Land Rover jaki alarm CAN czy ANALOG
Robert H 18 Mar 2010 08:36 2065 3
  • #1 7845964
    Robert H
    Mam pytanie czy do samochodu Land Rover 01r musi być alarm na CAN czy może być zwykły analog, jeżeli ma ktoś schemat podłączenia alarmu pod Land Rover.
  • #3 7848521
    Robert H
    Sory zapomniałem dopisać Land Rover Freelander
  • #4 7848909
    carrier
    Specjalista - Alarmy Samochodowe
    FREELANDER 2002 -2006
    KEY T-HARNESS IMMOBILIZER
    N/A N/A LAND ROVER'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key
    PART COLOR LOCATION DIAGRAM
    12 VOLT CONSTANT BROWN (+) and BROWN/RED (+) IGNITION SWITCH HARNESS
    STARTER WHITE/RED (+) IGNITION SWITCH HARNESS
    STARTER 2 N/A
    IGNITION 1 GREEN (+) IGNITION SWITCH HARNESS
    IGNITION 2 BROWN/WHITE (+) IGNITION SWITCH HARNESS
    IGNITION 3 N/A
    ACCESSORY/HEATER BLOWER 1 GRAY/BLUE (+) IGNITION SWITCH HARNESS
    ACCESSORY/HEATER BLOWER 2 PURPLE/GRAY (+) IGNITION SWITCH HARNESS
    KEYSENSE N/A
    PARKING LIGHTS ( - ) N/A
    PARKING LIGHTS ( + ) RED (+) or RED/WHITE (+) @ HEADLIGHT SWITCH
    POWER LOCK BLACK/BROWN (TYPE B) @ CCU, 26-Pin plug, Pin 20, See NOTE *1
    POWER UNLOCK BLACK/PINK (TYPE B) @ CCU, 26-Pin plug, Pin 8, See NOTE *1
    LOCK MOTOR WIRE PINK (+) @ CCU, 10-PIN PLUG, PIN 4, See NOTE *1
    DOOR TRIGGER PURPLE/GRAY (-) and PURPLE/WHITE (-) Use both, See NOTE *2 @ CCU, 26-Pin plug, Pins 24 and 21, See DIAGRAM 17044_FREELANDER_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
    DOMELIGHT SUPERVISION USE DOOR TRIGGER
    TRUNK RELEASE ORANGE/BROWN (-) @ CCU, 26-Pin plug, Pin 18, See NOTE *1
    SLIDING POWER DOOR N/A
    HORN PURPLE/YELLOW (-) @ CCU, 10-Pin plug, Pin 5, See NOTE *1
    TACH Any wire NOT BROWN/PINK or BLACK @ ANY IGNITION COIL
    WAIT TO START LIGHT N/A
    BRAKE GREEN/PINK (+) @ SWITCH ABOVE BRAKE PEDAL
    FACTORY ALARM DISARM BLACK/RED (-) @ CCU, 26-Pin plug, Pin 7, See NOTE *1
    ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER
    NOTES
    NOTE *1 the CCU (Central Control Unit) is attached to the back of the FUSE BOX under the DRIVERS SIDE of the DASH
    NOTE *2 this vehicle has (2) Door Trigger wires, when connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
