W Bascom'ie jest biblioteka mmc.lib i nigdzie nie jest opisana jej konfiguracja jak i jej sposób użycia.
Czy wiecie jak wysyłać i odbierać bajty przy użyciu tej biblioteki?
Dokopałem się do czegoś takiego i co dalej.......
$regfile = "m128def.dat"
$crystal = 14745600
$baud = 115200
$hwstack = 150 'wartosc stosu
$swstack = 150 'wartosc stosu
$framesize = 150 'wartosc ramki
Const cMMC_Soft = 0
#IF cMMC_Soft = 0
' --------- Start of Section for HW-SPI ----------------------------------------
' define Chip-Select Pin
Config PinB.0 = Output ' define here Pin for CS of MMC/SD Card
Mmc_cs Alias PortB.0
Set Mmc_cs
' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
' If an other Pin than SS is used for MMC_SS, SS must be set to OUTPUT and high for proper work of SPI
' otherwise AVR starts SPI-SLAVE if SS-Pin is INPUT and goes to LOW
Config Pinb.0 = Output ' define here Pin of SPI SS
Spi_ss Alias PortB.0
Set Spi_ss ' Set SPI-SS to Output and High por Proper work of
' SPI as Master
' HW-SPI is configured to highest Speed
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
' Spsr = 1 ' Double speed on ATMega128
Spiinit ' Init SPI
' --------- End of Section for HW-SPI ------------------------------------------
#ELSE ' Config here SPI pins, if not using HW SPI
' --------- Start of Section for Soft-SPI --------------------------------------
' Chip Select Pin => Pin 1 of MMC/SD
MMC_CS Alias PortB.0
Set MMC_CS
' MOSI - Pin => Pin 2 of MMC/SD
Config PinB.2 = Output
Set PinB.2
MMC_PortMOSI Alias PortB
bMMC_MOSI Alias 2
' MISO - Pin => Pin 7 of MMC/SD
Config PinB.3 = Input
MMC_PortMISO Alias PinB
bMMC_MISO Alias 3
' SCK - Pin => Pin 1 of MMC/SD
Config PinB.1 = Output
Set PinB.1
MMC_PortSCK Alias PortB
bMMC_SCK Alias 1
' --------- End of Section for Soft-SPI ----------------------------------------
#ENDIF
' ========== End of user definable range =======================================
' Error
Const Cperrdrivereset = 225 ' Error response Byte at Reset command
Const Cperrdriveinit = 226 ' Error response Byte at Init Command
Const Cperrdrivereadcommand = 227 ' Error response Byte at Read Command
Const Cperrdrivewritecommand = 228 ' Error response Byte at Write Command
Const Cperrdrivereadresponse = 229 ' No Data response Byte from MMC at Read
Const Cperrdrivewriteresponse = 230 ' No Data response Byte from MMC at Write
Const Cperrdrive = 231
Const Cperrdrivenotsupported = 232 ' return code for DriveGetIdentity, not supported yet
Waitms 1 ' Wait some time before initialising MMC/SD
Dim Gbdriveerror As Byte ' General Driver Error register
Dim Gbdriveerrorreg As Byte ' Driver load Error-Register of HD in case of error
Dim Gbdrivestatusreg As Byte ' Driver load Status-Register of HD on case of error
Dim Gbdrivedebug As Byte
$lib "MMC.LIB" ' link driver library
$EXTERNAL _mmc
Gbdriveerror = Driveinit() ' Init MMC/SD Card
