Witam chciałbym dokupic pamiec, ale nie wiem jak ja dobrac
poznizej wklejam wycinek z CPU-Z
Chipset
Northbridge VIA K8T800 (VT8383) rev. 01
Southbridge VIA VT8237 rev. 00
Graphic Interface AGP
AGP Revision 2.0
AGP Transfer Rate 4x
AGP SBA not supported, not enabled
Memory Type DDR
Memory Size 256 MBytes
Channels Single
Memory Frequency 134.0 MHz (CPU/12)
CAS# latency (CL) 2.5
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 7
Bank Cycle Time (tRC) 9
DRAM Idle Timer 16
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Manufacturer (ID) Samsung (CE00000000000000)
Size 256 MBytes
Max bandwidth PC2100 (133 MHz)
Part number M3 68L3313BT0-CB0
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-2-2-5-0 @ 100 MHz
JEDEC #2 2.5-3-3-7-0 @ 133 MHz
Monitoring
Mainboard Model K8T800-8237 (0x00000270 - 0x699A14F0)
Najadja się takie ?
2 sztuki DDR PC2100 1GB 266MHz - firmy SMART na układach SAMSUNG
OBYDWIE DWUSTRONNE.
Bylbym wdzieczny za podanie parametrow PC i Mhz jakie moga dokupic by chodizly na tej plycie glownej i nie bylo konfliktu z juz istniejaca pamiecia
Chipset
AGP Revision 2.0
Memory Type DDR
Channels Single
Cycle Time (tRAS) 7
DRAM Idle Timer 16
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Size 256 MBytes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Monitoring
Najadja się takie ?
OBYDWIE DWUSTRONNE.
