Wyświetlacz siedmiosegmentowy i ds18b20 prosze o pomoc
Piotr Kania 11 Kwi 2009 14:34 2145 17
  • #1 6401433
    Piotr Kania
    Witam oto mój program czy ktoś wie jak zrobić konwersje msb i lsb w ds18b20 żeby wyświetlić na siedmio segmentowym wyświetlaczu temperaturę ?
    #include <avr/io.h>
    //#include <avr/iom8.h>
    #include <avr/interrupt.h>
    //#include <stdlib.h>
    //#include <string.h>
    #define F_CPU 8000000UL
    #include <util/delay.h>
    #include "ds18B20.c"
    volatile unsigned char a,b,c,d;
    #define LEDA_OUTPUT() DDRC |= _BV(0)
    #define LEDA_ON() PORTC&= ~_BV(0)
    #define LEDA_OFF() PORTC|= _BV(0)
    #define LEDB_OUTPUT() DDRC |= _BV(1)
    #define LEDB_ON() PORTC&= ~_BV(1)
    #define LEDB_OFF() PORTC|= _BV(1)
    #define LEDC_OUTPUT() DDRC |= _BV(2)
    #define LEDC_ON() PORTC&= ~_BV(2)
    #define LEDC_OFF() PORTC|= _BV(2)
    #define LEDD_OUTPUT() DDRC |= _BV(3)
    #define LEDD_ON() PORTC&= ~_BV(3)
    #define LEDD_OFF() PORTC|= _BV(3)
    //w1-w4
    #define W1_OUTPUT() DDRD |= _BV(7)
    #define W1_ON() PORTD&= ~_BV(7)
    #define W1_OFF() PORTD|= _BV(7)
    #define W2_OUTPUT() DDRD |= _BV(6)
    #define W2_ON() PORTD&= ~_BV(6)
    #define W2_OFF() PORTD|= _BV(6)
    #define W3_OUTPUT() DDRD |= _BV(5)
    #define W3_ON() PORTD&= ~_BV(5)
    #define W3_OFF() PORTD|= _BV(5)
    #define W4_OUTPUT() DDRD |= _BV(4)
    #define W4_ON() PORTD&= ~_BV(4)
    #define W4_OFF() PORTD|= _BV(4)
    void led_init(void)
    LEDA_OUTPUT();
    LEDB_OUTPUT();
    LEDC_OUTPUT();
    LEDD_OUTPUT();
    LEDA_OFF();
    LEDB_OFF();
    LEDC_OFF();
    LEDD_OFF();
    W1_OUTPUT();
    W2_OUTPUT();
    W3_OUTPUT();
    W4_OUTPUT();
    W1_OFF();
    W2_OFF();
    W3_OFF();
    W4_OFF();
    void wyswietl(unsigned char a)
    if(a==0)
    {LEDD_ON();LEDC_ON();LEDB_ON();LEDA_ON();}
    if(a==1)
    {LEDD_ON();LEDC_ON();LEDB_ON();LEDA_OFF();}
    if(a==2)
    {LEDD_ON();LEDC_ON();LEDB_OFF();LEDA_ON();}
    if(a==3)
    {LEDD_ON();LEDC_ON();LEDB_OFF();LEDA_OFF();}
    if(a==4)
    {LEDD_ON();LEDC_OFF();LEDB_ON();LEDA_ON();}
    if(a==5)
    {LEDD_ON();LEDC_OFF();LEDB_ON();LEDA_OFF();}
    if(a==6)
    {LEDD_ON();LEDC_OFF();LEDB_OFF();LEDA_ON();}
    if(a==7)
    {LEDD_ON();LEDC_OFF();LEDB_OFF();LEDA_OFF();}
    if(a==8)
    {LEDD_OFF();LEDC_ON();LEDB_ON();LEDA_ON();}
    if(a==9)
    {LEDD_OFF();LEDC_ON();LEDB_ON();LEDA_OFF();}
    if(a==10)
    {LEDD_OFF();LEDC_OFF();LEDB_OFF();LEDA_OFF();}
    SIGNAL (SIG_OVERFLOW1)
    TCNT1 = 0xfec8;        // przeładuj timer 1
    W1_ON();
    wyswietl(a);
    _delay_ms(1);
    W1_OFF();
    W2_ON();
    wyswietl(b);
    _delay_ms(1);
    W2_OFF();
    W3_ON();
    wyswietl(c);
    _delay_ms(1);
    W3_OFF();
    W4_ON();
    wyswietl(d);
    _delay_ms(1);
    W4_OFF();
    void pomiar(void)
    float celcius;
    char msb,lsb,temp;
    char tab[6];
    ow_reset();
    ow_write_byte(0xCC);
    ow_write_byte(0x44);
    _delay_ms(750);
    ow_reset();
    ow_write_byte(0xBE);
    lsb = ow_read_byte();
    msb = ow_read_byte();
    ow_reset();
    KONWERSJA i wyświetlenie na led
    próbowałem coś zrobić na itoa ale nie przyniosło to dobrego rozwiązania
    int main(void)
    led_init();
    TIMSK = _BV(TOIE1);        // włącz obsługę przerwań T/C1
    TCNT1 = 0xfec8;        // wartość początkowa T/C1 0bdc=2s
    TCCR1A = 0x00;        // włącz tryb czasomierza T/C1
    TCCR1B=(1<<CS12);		// preskaler 256
    a=0;
    b=0;
    c=0;
    d=0;
    sei();
    while(1)
    pomiar();
  • #2 6401530
    __Maciek__
    Konwersja na temperaturę :
    ow_reset() ;
    lsb = ow_read_byte() ;
    msb = ow_read_byte() ;
    Temperatura = (msb<<8 | lsb) * 10 / 16 ;
    A jak masz podłączone wyświetlacze ?
    Np. część kontrolerów potrzebuje kodów BCD.
    Używaj opcji SZUKAJ. To co podałem było już niejednokrotnie.
    Dobra .. popatrzyłem w kod ... i jeśli procedury wyświetlające cyfry funkcjonują prawidłowo ... to teraz możesz pobawić się z itoa ( będziesz musiał dodać kopkę dziesiętną. ) W zmiennej Temperatura masz wartość temperatury np: 200 = 20,0°C itd ...
  • #3 6401572
    Piotr Kania
    ok to znam ale jak teraz tą temp rozdzielić na 2 wyświetlacze np na pierwszym liczba dziesiętna na na 2 jedności. Wyświetlacze działają bo zrobiłem na nich zegar, steruje przez HEF4543
  • #4 6401656
    __Maciek__
    Więc właśnie interesuje Cię konwersja Int na BCD.
    np z tąd : Link
    // returns number of digits converted
    // result array must be large enough to hold
    // the number of digits converted.
    int itobcd(unsigned int val, char *result)
      char BCD_text[6]; // max 5 digits in a 16 bit uint
      int i;
      itoa(val, BCD_text, 10);
      i=0;
      while(BCD_text[i])
        result[i] = BCD_text[i]-'0';
        i++;
      return i;
    Można też napisać własną procedurę .. tu patrz Google -> BCD .
    kaktus_c++
    nie kapuję do czego zmierzasz, przykład funkcji zamieniającej msb i lsb na zmienną typu float podałem tam: https://www.elektroda.pl/rtvforum/topic1256758.html
    jeśli nie o to chodzi to napisz dokładniej co chcesz w tym kodzie zrobić
  • #7 6402452
    Piotr Kania
    Potrzebuje wyświetlić temperaturę na 4 wyświetlaczach led zawsze jeżeli chodziło o LCD robiłem to tak
     celcius =  msb << 8 | lsb ;
     celcius/=16;
     write_text(dtostrf(celcius, 3, 1, tab));
    teraz chce to wyświetlić na led i np temperature 27st rozłożyć na a=2, b=7 i w przerwaniu wyswietlić
    może ktoś zna prostszy sposób?
  • #9 6403767
    Piotr Kania
    zrobiłem tak
    ow_reset();
    _delay_ms(100);
    ow_reset();
    temp = ((msb<<4)|(lsb >> 4));
    c=temp%10;
    temp=temp/10;
    b=temp%10;
    temp=temp/10;
    a=temp%10;
    i działa ale co jakiś czas na wyświetlaczu pojawia sie 255 wydaje mi się że to przez timer1, który wyświetla temperaturę wiecie może jak to załatwić? Wyłącznie przerwań na czas komunikacji z ds załatwia problem, czy ktoś ma jakieś inne propozycje rozwiązania tego problemu
  • #10 6404173
    dawid512
    Poziom 32  
    Można też stosować flagę ustawianą bądź kasowaną w przerwaniu aby stwierdzić czy wystąpiło przerwanie. Na ogół jednak wyłącza się przerwania na czas komunikacji tak jak ty to zrobiłeś.
    kaktus_c++
    jestem ciekaw jak tam u ciebie z odczytem ujemnych temperatur, bo wg mnie to będą źle czytane. no chyba że nie potrzebujesz ujemnych
  • #12 6405370
    Piotr Kania
    tak będzie źle ale musiałem sprawdzić czy to działa. Jeśli wezmę 4 bity z msb i wszystkie z lsb to dostane np temperature w postaci 12,0625 przyczym czwarty bit z msb decydował będzie o znaku. Próbowałem tak jak Kaktus mówił ale mnożyłem przez 10000, dobrego wyniku nie dostałem, dlaczego?
    kaktus_c++
    jeśli chodzi o ujemne temperatury to ta funkcja sobie poradzi:
    float zamien_temp(unsigned char MSB,unsigned char LSB)
        if(MSB&0x80)//ujemna temp
           LSB=~LSB +1;
           MSB=~MSB;
           unsigned int suma = LSB + (((unsigned int)MSB)<<8);
           return  ((float)suma) * -0.0625;
        else//dodatnia temp
           return ((float)(MSB<<8|LSB))/16;
    a jeśli chodzi o mnożenie przez 10000 to poki nie zobacze fragmentu kodu to nie wiem co jest grane, zresztą taka dokładność to chyba przesada.
  • #14 6406964
    Piotr Kania
    to prawda przesada ale ds18b20 niby z tyloma miejscami po przecinku działa. Jutro przetestuje ten kod i dam znać do czego doszedłem. Dzięki
  • #15 6407161
    rrata
    Nie wiem za bardzo po co używać typu float, spokojnie można zrobić to na liczbach całkowitych (kodowanie U2). Zresztą dokładność tego termometru według dokumentacji wynosi 0.5°C, wystarczy wyświetlać z rozdzielczością 0.1°C, a to i tak będzie za dużo.
  • #16 6407178
    Piotr Kania
    no tak zgadza się ale chodzi o poznanie zasady jak to działa, dokładność przetwornika wynosi 0.5st wiec wystarczy nawet całkowite wyświetlać
    Przetestowałem oto mój kod
    temp = zamien_temp(msb,lsb)*10;
    d=temp%10;
    temp=temp/10;
    c=temp%10;
    temp=temp/10;
    b=temp%10;
    temp=temp/10;
    a=temp%10;
    if(a==0) a=10;//wyłącznie 1 wyświetlacza
    temp jest jako int, program działa dziękuje za pomoc
  • #17 6407323
    rrata
    Dobrym programistą może nie jestem, ale zrobiłem sobie to w ten sposób:
    Wydzielam sobie cztery bity odpowiadające za ułamek
    ulamek = lsb & 0x0F;
    Później normalnie wydzielam sobie bity odpowiadające za liczbę całkowitą:
    lsb = lsb >> 4;
    		msb = msb << 4;
    		temp = lsb | msb;
    Sprawdzam czy jest ujemna, jesli tak to zamieniam ją na liczbę przeciwną, aby dało się to wysłać na LCD:
    if(temp & 0b10000000)//Jeśli ujemna
    			temp = (~temp) + 1;
    			if(ulamek)
    				ulamek = (~ulamek) + 1;
    			pisz_znak('-');//Wyświetla znak "-" na LCD
    Wcześniej mam utworzoną tablicę
    const unsigned char liczbyulamk[] = {0,0,1,2,2,3,3,4,5,5,6,6,7,8,8,9};
    ponieważ liczba ułamkowa to 4 bity, czyli od 0 do 15.
    Za wartość zmiennej ułamek wpisuję wartość cyfry po przecinku jaka ma się pokazać na LCD
    ulamek = liczbyulamk[ulamek];
    i na koniec wyświetlam to wszystko na LCD
    kursor_na_poczatek();//ustawia kusor na początek ekranu
    		liczba_na_lcd(temp);
    		pisz_znak('.');
    		liczba_na_lcd(ulamek);
    		pisz_znak(0b11011111);//wypisuje znak "°"
    		pisz_znak('C');
    W ten oto sposób mam wyświetlaną temperaturę z liczbami ujemnymi z rozdzielczością 0,1°C. Kod jest błedny, gdyż zamiast pokazać temperaturę -0,1°C pokazuje -0,0°C, ale nie bardzo mam czas i chęci by to zmieniać. Zapewne lepiej dałoby się to zapisać, ale zapisałem to jak umiałem.
    Myślę, że modyfikacja kodu, aby wyświetlał temperaturę na wyświetlaczu LED siedmiosegmentowym nie będzie duzym problemem.
  • #18 6407382
    Piotr Kania
    Sposób kaktusa jest dla mnie lepszy bo obrabia wszystko, kiedyś też zrobiłem coś takiego jak Ty rrata ale brałem pod uwagę bit odpowiadający za zmianę co 0.5 st i też działało ale wyświetlałem na lcd.
