[AT90S2323][ASM] odbiornik RC5 - dziala niestabilnie
chip2007 01 Kwi 2009 13:59 2502 5
  • #1 6361861
    chip2007
    Zrobilem sobie prosty uklad na at90s2323. Schemat ponizej.
    Kod aplikacji bazuje na przykladzie atmela AVR410.asm
    Oto i sam kod.
    ;	IR-Switch
    ; AT90S2323 at 4 MHz with external oscillator
    ; RC5 code is based on Atmel's Application note AVR410.asm file.
    .include "2323def.inc"
    .equ    POWER    	=0  ;PB0 is connected the transistor, to power-On/Off relay
    .equ	INPUT		=1	;PB1 is connected the TSOP1736 Infrared Receiver IC.
    .equ	SW			=2	;PB2 is switch
    .equ	SYS_ADDR	=0	;The system address - Philips TV set
    .equ	on_key		=7	;key 7 - device ON
    .equ	off_key		=9	;key 9 - device OFF
    .def	S		=R0
    .def	inttemp	=R18
    .def	ref1	=R2
    .def	ref2	=R3
    .def	temp	=R16
    .def	temp2	=R26
    .def	timerL	=R17
    .def	timerH	=R16
    .def	system	=R19
    .def	command	=R20
    .def	bitcnt	=R21
    .def	counter =R25
    .cseg
    .org 0
    		rjmp	reset
    ;* "TIM0_OVF" - Timer/counter overflow interrupt handler
    ;* The overflow interrupt increments the "timerL" and "timerH"
    ;* every 64us and 16,384us.
    ;* Number of words:	7
    ;* Number of cycles:	6 + reti
    ;* Low registers used:	1
    ;* High registers used: 3
    ;* Pointers used:	0
    .org OVF0addr
    TIM0_OVF:
    		in		S,sreg
    		inc		timerL				;Updated every 64us
    		inc		inttemp
    		brne	TIM0_OVF_exit
    		inc		timerH
    TIM0_OVF_exit:
    		out		sreg,S
    		reti
    ;       initiallizing Timer and PortB and enables interrupts.
    reset:
    		ldi  	temp,low(RAMEND)	;Initialize stackpointer
    		out		SPL,temp
    		ldi		temp,1				;Timer/Counter 0 clocked at CK
    		out		TCCR0,temp
    		ldi		temp,1<<TOIE0		;Enable Timer0 overflow interrupt
    		out		TIMSK,temp
    		ldi 	temp,0b00000001 	;PB0 output
    		out 	DDRB,temp
    		ldi 	temp,0b00000100 	;pull-up resistor on PB2
    		out 	PORTB,temp
    		sei							;Enable global iterrupt
    ;               Main program
    main:
    		rcall	delayTime
    		sbis	PINB,SW				;is button pressed?
    		rcall	switchRelay			;yes -> switch (invert) relay
    		rcall	detect				;Call RC5 detect routine
    		cpi		system,SYS_ADDR		;Respponds only at the specified address (philips TV)
    		brne	release
    		andi	command,0x3F		;Remove control bit
    		cpi		command,on_key   	; command = on_key (7)  ?
    		brne	release         	;no -> jump to release
    		sbi		PORTB,POWER			;yes -> switch device ON
    		rjmp	main
    release:
    		cpi		command,off_key		; command = off_key (9)  ?
    		brne	release_sub			;no -> jump to release_sub
    		cbi		PORTB,POWER			;yes -> switch device OFF
    release_sub:
    		clr		command
    		rjmp	main
    ;* "detect" - RC5 decode routine
    ;* This subroutine decodes the RC5 bit stream applied on PORTB
    ;* pin "INPUT".
    ;* If successe: The command and system address are
    ;*		returned in "command" and "system".
    ;*		Bit 6 of "command" holds the toggle bit.
    ;* If failed: 	$FF in both "system" and "command"
    ;* Crystal frequency is 4MHz
    ;* Number of words:	72
    ;* Low registers used:	 3
    ;* High registers used:  6
    ;* Pointers used:	 0
    detect:
    		clr		inttemp
    		clr		timerH
    detect1:
    		clr		timerL
    detect2:
    		cpi		timerH,8	;If line not idle within 131ms
    		brlo	dl1
    		rjmp	fault		;  then exit
    dl1:
    		cpi		timerL,55	;If line low for 3.5ms
    		brge	start1		;   then wait for start bit
    		sbis	PINB,INPUT	;If line is
    		rjmp	detect1		;   low  - jump to detect1
    		rjmp	detect2		;   high - jump to detect2
    start1:
    		cpi		timerH,8	;If no start bit detected
    		brge	fault		;within 130ms then exit
    		sbic	PINB,INPUT	;Wait for start bit
    		rjmp	start1
    		clr		timerL		;Measure length of start bit
    start2:
    		cpi		timerL,17	;If startbit longer than 1.1ms,
    		brge	fault		;   exit
    		sbis	PINB,INPUT
    		rjmp	start2
    					;Positive edge of 1st start bit
    		mov		temp,timerL	;timer is 1/2 bit time
    		clr		timerL
    		mov		ref1,temp
    		lsr		ref1
    		mov		ref2,ref1
    		add		ref1,temp	;ref1 = 3/4 bit time
    		lsl		temp
    		add		ref2,temp	;ref2 = 5/4 bit time
    start3:
    		cp		timerL,ref1	;If high periode St2 > 3/4 bit time
    		brge	fault		;   exit
    		sbic	PINB,INPUT	;Wait for falling edge start bit 2
    		rjmp	start3
    		clr		timerL
    		ldi		bitcnt,12	;Receive 12 bits
    		clr		command
    		clr		system
    sample:
    		cp		timerL,ref1	;Sample INPUT at 1/4 bit time
    		brlo	sample
    		sbic	PINB,INPUT
    		rjmp	bit_is_a_1	;Jump if line high
    bit_is_a_0:
    		clc			;Store a '0'
    		rol		command
    		rol		system
    					;Synchronize timing
    bit_is_a_0a:
    		cp		timerL,ref2	;If no edge within 3/4 bit time
    		brge	fault		;   exit
    		sbis	PINB,INPUT	;Wait for rising edge
    		rjmp	bit_is_a_0a	;in the middle of the bit
    		clr		timerL
    		rjmp	nextbit
    bit_is_a_1:
    		sec			;Store a '1'
    		rol		command
    		rol		system
    					;Synchronize timing
    bit_is_a_1a:
    		brge	fault		;   exit
    		rjmp	bit_is_a_1a	;in the middle of the bit
    		clr		timerL
    nextbit:
    		dec		bitcnt		;If bitcnt > 0
    		brne	sample		;   get next bit
    ;All bits sucessfully received!
    		mov		temp,command	;Place system bits in "system"
    		rol		temp
    		rol		system
    		rol		temp
    		rol		system
    		bst		system,5	;Move toggle bit
    		bld		command,6	;to "command"
    					;Clear remaining bits
    		andi	command,0b01111111
    		andi	system,0x1F
    		ret
    fault:
    		ser		command		;Both "command" and "system"
    		ser		system		;0xFF indicates failure
    		ret
    ;               delay routine
    delayTime:
    			ldi		counter,255
    delay:
    			dec		counter
    			brne	delay
    			ret
    ;               switch Relay (invert state) routine
    switchRelay:
    			sbis	PINB,POWER		;pomin nastepna linie jesli 1
    			rjmp	SetRelayON		;nie 1 -> SetRelayON
    			cbi		PORTB,POWER		;wyczysc bit (przekaznik OFF)
    			ret
    SetRelayON:
    			sbi		PORTB,POWER		;ustaw bit (przekaznik ON)
    			ret
    Problem polega na tym, ze uklad "nie zawsze dziala". Czasami wlacza / wylacza sie bez problemu innym razem musze kilkakrtonie nacisnac przycisk pilota, aby spowodowac zalaczenie / wylaczenie urzadzenia.
    Czy ktos moglby mnie naprowadzic na wlasciwy kierunek?
  • #2 6364126
    janbernat
    Wyczyszczenie "pilota" spirytusem daje często zbawienne skutki.
    A wymiana "gumek"...
  • #3 6364739
    chip2007
    dzieki za chec pomocy, ale to nie to :(
    pilot noweczka Logitech Harmony 885, "nauczony" z oryginalnego pilota philipsa
    nadajnik ma duzo mocniejszy niz oryginalny, sygnal spokojnie odbija sie od sufitu, scian i innych przedmiotow, kiedy oryginal trzeba "wcelowac" w odbiornik
  • #5 6365709
    chip2007
    OK, to jest jakis trop!
    dzieki
    a mam takze dodatkowe info, ktore powiem szczerze "zdziwilo" mnie lekko
    otoz wgralem sobie do komorki program irRemote, ktory pozwala na sterowanie urzadzeniami "robiac" z komorki pilota
    z bazy danych urzadzen wybralem swoj TV i O DZIWO !!??!! komorka wlacza wylacza moje urzadzenie za kazdym razem !!!
    nie ma najmniejszego problemu, wlasciwie z kazdej odleglosci
    kurcze, o co tu chodzi ?
    mam jakies swoje "przemyslenia" i ciekawi mnie co o tym sadzicie:
    Odbiornik ir TSOP1736, moze to jakis "klon" ktory nie ma jednak 36kHz, ale np. 38kHz. Komorka nie ma "prawdziwego" nadajnika IR, ale jakis modul IrDA, ktory byc moze pracuje "blizej" tego odbiornika i dlatego za kazdym razem zalacza/wylacza urzadzenie.
    Czy tak moze byc? Czy moze za bardzo kombinuje?
    EDIT:
    wlasnie "nauczylem" mojego harmony komed z komorki i nadal to samo, wiec to co powyzej napisalem to chyba raczej nie ma sensu :(
  • #6 6370628
    chip2007
    dodatkowe info
    podlaczylem oscyloskop zeby zobaczyc co sie dzieje z tym moim urzadzeniem i tak to wyglada:
    pilot logitech harmony (klawisz 7):
    nokia e51 (w programie irRemote, symulacja pilota philipsa, klawisz 7):
    harmony (klawisz 9):
    nokia (klawisz 9):
    z obrazkow widac, ze sygnal z nokii jest bardziej skompresowany niz z harmony
    ale nie rozumiem dlaczego tak jest, skoro harmony zostal "nauczony" wlasnie z nokii !!
    ktos pomoze ??
