#define F_CPU 8000000UL
#define BAUD 9600
#define MYUBRR ((F_CPU/(16L*BAUD))-1)
#include <avr/io.h>
#include <avr/eeprom.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <stdint.h>
uint8_t RCDATA[] = {0,0,0,0};
volatile uint8_t RECEIVE_DATA;
volatile uint8_t rcI;
volatile uint8_t A,B,C,D;
static const uint8_t LINES[100][5] PROGMEM = { {0,0,0,0,0x001},{0,0,0,0,0x002},{0,0,0,0,0x003},{0,0,0,0,0x004},{0,0,0,0,0x005},{0,0,0,0,0x006},{0,0,0,0,0x007},{0,0,0,0,0x008},
{0,0,0,1,0x011},{0,0,0,1,0x012},{0,0,0,1,0x013},{0,0,0,1,0x014},{0,0,0,1,0x015},{0,0,0,1,0x016},{0,0,0,1,0x017},{0,0,0,1,0x018},
{0,0,1,0,0x021},{0,0,1,0,0x022},{0,0,1,0,0x023},{0,0,1,0,0x024},{0,0,1,0,0x025},{0,0,1,0,0x026},{0,0,1,0,0x027},{0,0,1,0,0x028},
{0,0,1,1,0x031},{0,0,1,1,0x032},{0,0,1,1,0x033},{0,0,1,1,0x034},{0,0,1,1,0x035},{0,0,1,1,0x036},{0,0,1,1,0x037},{0,0,1,1,0x038},
{0,1,0,0,0x041},{0,1,0,0,0x042},{0,1,0,0,0x043},{0,1,0,0,0x044},{0,1,0,0,0x045},{0,1,0,0,0x046},{0,1,0,0,0x047},{0,1,0,0,0x048},
{0,1,0,1,0x051},{0,1,0,1,0x052},{0,1,0,1,0x053},{0,1,0,1,0x054},{0,1,0,1,0x055},{0,1,0,1,0x056},{0,1,0,1,0x057},{0,1,0,1,0x058},
{0,1,1,0,0x061},{0,1,1,0,0x062},{0,1,1,0,0x063},{0,1,1,0,0x064},{0,1,1,0,0x065},{0,1,1,0,0x066},{0,1,1,0,0x067},{0,1,1,0,0x068},
{0,1,1,1,0x071},{0,1,1,1,0x072},{0,1,1,1,0x073},{0,1,1,1,0x074},{0,1,1,1,0x075},{0,1,1,1,0x076},{0,1,1,1,0x077},{0,1,1,1,0x078},
{1,0,0,0,0x081},{1,0,0,0,0x082},{1,0,0,0,0x083},{1,0,0,0,0x084},{1,0,0,0,0x085},{1,0,0,0,0x086},{1,0,0,0,0x087},{1,0,0,0,0x088},
{1,0,0,1,0x091},{1,0,0,1,0x092},{1,0,0,1,0x093},{1,0,0,1,0x094},{1,0,0,1,0x095},{1,0,0,1,0x096},{1,0,0,1,0x097},{1,0,0,1,0x098},
{1,0,1,0,0x0A1},{1,0,1,0,0x0A2},{1,0,1,0,0x0A3},{1,0,1,0,0x0A4},{1,0,1,0,0x0A5},{1,0,1,0,0x0A6},{1,0,1,0,0x0A7},{1,0,1,0,0x0A8},
{1,0,1,1,0x0B1},{1,0,1,1,0x0B2},{1,0,1,1,0x0B3},{1,0,1,1,0x0B4},{1,0,1,1,0x0B5},{1,0,1,1,0x0B6},{1,0,1,1,0x0B7},{1,0,1,1,0x0B8},
{1,1,0,0,0x0C1},{1,1,0,0,0x0C2},{1,1,0,0,0x0C3},{1,1,0,0,0x0C4}
void USART_Transmit( unsigned char data );
void USART_Init( unsigned int ubrr);
uint8_t USART_Receive( void );
void ReceiveFrame();
void updateBoard(uint8_t);
void setBoard(void);
int main (void)
USART_Init ( MYUBRR );
DDRB = 0xFF;
DDRC = 0xBF;
DDRD = 0xFF;
PORTB=0x00;
PORTC=0x40;
PORTD=0x00;
rcI = 0;
RECEIVE_DATA = 0;
_delay_ms(100);
setBoard();
while(1){
if(RECEIVE_DATA == 0) ReceiveFrame();
else if(RECEIVE_DATA == 1 ){
uint8_t lineValue = 0;
uint8_t lineCode = 0;
lineCode = (RCDATA[0] * 100) + (RCDATA[1] * 10) + RCDATA[2] -1;
lineValue = RCDATA[3];
eeprom_busy_wait();
eeprom_write_byte( (uint8_t *)pgm_read_byte(&LINES[lineCode][4]), lineValue);
D = pgm_read_byte(&LINES[lineCode][0]);
C = pgm_read_byte(&LINES[lineCode][1]);
B = pgm_read_byte(&LINES[lineCode][2]);
A = pgm_read_byte(&LINES[lineCode][3]);
updateBoard(lineCode);
RECEIVE_DATA = 0;
rcI = 0;
USART_Transmit('*');
return 0;
void setBoard(){
volatile uint8_t a,b,c,d,e,f,g,h;
uint8_t beginAddress = 0x001;
uint8_t j;
uint8_t pointer = 0;
while(pointer != 104){
eeprom_busy_wait();a = eeprom_read_byte((uint8_t *) beginAddress);
eeprom_busy_wait();b = eeprom_read_byte((uint8_t *) beginAddress+1);
eeprom_busy_wait();c = eeprom_read_byte((uint8_t *) beginAddress+2);
eeprom_busy_wait();d = eeprom_read_byte((uint8_t *) beginAddress+3);
eeprom_busy_wait();e = eeprom_read_byte((uint8_t *) beginAddress+4);
eeprom_busy_wait();f = eeprom_read_byte((uint8_t *) beginAddress+5);
eeprom_busy_wait();g = eeprom_read_byte((uint8_t *) beginAddress+6);
eeprom_busy_wait();h = eeprom_read_byte((uint8_t *) beginAddress+7);
beginAddress += 16;
_delay_ms(200);
D = pgm_read_byte(&LINES[pointer][0]);
C = pgm_read_byte(&LINES[pointer][1]);
B = pgm_read_byte(&LINES[pointer][2]);
A = pgm_read_byte(&LINES[pointer][3]);
pointer += 8;
PORTC = (a << 0) | (b << 1) | (c << 2) | (d << 3) | (e << 4) | (f << 5);
PORTB = (g << 4) | (h << 5) |(A << 0);
PORTD = (B << 7) | (C << 6) | (D << 5); // wybór zatrzasku
PORTB &= ~_BV(PB7); // odblokowanie MUXa
_delay_ms(50);
PORTB |=_BV(PB7);
_delay_ms(50);
PORTC = (0 << 0) | (0 << 1) | (0 << 2) | (0 << 3) | (0 << 4) | (0 << 5);
PORTB = (0 << 4) | (0 << 5) | (1 << 7);
void updateBoard(uint8_t lineNumber){
volatile uint8_t valueTab[8];
uint8_t j,k,i;
uint8_t okFlag = 1;
i = 0;
for(j=(lineNumber -9); j<(lineNumber + 9);j++){
for(k=0; k<3; k++){
if(pgm_read_byte(&LINES[lineNumber][k]) != pgm_read_byte(&LINES[j][k])) okFlag = 0;
if(okFlag){
eeprom_busy_wait();
valueTab[i++] = eeprom_read_byte((uint8_t *)pgm_read_byte(&LINES[j][4]));
_delay_ms(200);
D = pgm_read_byte(&LINES[lineNumber][0]);
C = pgm_read_byte(&LINES[lineNumber][1]);
B = pgm_read_byte(&LINES[lineNumber][2]);
A = pgm_read_byte(&LINES[lineNumber][3]);
PORTC = (valueTab[0] << 0) | (valueTab[1] << 1) | (valueTab[2] << 2) | (valueTab[3] << 3) | (valueTab[4] << 4) | (valueTab[5] << 5);
PORTB = (valueTab[6] << 4) | (valueTab[7] << 5) |(A << 0);
_delay_ms(50);
PORTB |=_BV(PB7);
_delay_ms(50);
PORTB = (0 << 4) | (0 << 5)| (1 << 7);
/* Set baud rate */
UBRRH = (unsigned char)(ubrr>>8);
UBRRL = (unsigned char)ubrr;
/* Enable receiver and transmitter */
UCSRB = (1<<RXEN)|(1<<TXEN);
/* Set frame format: 8data, 2stop bit */
UCSRC = (1<<URSEL)|(1<<USBS)|(3<<UCSZ0);
/* Wait for empty transmit buffer */
while ( !( UCSRA & (1<<UDRE)) )
/* Put data into buffer, sends the data */
UDR = data;
/* Wait for data to be received */
while ( !(UCSRA & (1<<RXC)) )
/* Get and return received data from buffer */
return UDR;
void ReceiveFrame(){
RCDATA[rcI] = USART_Receive(); rcI++;
if( rcI > 3){
rcI = 0;
RECEIVE_DATA = 1;
