR0,R16
    ; Initial PWM
            ldi   R16,0b10000011
     	out   TCCR0A,R16       ; Fast PWM Mode, Clear on OC0A
    	ldi   R16,0b00000100
    	out   TCCR0B,R16       ; Used fclk/256 prescaller
    ; Initial the Button Flag and PORTB
    	ldi   R17,0            ; Initial Button Flag
            out   PORTB,R17
    lb_00:  sbic  PINB,PB3         ; if (PB3 == 0)
            rjmp  lb_20            ; else goto lb_20
            ldi   R19,5            ; Use delay for simple debounce
      	rcall delay_func
    	sbic  PINB,PB3         ; if (PB3 == 0), read again
    	cpi   R17,1            ; Process if button pressed
    	brne  lb_10            ; if (R17 != 1) goto lb_10
    	ldi   R17,0            ; else R17=0
    	ldi   R16,0            ; Disable PWM Clock
            out   TCCR0A,R16       ; TCCR0A = 0
    	out   TCCR0B,R16       ; TCCR0B = 0
    	cbi   PORTB,PB0        ; Turn off Motor
    	cbi   PORTB,PB1        ; Turn off LED
            rjmp  lb_20
    lb_10:	ldi   R17,1	       ; R17=1
            ldi   R16,0b10000011
    	out   TCCR0A,R16       ; Fast PWM Mode, Clear on OCR0A
    	ldi   R16,0b00000100
            sbi   PORTB,PB1        ; Turn on LED
    lb_20:  cpi   R17,1            ; if (R17 != 1)
    	brne  lb_40            ; goto lb_50
            sbi   ADCSRA,ADSC      ; Start ADC conversion
    lb_30:  sbic  ADCSRA,ADSC      ; while (ADCSRA & (1<<ADSC))
    	rjmp  lb_30
    	in    R16,ADCH         ; Read the result Ignore the last 2 bits in ADCL
            out   OCR0A,R16        ; OCR0A = R16
    	mov   R19,R16
    	rcall delay_func       ; Call Delay Function Parameter R19
    lb_40:	mov   R19,R16
         	rjmp  lb_00
    ; Simple Delay Function
    delay_func:
    delay0: ldi   R20,25           ; R20 = 25
    delay1: ldi   R21,255          ; R21 = 255
    delay2: dec   R21              ; Decrease R21
    	brne  delay2           ; if (R20 != 0) goto delay2 label
            dec   R20              ; Decrease R20
            brne  delay1           ; if (R20 != 0) goto delay1 label
    	dec   R19              ; Decrease R19
    	brne  delay0           ; if (R19 != 0) goto delay0 label
    	ret                    ; Return to the caller
    .exit
    Niby udało mi się to skompilować w AVR studio Ale program niby dział jak powinien, ale PWM ma max 0.6Hz
  • #3 6208155
    jony
    Dzięki, ale i tak okazał się ze to program jest do bani.
    A ja durny myślałem ze to coś z kompilatorem, ale tak to jest jak się dopiero zaczyna zabawę z AVR a w pracy jedyne co programuje to PLC.
    Po zmianie programu mam piękny PWM 36Khz.
