Witam! Znalazłem opis konfiguracji licznika a4 b6 na stronie ros tech nie mogłem tego znaleźć spędziłem 12h żeby to znaleźć ale udało się wchodzicie w instruments 17, następne adaptacje kanał 19 i podaje opis poniżej co i jak .
audi A4 2001 > Dash panel insert, adapting illumination, DIS, radio clock and on-board computer
In adaption channel 19 the following functions are adapted:
Radio clock
Driver information system
On-board computer
Illumination options
The following options are possible:
1st digit: Radio clock and sports seats:
Coding value XXXX0 = Radio clock not active
Coding value XXXX1 = Radio clock active (with PR no. U2A)
Coding value XXXX2 = Radio clock not active and sports seat active (only RS4) (with PR no. Q4P)
Coding value XXXX3 = Radio clock active and sports seat active (only RS4) (with PR no. U2A and Q4P)
2nd digit is not coded, so always 0:
XXX0X
3rd digit: Driver Information System:
Coding value XX1XX = Highline dash panel insert without driver information system, (no drive time alarm, no washer fluid/brake light/bulb warning (even in Check) and Computer option not selectable from menu. Only range displayed on on-board computer. (dash panel inserts with PR no. 9Q3)
Coding value XX2XX = Driver information system with menu guidance
Coding value XX3XX = Driver information system with menu guidance and unit switching (dash panel inserts with PR no. 9Q2 and 9Q4)
4th digit: On-board computer:
Coding value X0XXX = On-board computer (only level 2 - long-term memory)
Coding value X1XXX = Level 1 and 2 (dash panel inserts with PR no. 9Q2 and 9Q4)
5th digit: Illumination options:
Coding value 0XXXX = Illumination (pointer and scale) on only active with lights on
Coding value 1XXXX = Pointer illumination on active with ignition on, scale (1st dimming characteristic) and pointer illumination active with lights on
Coding value 2XXXX = Scale illumination (1st dimming characteristic) active with ignition on, scale and pointer illumination active with lights on
Coding value 3XXXX = Scale (with 2nd dimming characteristic) and pointer illumination active with ignition on or lights on
General points on dimming characteristics:
If one of the two dimming characteristics is adapted, the value of the photo transistor in the dash panel insert is included in the illumination (according to the adaptation: pointer, scales or both).
Example:
If a vehicle drives into a tunnel, underpass or suchlike during daytime without its lights on, the illumination in the dash panel insert is dimmed down to indicate to the driver that the driving lights are off. Depending on the adaptation, either the pointer or scale illumination, or both, is dimmed
Go to 17 dash and go to adaptation channel 19 and use the help balloon to determine your code.
Mine required to be set to 31010
