HP CP1700 in VISTA - format papieru i duplex - rozwiązanie
krzychop 18 Paź 2009 01:27 11594 0
  • Jak pewnie niektórzy zauważyli HP olało sprawę sterowników do wielu swoich urządzeń pod VISTA
    Jednym z takich urządzeń jest drukarka A3 HP CP1700
    Sam sterownik instaluje się z automatu ale nie posiada podstawowje funkcji wyboru formatów papieru i włączenie funkcji duplex (gdy mam zainstalowany fizycznie w drukarce)
    Rozwiązanie
    I have a patch that will allow printing large format but it does not currently support tray selection. I am working on this and hope to have a solution eventually,
    If your favorite paper size is not available after you apply the patch try the following: go to start, settings, printers. Right click on an empty area and select "run as administrator", server properties, forms, click the "create a new form" box, type in a new form name like Super B in the Form name box, set the width and height to 13 and 19 inches, save form, close. Now open the CP 1700 properties, you should have Super B available in the Paper/Quality tab. This should work for other custom sizes as well.
    INSTALACJA PATCHA
    Go to "Start" and in the start search box type CMD.EXE, the press the control and shift keys and while holding them hit enter. This will open a window called "Administrator: Command Prompt". At this point type the following in Blue Bold exactly, and the computer will respond with the information in italics.
    net stop spooler
    [If you are connected by a network connection the following will appear, for USB connection skip to the mkdir c:\temp line.]
    The following services are dependent on the Print Spooler service.
    Stopping the Print Spooler service will also stop these services.
    TCP/IP Print Server
    Do you want to continue this operation? (Y/N) [N]: Y
    The TCP/IP Print Server service is stopping.
    The TCP/IP Print Server service was stopped successfully.
    The Print Spooler service is stopping.
    The Print Spooler service was stopped successfully.
    mkdir c:\temp (This directory may already exist....)
    [now go to the path file and copy c:\temp\hpw1b83l.gpd]
    cd %windir%\system32\spool\drivers\w32x86\3 or if Vista 64 cd %windir%\system32\spool\drivers\x64\3
    ren hpw1b83l.gpd *.bak
    copy c:\temp\hpw1b83l.gpd c:
    1 file copied
    del *.bud
    net start spooler
    The Print Spooler service is starting.
    The Print Spooler service was started successfully.
    exit
    [You may need to reboot the computer at this point to get the changes to take effect]
    Go to Start, Settings, Control Panel, Printers, right-click on the 1700, Run as Administrator, Properties, Printing Preferences and then change any setting such as in the Paper/Quality box select Fast Draft, Apply, OK, OK. You can then go back later and change the settings to whatever you want.
    Go to Start, Printers, doubleclick on the CP1700d, Printers, Properties, Device Settings and set the duplexer to "Installed" if you have a duplexer. If you do not have a duplexer set this to "not installed"
    After each command press the enter key. The computer should respond to each command with a prompt such as c:
    krzychop
    krzychop napisał 28 postów o ocenie 2. Mieszka w mieście Mazowieckie. Jest z nami od 2006 roku.
