Glosniki 20 , 25 , 30 ,38 cm
Supra1991 04 Paź 2009 14:42 2471 14
  • #1 7089666
    Supra1991
    Witam!
    Mam takie pytanie:
    jak mocna bedzie roznica DB w samochodzie jesli zaloze:
    2 glosniki 20cm za 1500zl
    albo
    1 glosnik 25cm za 1500zl
    albo
    1 glosnik 30cm za 1500zl
    albo
    1glosnik 38cm za 1500zl
    Napedze jeden z tych glosnikow:
    Blaupunkt VELOCITY BURNING DESIRE 2
    Dane techniczne wzmaczniacza to:
    1 x 1200W Rms @ 4 ohm (0.07% THD)
    1 x 1750W Rms@ 2 ohm (0.07% THD)
    1 x 2000W Rms@ 1 ohm (0.07% THD)
    Freq. Response: 10Hz ~ 450Hz S/N Ratio: >95 dBA
    Wymiary - 57.3cm x 27.8cm x 6.5cm
    Waga - 7.2 kg
    Ktory da najwiecej Decybeli w samochodzie?
  • #2 7089686
    Invalid
    Ten za 1500zł.
  • #3 7089690
    Supra1991
    Invalid napisał:
    Ten za 1500zł.
    Ale ktora srednica glosnika bo tym napewno tez sie rozni ilosc DB
  • #4 7089705
  • #5 7089790
    Supra1991
    2 Glosniki 20cm
    JL Audio 8W3v3-4
    Rozmiar: 200 mm
    Moc RMS: 150 W
    Impedancja: 4 Ohm
    Max wychylenie: 7,5 mm
    Skrzynia zamknięta: 10,6 l
    Skrzynia bas-reflex: 21,2 l
    Glosnik 30cm:
    Hifonics AS12SQ (kwadratowy)
    # Subwoofer średnica 30 cm ( 12 cali )
    # Moc RMS: 900 W
    # Moc Max: 1800 W
    # Hifonics Atlas cast Aluminum chrome basket
    # Woven glass fiber cone
    # Acrylic Illuminated Dust Cap
    # 1.4" Rubber Surround
    # Nomex fiber spider with woven tinsel leads
    # 2.5" Bi-fair wound 4 layer voice coil
    # Thick Aluminum voice coil former
    # Dual 2 Ohm voice coil with 40MM voice coil winding
    # 6 Flare shape magnet design with 140 Oz triple stack magnet
    # 10MM Polished top plate
    # Chrome plated flare T-plate
    # Push pin terminal
    # Rubber magnet boot
    # Priced per speaker
    Glosnik 38cm
    CarPower SONIC 15
    Impedance (Z) 2 x 2Ω
    Resonant frequency (fs) 25Hz
    Max. frequency range f3-300Hz
    Music power 2 x 800WMAX
    Power rating (P) 2 x 400WRMS
    SPL (1W/1m) 88dB
    Suspension compl. (Cms) 0.13mm/N
    Moving mass (Mms) 310g
    Mech. Q factor (Qms) 10.86
    Electr. Q factor (Qes) 0.52
    Total Q factor (Qts) 0.50
    Equivalent volume (Vas) 126 l
    DC resistance (Re) 2 x 1.9Ω/1 x 3.8Ω
    Force factor (BxL) 19Tm
    Voice coil induct. (Le) 2 x 0.7mH/1 x 2.8mH
    Voice coil diameter Ø 75mm
    Voice coil former Kapton
    Linear excursion (XMAX) ą25mm
    Eff. cone area (Sd) 830cm2
    Magnet weight 180oz.
  • #6 7089866
    Karolo MPower
    Poziom 30  
    Sonic 15 zrobi największy bass i ciśnienie.
  • #7 7089885
    Grzegorz Siemienowicz
    Poziom 36  
    A mógłbyś doprecyzować tą myśl. Nie za bardzo rozumiem.
  • #8 7089894
    Supra1991
    chodzilo mi o to ze wydawalo mi sie ze jak wieksza srednica membrany glosnika to zrobi wieksze cisnienie i bedzie mocniejsze udezenie!
    A teraz takie rozwiazanie
    2 glosniki 38cm
    Hifonics BX15D2
    * Średnica głosnika: 380 mm
    * Moc Max: 1400W
    * Dual 2-Ohm Illuminated DVC Subwooferr
    * Moc RMS: 700-Watts
    * Impedancja: 2 x 2 Ohm
    * Fs: 27,57 Hz
    * Qts: 0.48
    * Vas: 122,6 Liters
    * Xmax: 15mm
    * SPL: 97,84 dB @ 2.83v
    * Illuminated Brutus Speaker Cone
    * Huge 100z. Double-Stack Magnet Assembly
    * 2.5-inch 4-Layer Hi-Temp Aluminum Voice-Coils
    * Woven Glass-Fiber Layered Composite Cone
    * Integrated One-Piece Spider- Tinsel Lead Design
    * White Chrome Steel Speaker Frame with Rubber Front Gasket
    * 1" Tall NBR Reinforced Rubber Surround
    * Rubber Magnet Boot
    * Ported Nickel Plated Back-Plate for Heat Dispersion
    * Nickel Plated Push & Insert Terminals
    * Nomex Spider-Assembly
    * For Vented And Sealed Enclosure Designs
    bedzie lepiej od sonic'a??
    to juz ostatnie pytanie!
    Karolo MPower
    Poziom 30  
    Masakra normalnie... skaczesz kolego od zastosowań w miare mocnych do bardzo mocnych.
    2x38 cm zagra duzo lepiej od sonica, chociazby dlatego, że powierzchnia membrany 2x15" jest o niebo wieksza niz 1x15" a po drugie 2x700 = 1400 RMS> 1x800 RMS ( sonic )
    Szybka pomoc :D
  • #10 7089967
    Supra1991
    ;) dzieki i sorki za takie troche dziwne pytania;p ale dzieki za pomoc ;) pozdrawiam;]
  • #11 7090020
    Poziom 36  
    1) Ciśnienie akustyczne czyli "głośność" wytwarza subwoofer czyli głośnik/i z obudową.
    2) Jest to również jakoś (niekoniecznie liniowo) zależne od dynamiki/skuteczności/efektywności przetwornika oraz dostarczonej mocy.
    Radził bym zwrócić się do ludzi zajmujących się chociaż hobbystycznie SPL podając:
    a) Maksymalną objętość skrzyni;
    b) Moce RMS wzmacniacza przy różnych rezystancjach;
    c) Budżet.
    Najlepiej było by dla Ciebie aby jeden z takich tuzów podjął się wykonania dla Ciebie takiej skrzyni.
  • #12 7090865
    RafałVR6
    Kup 2 x rainbow hammer 15 i masz konkretne ciśnienie
  • #13 7094669
    GSX-R
    Kupa Jackhammera: )
  • #14 7094702
    Supra1991
    tak jest 1 jackhammer 20.000rms i mozna sluchac haha xD
  • #15 7102540
    crazy_88
    będzie to konkretna propozycja
