Citroen Xsara II po lifcie 2002 r 2.0 HDI Montaż alarmu
k0vv4l3k 27 Mar 2010 20:08 4577 1
  • #1 7887681
    k0vv4l3k
    Witam, Potrzebuje pomocy w podłączeniu alarmu a dokładnie sterowania zamkiem centralnym w mojej cytrynie. Zamek centralny jest fabryczny i to właśnie do niego potrzebuje podłączyć nowy alarm. Ma ktoś jakieś schematy do tego samochodu ? Może własne doświadczenia z montażem ? Nigdy takiego czegoś nie robiłem i nie za bardzo wiem jak sie do tego zabrać. Sterowanie jest "+" czy "-" ? DOdam że posiadam BSI.. Proszę o pomoc
  • #2 7888129
    sadek1979
    Spec od samochodów
    proszę bardzo
    SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
    www.cobra.it
    Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
    as per the instructions given on the product installation manual.
    cixs202gbb.doc
    MAKE CITROEN MOD. XSARA 2 YEAR. 02 ® PETROL
    DIESEL
    ALARM/SIREN
    POSITION
    Position the compact alarms and the sirens on the dome of the shock absorber,
    passenger’s side.
    CENTRAL UNIT POSITION Position the modular systems and the modules under the dashboard, driver’s
    side.
    POWER SUPPLY + 30: connect to the 3 mm2 RED wire located at the entrance of the fuse box.
    - 31: connect with a cable terminal to one of the original ground wire located on
    the right of the BSI operating central.
    IGNITION WIRE + 15/54: connect to the wire, at the position nr. 16, coming out of the 26 way blue
    connector of the BSI operating central.
    DIRECTION INDICATORS Connect to the wires at the positions nr.13 and nr.14 coming out of a 16 way black
    ELECTRIC WINDOWS Positive control signal
    Front window, driver’s side:
    refer to the diagram nr. 113.
    Front window, passenger’s side:
    Rear window, driver’s side:
    cut the wire located at the position nr. 3, in the 16 way grey connector.
    Rear window, passenger’s side:
    cut the wire located at the position nr. 4, in the 16 way grey connector.
    CENTRAL DOORS LOCKING Original door motor control signal
    For antithefts of the Bridge serie, refer to the diagram nr.102; for antithefts of the
    3100 serie refer to the diagram nr.102A.
    IMMOBILISATION POINT 1
    IMMOBILISATION POINT 2
    Fuel pump
    Cut the YELLOW wire located in a wiring harness coming out of the connector of
    the inertial switch placed on the shock absorber support, passenger’s side.
    General underlock
    Cut the wire located at the position nr. 16 coming out of the 26 way blue
    connector of the BSI central.
    STARTER +50: Cut the YELLOW wire located in a flying wiring harness placed on the rear
    of the cover of the fuse box.
    BONNET SWITCH Install an additional switch on the front headlamp support plate, driver’s side.
    DOORS SWITCH Connect to the wire at the position nr. 23 of the 26 way blue connector of the BSI
    operating central.
    Note: the lamp control is with positive polarity.
    www.cobra.it
    cixs202gbb.doc
    FITTING DIAGRAM N° 102
    Diagram to make the lock and unlock of the doors on
    Citroen XSARA 2 year 2002
    (for Bridge serie antithefts)
    VIOLET YELLOW/BLACK ORANGE GREY/BLACK VIOLET/ORANGE
    + 30
    Position nr. 4
    Position nr. 3
    Towards door motors 16 way black connector
    www.cobra.it
    cixs202gbb.doc
    FITTING DIAGRAM N°102A
    (for 3100 serie antithefts)
    ORANGE/WHITE
    + 30
    Position nr. 4
    Position nr. 3
    www.cobra.it
    cixs202gbb.doc
    FITTING DIAGRAM N° 113
    Diagram for windows connection on
    CITROEN XSARA 2 year 2002
    Diagram for windows locking using the BROWN/WHITE wire of the autodriven Bridge serie antithefts.
    Left Right
    Diagram for windows locking using the BROWN wire of the no autodriven Bridge serie, 3100 e 3800 antithefts.
    1055
    1 2 3 4 5 6 7
    1052
    1 2 3 4 5
    push botton push botton
    +30 LIGHT BLUE GREY
    Diode 1N4004
    BROWN/WHITE Diode 1N4004
    Left Right
    LIGHT BLUE GREY
    +30
    Diode 1N4004
    BROWN Diode 1N4004
