Problem z wgrywaniem programu (AVRdude + Burn-O-Mat)
czopik2004 01 Cze 2009 15:15 2111 2
  • #1 6602955
    czopik2004
    Witam!
    Próbując wgrać program do procesora dostaję takie coś:
    C:\WinAVR-20090313\bin\avrdude.exe -C C:\WinAVR-20090313\bin\avrdude.conf -p m8 -P com3 -c stk500v2  -U flash:w:C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX:a
    avrdude.exe: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.02s
    avrdude.exe: Device signature = 0x1e9307
    avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
                 To disable this feature, specify the -D option.
    avrdude.exe: erasing chip
    avrdude.exe: reading input file "C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX"
    avrdude.exe: input file C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX auto detected as Intel Hex
    avrdude.exe: writing flash (3200 bytes):
    Writing | #####avrdude.exe: stk500v2_recv(): previous packet sent with wrong checksum
    ##################################avrdude.exe: stk500v2_recv(): previous packet sent with wrong checksum
    ## | 100% 4.70s
    avrdude.exe: 3200 bytes of flash written
    avrdude.exe: verifying flash memory against C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX:
    avrdude.exe: load data flash data from input file C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX:
    avrdude.exe: input file C:\Documents and Settings\Administrator\Pulpit\Zasilacz cyfrowy\PROGRAM.HEX contains 3200 bytes
    avrdude.exe: reading on-chip flash data:
    Reading | ############################################avrdude.exe: stk500_2_ReceiveMessage(): timeout
    ###### | 100% 19.58s
    avrdude.exe: verifying ...
    avrdude.exe: verification error, first mismatch at byte 0x0140
                 0x07 != 0x6e
    avrdude.exe: verification error; content mismatch
    avrdude.exe done.  Thank you.
    Co zrobić i jak na to zaradzić? Fuse bity nie ruszane.
    Z góry dziękuję za pomoc i pozdrawiam: Kamil
  • #2 6713173
    Kacpir
    Mam to samo tyle, że ja pod Linuxem pracuje.
  • #3 6713224
    czopik2004
    Masz może Płytkę testową ZL2AVR? Pomogło mi włożenie zworki od resetu.
