Co myślicie o tym wzmacniaczu ? The Loudest TL-1021
godiii 23 Lut 2010 10:22 1550 0
  • #1 7737638
    godiii
    Parametry podane przez producenta, a moze ktoś sprawdzał sam :D
    Output Power (14.4v)
    (When bridging the channels)
    1 x 8,000 watts Max (@ 2 ohm)
    1 x 3,000 watts RMS (@ 2 ohm THD+N < 3.5%)
    1 x 2,000 watts RMS (@ 4 ohm THD+N < 2%)
    Up to 1 x 3,400 watts RMS (@ 2 ohm)
    Up to 1 x 2,500w watts RMS (@ 4 ohm)
    (When using both channels individually)
    2 x 4,000 watts Max (@ 1 ohm per channel)
    2 x 1,500 watts RMS (@ 1 ohm per channel THD+N < 3%)
    2 x 950 watts RMS (@ 2 ohm per channel THD+N < 2%)
    2 x 600 watts RMS (@ 4 ohm per channel THD+N < 3%)
    2 x 560 watts RMS (@ 4 ohm per channel THD+N < 1%)
    Frequency response 10 Hz ~ 200 Hz
    Subsonic Filter Frequency Range 20 ~ 50 Hz (Adjustable)
    Low Pass Filter Frequency Range 40 ~ 180 Hz (Adjustable)
    Bass Boost Frequency Range
    45 Hz
    Input Impedance
    67 Kohm
    Input sensitivity
    0.2 V ~ 5 V
    Signal/Noise Ratio (A. Wtg)
    1 Watt Reff.
    >100 dB
    Damping Factor
    (100 Hz @ 4 ohm)
    >120
    Efficiency
    82%
    Total Harmonic Distortion (THD)
    4 ohm loaded 1 Watt 0.20%
    800w RMS 0.50%
    80% of total 0.70%
    Idle Current 2.4 A
    Max Peak Current
    240 A
    Minimum Subwoofer impedance Each channel individually
    1 ohm
    Minimum Subwoofer impedance when in bridge mode
    2 ohm
    Power supply
    DC 12V
    Dimensions
    (length x width x height) 60 x 19
    Czy na prawdę może mieć taką moc, jaką producent podaje ??
    A może ktoś słyszał jak on gra ?
