Config Lcd = 16 * 2
$crystal = 1382400 ' fusebit ustaw xtal full swing
$baud = 9600
$hwstack = 32
$swstack = 10
$framesize = 40
Cls
Deflcdchar 1 , 14 , 31 , 31 , 31 , 31 , 31 , 31 , 31 ' bat full
Deflcdchar 2 , 14 , 17 , 17 , 25 , 29 , 31 , 31 , 31 ' bat haf
Deflcdchar 3 , 14 , 17 , 17 , 17 , 17 , 17 , 17 , 31 ' bat empty
Cursor Off
Config Portd.6 = Input
Config Portd.7 = Input
Config Portb.2 = Input
Config Portb.1 = Input
Config Portb.1 = Input ' sound on
Config Portd.4 = Input ' fgm-3
Config Portd.5 = Input 'fgm-3
Config Portc.5 = Input ' batt indicator
Config Timer0 = Counter , Edge = Falling
Config Timer1 = Counter , Edge = Falling ,
Config Timer2 = Timer , Gate = Internal , Prescale = 8
Dim F0 As single
Dim F1 As single
Dim Fx As single
Dim F0min As single
Dim F0max As single
Dim F1min As single
Dim F1max As single
Dim F1calib As single
Dim F1offset As single
Dim Fus As long
Dim Initf As Byte
Dim Temp0 As single
Dim Temp1 As single
Dim Tt0 As single
Dim Tt1 As single
Dim Factormin As single
Dim Factormax As single
Dim Tempf1 As single
Dim Tempf2 As single
Dim Tempf3 As single
'dim duration as integer
Dim Kalibracja As Bit
Dim Skalibrowany As Bit
Dim Counts As Long
Declare Sub Czas1
Dim Sampling As Integer
On Timer0 Przepelnienie0
On Timer1 Przepelnienie1
On Timer2 Timer2_int
Cursor Off
Enable Interrupts
Enable Timer0
Enable Timer1
Enable Timer2
Cls
Config Adc = Single , Prescaler = Auto , Reference = avcc
Start Adc
Dim batt As Word , Channel As Byte
'channel = 5
l
Lcd " FLUXGATE"
Lowerline
Lcd " GRADIOMETER"
'Wait 1
Temp0 = 0
Temp1 = 0
Tt0 = 0
Tt1 = 0
Kalibracja = 0
Skalibrowany = 0
F0min = 0
F0max = 0
F1min = 0
F1max = 0
Sampling = 454
Cls
Do
If Pind.6 = 0 Then Sampling = 454
If Pind.7 = 0 Then Sampling = 227
If Pinb.2 = 0 Then Sampling = 45
If Pinb.1 = 0 And Kalibracja = 1 Then
Kalibracja = 0
F0min = F0
F0max = F0
F1min = F1
F1max = F1
Bitwait Pinb.1 , Set
Delay
Skalibrowany = 1
Goto Pomiar
End If
If Pinb.1 = 0 And Kalibracja = 0 Then
Kalibracja = 1
Cls
Lcd " Calibration"
'Wait 1
Cls
Lcd " very slowly"
Lowerline
Lcd " rotate sensor"
'Wait 1
Cls
Lcd " on magnetic"
Lowerline
Lcd "inclinat. plane"
'Wait 1
Goto Kalibracja
End If
If Kalibracja = 0 Then Goto Pomiar
If Initf = 0 and Sampling = 454 Then
Initf = 1
F0min = F0
F0max = F0
F1min = F1
F1max = F1
End If
If Sampling = 227 Then
Sampling = 454
Goto Pomiar
End If
If Sampling = 45 Then
Sampling = 454
Goto Pomiar
End If
Sampling = 454
Kalibracja:
If F0 < F0min Then
F0min = F0
F1min = F1
End If
If F0 > F0max Then
F0max = F0
F1max = F1
End If
'Print "F0min = " ; F0min
'Print "F0max = " ; F0max
'Print "F1min = " ; F1min
'Print "F1max = " ; F1max
Tempf1 = F0max / F1max
'print "tempf1 = " ; Tempf1
Tempf2 = Tempf1 * F1min
'Print "f0 / Tempf2 = " ; F0min ; " / " ; Tempf2
Pomiar:
If Skalibrowany = 0 And Kalibracja = 0 Then
Cls
fus = f0
Lcd Fus
Locate 1 , 8
fus = f1
Lcd "* " ; Fus
Fx = F0 - F1
Lowerline
fus = Fx
Lcd Fus
batt = Getadc(5)
Print batt
Locate 2 , 16
if batt > 800 then lcd chr(1)
if batt >= 600 and batt <= 800 then lcd chr(2)
if batt < 600 then lcd chr(3)
Locate 2 , 12
If Sampling = 454 And Kalibracja = 0 Then Lcd "1s"
If Sampling = 227 And Kalibracja = 0 Then Lcd "0.5s"
If Sampling = 45 And Kalibracja = 0 Then Lcd "0.1s"
End If
If Skalibrowany = 0 And Kalibracja = 1 Then
Cls
fus = F0
Lcd fus
Locate 1 , 8
fus = f1
Lcd "* " ; fus
Fx = F0 - F1
Lowerline
fus = fx
Lcd Fus
Locate 2 , 6
Lcd "calibration"
End If
If Skalibrowany = 1 And Kalibracja = 0 Then
Cls
fus = f0
Lcd fus
Locate 1 , 8
Factormax = F0max / F1max
'Print "factormax = " ; Factormax
F1calib = Factormax * F1
fus = f1calib
Lcd "* " ; Fus
Fx = F0 - F1calib
Lowerline
fus = fx
Lcd Fus
batt = Getadc(5)
Print batt
Locate 2 , 16
locate 2 , 8
lcd "cal"
Locate 2 , 12
End If
If Skalibrowany = 1 And Kalibracja = 1 Then
Cls
fus = f0
Lcd Fus
Locate 1 , 8
fus = f1
Lcd "* " ; Fus
Fx = F0 - F1
Lowerline
fus = fx
Lcd Fus
Locate 2 , 6
Lcd "calibration"
End If
F0 = 0
F1 = 0
Counter0 = 0
Counter1 = 0
Temp0 = 0
Temp1 = 0
Call Czas1
Stop Counter0
Stop Counter1
F0 = 256 * Temp0
F1 = 65535 * Temp1
Tt0 = Counter0
Tt1 = Counter1
F0 = F0 + Tt0
F1 = F1 + Tt1
Loop
Sub Czas1
Counts = 0
Counter2 = 0
Start Timer2
Start Timer0
Start Timer1
Do
If Counts = Sampling Then
Stop Timer2
Stop Timer0
Stop Timer1
Exit Do
End If
Loop
End Sub
Timer2_int:
Counter2 = 0
Start Timer2
Incr Counts
Return
Przepelnienie0:
Incr Temp0
Return
Przepelnienie1:
Incr Temp1
Return
