MODEL YEAR(S)
GRAND CHEROKEE 1996 -1998
KEY T-HARNESS IMMOBILIZER
N/A CHR-1 N/A
PART COLOR LOCATION
12 VOLT CONSTANT RED/WHITE (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 DARK BLUE/GRAY (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLACK/ORANGE (+) See NOTE *1 IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 RED/BLACK (+) See NOTE *1 IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BLUE/RED (+) @ HEAD LIGHT SWITCH
POWER LOCK ORANGE/VIOLET and PINK/BLACK (TYPE C) See NOTE *2 IN BOTH FRONT DOORS, See DIAGRAM
POWER UNLOCK PINK/BLACK (TYPE C) See NOTE *2 IN BOTH FRONT DOORS, See DIAGRAM
DOOR TRIGGER YELLOW (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION TURNS ON with DISARM
TRUNK RELEASE ORANGE/BROWN (+), Requires Part #775 Relay @ HATCH RELEASE SWITCH
SLIDING POWER DOOR N/A
HORN GRAY/ORANGE (-) @ STEERING COLUMN HARNESS
TACH GRAY/WHITE @ PCM, See NOTE *3
WAIT TO START LIGHT N/A
BRAKE WHITE/TAN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM PURPLE/YELLOW (-) IN DRIVERS DOOR HARNESS
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 When installing a Remote Starter, BOTH Accessory #1 and #2 wires MUST BE USED!! NOTE *2 Use ORANGE/VIOLET for LOCK and PINK/BLACK for UNLOCK at the DRIVERS DOOR SWITCH. Use BLACK/WHITE for LOCK and PINK/BLACK for UNLOCK at the passenger front door switch. This vehicle requires (2) of part # 778 one for each door See DIAGRAM. NOTE *3 the PCM (Powertrain Control Module) is located High on the Passenger side firewall.
