[ATMEGA32][Bascom] Wyświetlanie obrazu na TV.
MacFis 29 Cze 2009 13:38 5593 4
  • #1 6717586
    MacFis
    Witam!
    Mam do dyspozycji Atmega32, Atmega8 i Attiny2313. Chciałbym zbudować prosty generator obrazu TV. Wejście wideo podłączam do Atmegi32 przez rezystor 1K i 330Ohm.
    ................................................/ -rezystor 1k------ ----- PORTD.5
    Wejście Wideo (Chinch)------<
    ................................................\-rezystor 330Ohm ---- PORTD.6
    I mam problem z programem. A konkretnie to nie wiem jak go napisać. Od czego zacząć? W pomocy Bascom'a nic takiego nie znalazłem...
  • #2 6719120
    PiotrEtenM500
    '  * Mega 8 PAL Video Test Pattern 64 Colours ( noninterlaced )                         *
    '  * V3.1.38 (c) 2008 Moshtech                                                           *
    '  Device -> Analog Devices AD722 or ( AD724 )
    '  Note: This chip needs to have the correct timing !!!
    '        If the HSync pulse is to short or long no colour burst will not occour !
    '        The RGB input must be set to zero ( Black ) during sync and colour burst or it will cause problems
    '        Also, the RGB must be at black level at the end of the line. ( distorts next few lines )
    '        The Mega 8 is overclocked to 24Mhz with an external OSC module, it will work at 20 or 16Mhz,
    '        However, less time is available to draw the screen, higher clock = smaller pixels.
    '        24Mhz gives about ~60 useable pixels per horizontal line ( in basic )
    '  RED   X1 - PC5       6 Bit Video data, 64 colours inc black
    '  RED   X2 - PC4
    '  GREEN X1 - PC3
    '  GREEN X2 - PC2
    '  BLUE  X1 - PC1
    '  BLUE  X2 - PC0
    '  HSYNC - PB1          Syncs are both active low, to chip via 100 Ohm
    '  VSYNC - PB0          Not used, pull high
    '  Option: Put blanking buffer here, between the AVR port & the resistor network.
    '  74F AND or NAND gate with pullups on the outputs, or Buffer with enable, etc...
    '                             VCC
    '                             10pf
    '   X1  -------- 10K ----------*
    '   X2  ---- 10K ----- 10K ----*----- 100n ----- RGB IN (AD722) <- or to maxim buffer chip for RGB out
    '   OPT ----- 10K X4 ----------*
    '   OPT ----- 10K X8 ----------*     <- to add more bits
    '   OPT ----- 10K X16 ---------*
    '              ---->        680 ohm
    '  Fixed  -> 1K       or       |
    '              ---->      500 ohm pot <- colour adjust
    '                             GND
    '  Repeat above circuit for other colours
    '  References :   Analog Devices          AD722.pdf
    '                 Analog Devices          AD722AN.pdf
    '                 Maxim                   AN734.pdf
    '                 Silicon Chip Magazine   June 2004 p24 ( Dr Video Mk.2 )
    '                 Silicon Chip Magazine   June 2006 p28 ( Pocket AV Generator ( AD724 ))
    '                 Silicon Chip Magazine   September 2006 p84 ( S-Video to Composite converter )
    '                 PAL Standards info      http://www.kolumbus.fi/pami1/video/pal_ntsc.html
    '$sim
    $regfile = "m8def.dat"                                      ' * Mega 8
    $crystal = 24000000                                         ' * 24 MHz External OSC ( 16Mhz part OVERCLOCKED !!! )
    $hwstack = 128                                              ' * default use 32 for the hardware stack
    $swstack = 128                                              ' * default use 10 for the SW stack
    $framesize = 64                                             ' * default use 40 for the frame space
    Const Pause = 500                                           ' *  250 * Delay ms main loop
    Const Hsync_delay = 1471                                    ' * 1471 * Value to load timer1 (HSync) with, 1536 = 64us @ 24Mhz
    Const Vid_start = 146                                       ' *  146 * Delay from start of HSync untill the start of the video data
    Const Sync_del = 3.201                                      ' * 3.201 * Delay to pad out HSync low ( total 4.7us )
    Const Grid = 1.85                                           ' *  1.85 * box size
    Colour Alias Portc                                          ' * port C video data, 2 bit RGB
    Hsync Alias Portb.1                                         ' * Horizontal Sync Output ( on timer 1 ouput pin OC1A, not used )
    Vsync Alias Portb.0                                         ' * Vertical Sync Output
    Dim Current_line As Word                                    ' * Horizontal line counter
    Dim Current_block As Byte                                   ' * Horizontal block counter
    Dim Video As Byte                                           ' * video data ( used for, for next loops )
    Dim Tick As Word                                            ' * Vsync counter 50 ticks per second PAL                                         '
    Dim Colour_rnd As Byte                                      ' * random colour per field
    Dim New_colour As Byte                                      ' * new colour for cycling bars
    Dim Temp As Byte
    Config Hsync = Output
    Config Vsync = Output
    Config Colour = Output
    Set Hsync                                                   ' * active low
    Set Vsync                                                   ' * active low
    Colour = 0                                                  ' * colour data ( black )
    ' ********** Configure Timer 0  : Delay from start of HSync untill Video data start ( Only active during Horizontal line )
    Config Timer0 = Timer , Prescale = 1
    On Timer0 Vid_line                                          ', Nosave
    Load Timer0 , Vid_start
    Enable Timer0
    ' ********** Configure Timer 1  : 64us PAL HSync timer
    Config Timer1 = Timer , Prescale = 1
    On Timer1 Sync_h
    Load Timer1 , Hsync_delay
    Enable Timer1
    Start Timer1
    Enable Interrupts
    ' ********** Main Loop
    Do
       New_colour = Colour_rnd
       Waitms Pause
    Loop
    ' *  Horizontal Sync IRQ, uses timer1 for a total of 64us, 4.7us low pulse. Counts lines and starts video IRQ                  *
    Sync_h:
       Toggle Hsync                                             ' * Set HSync Low, Start H cycle
       Load Timer1 , Hsync_delay                                ' * Reload the timer ( total cycle PAL = 64us )
       Load Timer0 , Vid_start                                  ' * Load timer0 with delay value for start of video data
       Start Timer0                                             ' * enable the timer only during HSync IRQ, Hsync must finish before timer0 IRQ hits
       If Current_line = 1 Then Toggle Hsync                    ' * if first line, Start VSync pulse
       If Current_line = 3 Then Toggle Hsync                    ' * if 3rd line, End Vsync pulse
       Waitus Sync_del                                          ' * wait ( total from start IRQ code ) 4.7us
       Toggle Hsync                                             ' * Set HSync High, End H cycle
       Incr Current_line                                        ' * increment line counter
       If Current_line = 301 Then Colour_rnd = Rnd(&B00111111)  ' * for colour cycling bar
       If Current_line = 311 Then Toggle Vsync                  ' * sync for scope trigger
       If Current_line = 312 Then Incr Tick                     ' * increment system tick counter ( once per field 50Hz PAL )
       If Current_line = 313 Then Current_line = 0              ' * last line ( non interlaced )
    Return
    ' * Display Video Data IRQ, uses timer0 to delay the start of video data to the same point per line, aprox 10.5us              *
    Vid_line:
       Stop Timer0                                              ' * Stop timer0 untill next video line ( it will retrigger before the line ends if we don't ! )
       On Current_block Gosub Lin0 , Lin1 , Lin2 , Lin3 , Lin4 , Lin5 , Lin6 , Lin7 , Lin8 , Lin9 , Lin10 , Lin11 , Lin12 , Lin13 , Lin14 , Lin15 , Lin16 , Lin17
    Return                                                      ' * Use on gosub ( quicker than if a< or a> then gosub etc... )
    ' * first block ******************************************************************************************** colour bars
    Lin0:                                                       ' * Blank line ( No data all set black )
       Colour = 0
       If Current_line = 23 Then Incr Current_block             ' * start line is normaly 23
    Return
    Lin1:
    For Video = 0 To 47 Step 1
       Colour = 0                                               ' * insert black between colours
       Colour = Timer1                                          ' * electricky ;-)
    Next Video
       Colour = 0                                               ' * must end with black !!!!!!
       If Current_line = 50 Then Incr Current_block             ' * next block
    Return
    ' * second block ******************************************************************************************* colour blocks 1
    Lin2:                                                       ' * Blank line
       Colour = 0
       If Current_line = 60 Then Incr Current_block             ' * next block
    Return
    Lin3:
    For Video = 0 To 15 Step 1
       Colour = 0
       Colour = Video
       Waitus Grid
    Next Video
       If Current_line = 84 Then Incr Current_block             ' * next block
    Return
    ' * third block ******************************************************************************************** colour blocks 2
    Lin4:                                                       ' * Blank line
       Colour = 0
       If Current_line = 90 Then Incr Current_block             ' * next block
    Return
    Lin5:
    For Video = 16 To 31 Step 1
       Colour = 0
       Colour = Video
       Waitus Grid
    Next Video
       If Current_line = 114 Then Incr Current_block            ' * next block
    Return
    ' * forth block ******************************************************************************************** colour blocks 3
    Lin6:                                                       ' * Blank line
       Colour = 0
       If Current_line = 120 Then Incr Current_block            ' * next block
    Return
    Lin7:
    For Video = 32 To 47 Step 1
       Colour = 0
       Colour = Video
       Waitus Grid
    Next Video
       If Current_line = 144 Then Incr Current_block            ' * next block
    Return
    ' * fith block ******************************************************************************************** colour blocks 4
    Lin8:                                                       ' * Blank line
       Colour = 0
       If Current_line = 150 Then Incr Current_block            ' * next block
    Return
    Lin9:
    For Video = 48 To 63 Step 1
       Colour = 0
       Colour = Video
       Waitus Grid
    Next Video
       If Current_line = 174 Then Incr Current_block            ' * next block
    Return
    ' * sixth block ******************************************************************************************** colour cycle blocks
    Lin10:                                                      ' * Blank line
       Colour = 0
       If Current_line = 180 Then Incr Current_block            ' * next block
    Return
    Lin11:
    For Video = 0 To 31 Step 2
       Colour = 0
       Temp = New_colour + Timer1
       Colour = Temp + Video
       Waitus 1.36
    Next Video
       If Current_line = 200 Then Incr Current_block            ' * next block
    Return
    ' * seventh block ******************************************************************************************** grey blocks
    Lin12:                                                      ' * Blank line
       Colour = 0
       If Current_line = 206 Then Incr Current_block
    Return
    Lin13:
    For Video = 1 To 3 Step 1
       Colour = 0
       Colour = Lookup(video , Grey)
       Waitus 12.4
    Next Video
       If Current_line = 232 Then Incr Current_block            ' * next block
    Return
    ' * eighth block ******************************************************************************************** rainbow
    Lin14:                                                      ' * Blank line
       Colour = 0
       If Current_line = 238 Then Incr Current_block            ' * next block
    Return
    Lin15:
    For Video = 1 To 59 Step 1
       Incr Colour
    Next Video
       If Current_line = 264 Then Incr Current_block            ' * next block
    Return
    ' * last block ********************************************************************************************** colour fall
    Lin16:                                                      ' * Blank line
       Colour = 0
       If Current_line = 270 Then Incr Current_block            ' * next block
    Return
    Lin17:
    For Video = 0 To 200 Step 4
       Colour = Video + Current_line                            ' * more electricky ;-)
    Next Video
       If Current_line = 300 Then Current_block = 0             ' * last block, reset to zero  ( normaly at line 288 )
    Return
    End
    ' * Data for grey bars, block #7
    Grey:
    Data &B00000000
    Data &B00000111
    Data &B00111000
    Data &B00111111
  • #4 6719981
    PiotrEtenM500
    nie wiem co chcesz osiągnąć więc podałem taki przykład
    zobacz kit z AVT2853. To jest proste i tanie
    Tu bardzo ładny projekt, ze źródełkiem i opisem
    Link
  • #5 7589696
    Marcin_xx1
    Był podobny temat w bascom tyle ze dla monitora, trzeba zmienić (zwiększyć)
    czasy impulsów dla telewizora https://www.elektroda.pl/rtvforum/topic1210857.html z attiny na powyższe procesory chyba nie jest trudno
    przenieść kod.
    Jeżeli powyższy układ pracuje w trybie vga to być może wystarczy obniżyć częstotliwość kwarcu o polowe i odchylanie poziome będzie się zgadzać z telewizyjnym, nie wiem jak tam działa obliczanie ramki, dla telewizora trzeba około 50 hz, trzeba by jeszcze przerobić wyjście impulsów synchronizacji
    by wszystkie były na jednym pinie.
