Atmega32 SD-512 MB LCD nokia 6100-Obrazki z karty
ugh123 28 Mar 2010 20:42 4183 5
  • #1 7892145
    ugh123
    Cześć wszystkim ;)
    Mam ogromną prośbę o pomoc w sprawie otwierania obrazków w formacie *.bgc ktore beda umieszczone na karcie pamięci i atmega ma je otwierać i wyświetlać na kolorowym lcd . Probowałem już kilka różnych sposobów ale za każdym razem obrazek się nie wyswietlał poprawnie . Serdecznie pozdrawiam Bartek
    Nizej kod programu do obslugi karty sd i kolorowego lcd
    $regfile = "m32def.dat"
    $crystal = 8000000
    $lib "Lcd-pcf8833.lbx "                                     'special color display support                                         '8 MHz
    Config Graphlcd = Color , Controlport = Portc , Cs = 3 , Rs = 2 , Scl = 0 , Sda = 1
    Const Blue = &B00000011                                     'predefined contants are making programming easier
    Const Yellow = &B11111100
    Const Red = &B11100000
    Const Green = &B00011100
    Const Black = &B00000000
    Const White = &B11111111
    Const Brightgreen = &B00111110
    Const Darkgreen = &B00010100
    Const Darkred = &B10100000
    Const Darkblue = &B00000010
    Const Brightblue = &B00011111
    Const Orange = &B11111000
    Glcdcmd &H36                                                'Mem_control
    Glcddata &H48                                               'My=0 Mx=0 V=1 Lao=1 Rbg=0 "00110000"
    Glcdcmd &H21
    Config Clock = Soft
    Config Date = Mdy , Separator = /
    Time$ = "00:00:00"
    Date$ = "01/01/10"
    Config Watchdog = 2048
    Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 1
    Start Timer1
    Pwm1a = 150
    Cls
    $include "CONFIG_AVR-DOS.Bas"
    '$include "AVR-DOS.LBX"
    '---SPI-HW----------------------------------------------------------------------
    Const Cmmc_soft = 0                                         'SPI HARDWARE
       ' define Chip-Select Pin
       Config Pinb.4 = Output                                   ' define here Pin for CS of MMC/SD Card
       Mmc_cs Alias Portb.4
       Set Mmc_cs
       ' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
       Config Pinb.7 = Output                                   ' define here Pin of SPI SS
       Spi_ss Alias Portb.7
       Set Spi_ss                                               ' Set SPI-SS to Output and High por Proper work of
                                                      ' SPI as Master
       ' HW-SPI is configured to highest Speed
      Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1       'Config Spi = Soft , Din = Pinb.3 , Dout = Portb.2 , Ss = Portb.0 , Clock = Portb.1
       Spsr.0 = 1                                               ' Double speed on ATMega128
       Spiinit                                                  ' Init SPI
    'Spiinit
    ' Error
    Const Cperrdrivereset = 225                                 ' Error response Byte at Reset command
    Const Cperrdriveinit = 226                                  ' Error response Byte at Init Command
    Const Cperrdrivereadcommand = 227                           ' Error response Byte at Read Command
    Const Cperrdrivewritecommand = 228                          ' Error response Byte at Write Command
    Const Cperrdrivereadresponse = 229                          ' No Data response Byte from MMC at Read
    Const Cperrdrivewriteresponse = 230                         ' No Data response Byte from MMC at Write
    Const Cperrdrive = 231
    Const Cperrdrivenotsupported = 232                          ' return code for DriveGetIdentity, not supported yet
    Waitms 700
    Dim Gbdriveerror As Byte                                    ' General Driver Error register
    Dim Gbdriveerrorreg As Byte                                 ' Driver load Error-Register of HD in case of error
    Dim Gbdrivestatusreg As Byte                                ' Driver load Status-Register of HD on case of error
    Dim Gbdrivedebug As Byte
    Dim B As Word
    Dim C As Word
    Dim S As String * 96
    S = Dir( " * .txt")
    $lib "MMC.LIB"                                              ' link driver library
    $external _mmc
    Enable Interrupts
    Box(0 , 0) -(130 , 130) , Blue
    Gbdriveerror = Driveinit()
    B = Initfilesystem(1)
    C = Drivecheck()
    'start watchdog
    Dim Rozmiar As Long
    Rozmiar = Disksize() \ 1000
    Dim Wolne As Long
    Wolne = Diskfree() \ 1000
    Setfont Color8x8
    Cls
    If B > 0 Then Lcdat 50 , 10 , "Sprawdz KarteSD" , Darkred , White
    Lcdat , 10 , 2 , "AVR-DOS v 2.0" , Black , White
    Lcdat , 20 , 2 , "Atmega 32-16PU " , Black , White
    Lcdat , 30 , 2 , "CPU at 8 Mhz" , Black , White
    Lcdat , 40 , 2 , "Ram size : 2 KB" , Black , White
    Lcdat , 50 , 2 , "LCD PCF-8833" , Black , White
    Lcdat , 60 , 2 , "Karta SD info" , Black , White
    Lcdat , 70 , 2 , "Rozmiar: " ; Rozmiar ; " MB" , Black , White
    Lcdat , 80 , 2 , "Wolne  : " ; Wolne ; " MB" , Black , White
    Lcdat , 90 , 2 , "System OK" , Black , White
    End
  • #2 10654940
    dominon
    A gdzie masz procedurę rysowania na LCD pikseli i odczytywania pliku? Sprawdź helpa bascom'a dla polecenia SHOWPIC i przykład dla $BGF. Może uda Ci się przerobić tamte procedury pod odczyt.
    uczesietak
    Siemka ugh123 :D
    Co prawda nie mam tego wyświetlacza (Nokia), lecz o wiele większy.
    Ale do do tematu.
    Pliki ".bgc" są zapisywane w 8-bitowym kolorze, Ja pracuję z 16-sto bitowymi kolorami, więc konieczna jest konwersja z 8 na 16 bitów.
    Informacje na temat wymieniony przez Ciebie znajdziesz w sieci (poszukaj).
    Nie dam Ci gotowca,i sądzę, iż nikt Ci nie da :P
    Zerknij tutaj : http://evertdekker.com/Joomla/index.php?option=com_content&task=view&id=77&Itemid=116
    Sprawa wygląda tak :
    Kod: text
    Zaloguj się, aby zobaczyć kod
    Niestety ja pracuję na wyświetlaczu 320*240 i 16 bitowych kolorach, więc Sam się musisz pomęczyć z Twoim wyświetlaczem.
    Powodzenia :D
    PS. Podziękowania dla autora projektu.
  • #4 10673614
    dominon
    uczesietak Jak byś mógł to używaj znaczników Code albo SYNTAX. W ten sposób wiadomość będzie czytelniejsza i nie będzie zbędnie wydłużona.
  • #5 10675119
    uczesietak
    Dominon to jest mój pierwszy post, więc proszę o wyrozumiałość.
    Pozdrawiam :)
  • #6 10676446
    dominon
    Pozdrawiam :)
    Dlatego właśnie chciałem Ci udzielić porady i zwrócić uwagę na takową możliwość przy zamieszczaniu odpowiedzi w postaci listingów czy nawet całego kodu źródłowego :D
