Pisałem na innym forum ale tam robili sobie ze mnie jaja, mam nadzieję że tutaj dostanę profesjonalną pomoc. O to moje przykłady wzmacniaczy wszystkie są nowe:
JBL GTO7001 560zł
Technical Specification
RMS Power Range : 700 Watts
Number Of Channels: 1
Low Frequency response: 20 Hz
High Frequency Response: 330 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
RMS Power @ 4 Ohms: 425W x 1
RMS Power @ 2 Ohms: 700W x 1
Built-in Variable Electronic Crossover
Dynamic Bass Optimization Circuit
THD 0.02% (rated power at 4 ohms)
Full-Range PREAMP Outputs
Remote bass level control included
Dimensions (L x W x H): 15" x 10-3/8" x 2-1/8"
orion HCCA-D2400 600zł
Amplifier Type: Mono
-RMS Power @ 4 Ohms: 425W x 1 @ 4 ohms
-THD at 4-Ohm RMS Power: <1%
-Bridged RMS Power @ 4 Ohms: 800W x 1 @ 2 ohms
-Speaker Level Inputs: no
-Preamp Outputs : yes
-Built-In Crossovers: HP/LP
-Bass Boost: 0-10 dB
-Frequency Response: 20-250 Hz
-Signal to Noise Ratio: 57 dB
-Fuse Rating: 3 x 40 amps
INFINITY REF 1600A: 500zł
tryby pracy (kanały) 1
moc RMS, 4 Ohm 1 x 400W
moc RMS, 2 Ohm 1 x 600W
podbicie basu: płynne 0 - 6 dB
pasmo przenoszenia 11 Hz - 320 Hz
ustawienia zwrotnicy LP/wyłączony 32 - 320 Hz
nachylenie zboczy zwrotnicy 6 dB/okt
czułość wejściowa 100 mV - 6 V
wymiary: 360 x 228 x 69 mm
INFINITY 611A 500zł
Mono subwoofer car amplifier
657 watts RMS x 1 at 2 ohms
456 watts RMS x 1 at 4 ohms
Variable low-pass filter (32-320 Hz @ 12 dB/octave)
Dynamic Bass Optimization (DBO) circuit (0-12 dB at 20-80 Hz)
Class D Technology
CEA-2006 compliant
Preamp inputs and outputs
Fuse rating: 30A x 2
4-gauge power and ground leads recommended
15-7/8"W x 2-11/16"H x 12-1/8"D
PRECISION POWER D1000 560zł
-Amplifier Type: Mono
-RMS Power @ 4 Ohms: 185W x 1 @ 4 ohms
-THD at 4-Ohm RMS Power: 0.1%
-Bridged RMS Power @ 4 Ohms: 495W x 1 @ 1 ohm
-Speaker Level Inputs: yes
-Frequency Response: 20-200 Hz
-Signal to Noise Ratio: >70 dB
-Fuse Rating: n/a
JBL GTO7001 560zł
Features
INFINITY 611A 500zł
Class D Technology
CEA-2006 compliant
-Fuse Rating: n/a
