s300 migajace diody-reset pampersa
p4v3u 18 Lis 2009 12:34 9456 0
  • Opis jak wyzerowac waste ink counter
    Waste Ink Counter Reset.
    (1) Turn off the printer.
    (2) Press and hold the RESUME button, then press and hold the POWER button.
    (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will ???reset" or move momentarily.
    If the above was properly performed the printer will enter the "Service Mode".
    (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press.
    1. Service/Factory test printout, including ink sensor check.
    2. EEPROM - Info printout.
    3. EEPROM ??? Initialization.
    4. Reset the Waste ink counter.
    5. Printer model setting. (More selections beyond this point ??? However it is best leave them unaltered ??? You have been warned!)
    After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
    Dziala, wlasnie sobie odpalilem stare dobre S300.
    p4
    p4v3u
    p4v3u napisał 1256 postów o ocenie 35, pomógł 50 razy. Mieszka w mieście z lasu. Jest z nami od 2004 roku.
